Old Sep 30, 2011, 09:40 AM
aerofundan is offline
Find More Posts by aerofundan
aerofundan's Avatar
Panama
Joined Jul 2005
Yup, my bandit has always been flown on the Spektrum AR6210, first with the DX8 and now i switched to the JR 11x. It is a perfect receiver for it.
DemonGTI, nice job on the build!!!! keep on sharing the pics with us
aerofundan is offline Find More Posts by aerofundan
Site Sponsor
Old Sep 30, 2011, 10:15 AM
cayars is offline
Find More Posts by cayars
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
Yea, I've never had a bit of problem with any receiver in a PA plane. I just wanted to stress not to do something like tape the antenna to the plane right over carbon. That's why I stressed to keep the antennas away from the carbon.
Use common sense and your good to go.
cayars is offline Find More Posts by cayars
Old Sep 30, 2011, 11:55 AM
javabeans is offline
Find More Posts by javabeans
Bedford, Mass. USA
Joined Dec 2007
Just as an FYI... do not use an Orange receiver with a PA plane (single antenna).
I put one in my Addiction with the plan to only fly it close and not have to worry about range, but one day I was flying alone at the field and within minutes the flight was full of pilots and I ended up flying farther away from myself without thinking about it and lost control at about 300 feet away. Luckily it came down in tall grass with minimal damage (broken motor box and cowl).
javabeans is offline Find More Posts by javabeans
Old Sep 30, 2011, 12:33 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Java, I would go so far as to recommend not using those rx's in anything other than a combat foamy. While several people swear by them, I have found the quality control in manufacturing these orange rx's are so inconsistent that range varies from rx to rx. Some of those rxs can go as far as my brand name rx's but most of them drop the signal past only several hundred feet.
There are several side-by-side comparisons on Youtube that demonstrate the poor range of the Orange.
While we all said the same thing about HK batteries several years ago, "I am not going to risk my plane with a $10 battery..." now Turnigey has quickly become a standard and a huge competitor for Thunder Power for batteries.
However, I still wont trust my plane with a $5.99 orange rx; I have seen too many reports of failure for me to be comfortable using them, especially on high-dollar models... Just my $0.02
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Old Sep 30, 2011, 12:43 PM
Bedford, Mass. USA
Joined Dec 2007
bsbauman,
That is exactly what I learned and am trying to help others with. Even though i wasn't planning on flying outside the box, it happened and I got bit. I now only use them in home-made foamies.
Old Sep 30, 2011, 02:25 PM
jonathan7x70 is offline
Find More Posts by jonathan7x70
Fly, fly, fly, fly , fly more!
jonathan7x70's Avatar
Lafayette, Louisiana
Joined Dec 2005
Question... In this video: It says 4 Cell.... What mah size and c rating? or just the mah?
Thanks!!
PA Bandit 4S iPAs Xtreme setup maiden flights, flown by Daniel Dominguez (6 min 28 sec)
jonathan7x70 is offline Find More Posts by jonathan7x70
Old Sep 30, 2011, 03:15 PM
USA, GA, Atlanta
Joined Nov 2008
Originally Posted by javabeans View Post
bsbauman,
Dont you hate learning the hard way
Like when I found out CA Debonder will not work on a clear plastic canopy... Doh! It results in a nasty looking, irremovable fog.
Old Sep 30, 2011, 03:44 PM
aerofundan's Avatar
Panama
Joined Jul 2005
Thanks!!
http://vimeo.com/28627649
Hi Jonathan, its a PA 14.8v 2200 mah 20-40c they are available at the PA website.
Site Sponsor
Old Oct 01, 2011, 08:41 AM
demonGti is offline
Find More Posts by demonGti
Precision Aerobatics Team
demonGti's Avatar
South Africa, GP, Randburg
Joined Dec 2006
Installing servos
Here are a few pic of installing the aileron servos.
I first cut the covering and ironed the overlap into the servo bay.
