The only batteries I am using now are 70c and 90c Nano-Tech Turnigey batteries from HK.
They have held up incredibly well to my abuse and no swelling either. On top of the very high discharge rates, these batteries are capable of 10s charge rates! That means I can charge at up to 22.2 amps with my 24v power supply and my Super Duo 3 Hyperion charger, I max out at 20 amps however that will still fully balance charge a battery in about 8 mins.
Latest blog entry: Burned Retina Shorts
I'm using Hyperion VX packs and the new Thunder Power 65c packs in my other electrics - including my PA Extra. The Hyp packs are rated for a 5c charge, and the new TP 65c packs are rated for a 12c charge. Hyperion claims 300+ cycles with no loss of performance. Most of my Hyp packs are over three years old, and most have over 300 cycles on them @ 5c charge. Static RPM tests show that they're still very healthy, and none of them show any signs of swelling. TP claims 600 cycles with no loss of performance. The TP packs are performing very well, but none of them have even hit the 50 cycle mark yet - so, it's much too early to assess their longevity. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Joined Nov 2008
FWIW -many of the build processes in the Bandit are similar to the special delivery video - so you can still use that as a reference. That video took me over a week of near full time work to complete - so i wont be doing another one in the near future.
if you count the number of shots and edits in there you will get to a big number very quickly... In Fact there is probably less building on the Bandit than in the Special delivery edit- due to some very kind pre-hinging work designed in by Shaun, and the ball and clevis links supplied And the larger frame makes the tricky areas easier to access. |
I must admit, I have not tried their newest generation of 65c batteries, but I have had numerous batteries from them up to the 45c packs... after swelling several of the 45c 2650mAh batteries, I gave up on them completely. ...it is nice to read that Turbo's TP packs have held up well, but even he points out they have not had much use. |
| Thread Tools | |
| New Product Precision Aerobatics Addiction X Official thread / Video just posted!!! | aerofundan | 3D Flying | 3607 | May 16, 2013 06:40 AM |
| Discussion Anyone else wish Precision Aerobatics would make a larger electric 3D monoplane! | Neil_SC | 3D Flying | 18 | Apr 17, 2011 06:04 PM |
| Wanted Precision Aerobatics Katana MD or Precision Aerobatics Mini Katana | mixer911 | Aircraft - Electric - Airplanes (FS/W) | 5 | Jul 16, 2009 12:52 PM |
| Found 3d hobbyshop/precision aerobatics/greatplanes**3d yak/suk/katana/edge/extra | helifryer | Aircraft - Electric - Airplanes (FS/W) | 10 | May 20, 2009 09:13 PM |
| Discussion Precision Aerobatics How To Series, 3D Aerobatics & Repair Guide | aerofundan | 3D Flying | 22 | Jan 03, 2009 09:52 AM |