Centre the servo in the bay and carefully drill one hole with a 1.5mm bit using the grommet as a guide. Lightly screw down that side and drill the second hole and tap in the second screw.
Remove the screws and servo and wick a small droop of CA into the holes to harden the freshly tapped threads. ( i turn a screw in before the CA sets to make sure the hole does not get clogged with CA )
Fit servos.
demonGti is offline Find More Posts by demonGti
Old Oct 01, 2011, 12:44 PM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
All my linkages are made up now.
I epoxy the ball link side first since this end is a tight fit.
Roughen the tab on control horns and make sure the horn is aligned properly before you epoxy it in place. Then get the clevis fitting nicely onto the CF control horn. Tape the control surface in its neutral position. Shorten the CF rod as required to get the hole in the ball link to line up with the servo CF control horn. Obviously make sure you servos are centred before you epoxy the clevis to the CF rod and don't forget to notch both ends of the CF rods so the epoxy has an irregular surface to bite onto. Lastly use a "permanent" thread lock on the exposed threads on all the linkages. The last thing anyone needs is a nut working loose....
Job done, all control surfaces operational
Next up is VG's and decals
Old Oct 01, 2011, 03:20 PM
Ybor_elevator is offline
Find More Posts by Ybor_elevator
United States, FL, Tampa
Joined Sep 2011
Niiiice!
Ybor_elevator is offline Find More Posts by Ybor_elevator
Old Oct 01, 2011, 05:50 PM
OSOFAM is offline
Find More Posts by OSOFAM
What will happen if ....Oh....
OSOFAM's Avatar
Australia, VIC, Sale
Joined Oct 2007
Some more pics of my Bandit build. These are of making up the extended servo leads. I tinned the stripped wire ends first before I soldered them together. This makes the join quick and does not expose the wire insulation to too much heat from the soldering iron.
dG
Top work with the build pictures demonGti.
I though I might add some pictures of my method of actually connecting the wires together when soldering the extensions.
1) Strip the insulation off the wire.
2) "Tin" the wire with solder and put the heat shrink on.
3) Put a hook in the wire and hook the wires to each other.
4) Squeeze the wires together
5) Put a little bit of solder on the joint to mold the wires together
6) Shrink the heat shrink.
And repeat for all the wires.
OSOFAM is offline Find More Posts by OSOFAM
Old Oct 01, 2011, 06:21 PM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
I cut the holes in the covering for the VG's as per the manual. Just one of the underside small VG slots I couldn't see ( covered by the white stripe ) but with an LED light from the other side in the dark I could make out where they were. Nearly ready now for maiden tomorrow morning
Old Oct 01, 2011, 06:23 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Videos ladies
bildo baggins is offline Find More Posts by bildo baggins
Old Oct 01, 2011, 06:43 PM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
That's a very secure technique Dave
My Bandit is ready!
In Mr.K's words; Is it tomorrow yet, Is it tomorrow yet, Is it tomorrow yet, Is it tomorrow yet, Is it tomorrow yet, Is it tomorrow yet?!?!
New Product Precision Aerobatics Addiction X Official thread / Video just posted!!! aerofundan 3D Flying 5904 Sep 08, 2016 10:19 AM
Discussion Anyone else wish Precision Aerobatics would make a larger electric 3D monoplane! Neil_SC 3D Flying 19 Sep 24, 2014 11:14 AM
Wanted Precision Aerobatics Katana MD or Precision Aerobatics Mini Katana mixer911 Aircraft - Electric - Airplanes (FS/W) 5 Jul 16, 2009 12:52 PM
Found 3d hobbyshop/precision aerobatics/greatplanes**3d yak/suk/katana/edge/extra helifryer Aircraft - Electric - Airplanes (FS/W) 10 May 20, 2009 09:13 PM
Discussion Precision Aerobatics How To Series, 3D Aerobatics & Repair Guide aerofundan 3D Flying 22 Jan 03, 2009 09:52 AM
