Australia, QLD, Ipswich
Joined Sep 2008
I've tried two PA spinners as well, absolutley useless spinner, I'll never waste my money on a PA branded accessory again. Between rubbish spinners and prop/motor adaptors (i've tried two of those aswell) that can't clamp on the shaft correctly if you fit a spinner without modifying it.
My Bandit flys nice, and I still consider the idea of picking up an Addiction X but I don't think I could bring myself to do it. The quality is just not there, between bad accessories, cheap rubbish covering, and structure that has been excessively lightened in areas where it shouldn't have been and bits of CF in locations where it is achieving no added strength yet it is left out of areas where it could actually give large gains in strength. As for a spinner that is actually well priced and spins pretty true whilst also being light, take a look at the EF spinners, they don't have the exact size but 2.25" vs. 2.17" you'll barely notice. |
2nd impressions
I flew the Bandit today and while it's a nice flyer, lands easy, is very responsive, it is very pitch sensitive. Started moving the CG between flights and haven't yet found the sweet spot. Lots of EL coupling when I KE, but it's only slightly nose heavy when I do dive and inverted tests to validate the settings. I've maxed the resolution on my DX8/AR7100 by setting the travel adjusts to 100% and played with a lot and a little expo.
I do think the Voltec servos contribute to the pitch sensitivity. I'm going to look for a high res digital servo and put it on the tail. I've played with expo a bit. I'll give it a go again next week with a new servo. Paul |
Joined Sep 2008
These steps made quite a noticable improvement in pitch sensitivity, but it is still a very pitch sensitive airframe. |
There is a certain method of how to mount the spinner properly. follow it and you'll be find. i use the CF spinners on all of my planes, no problems at all. Just push the cone firmly in while fastening the mounting bolts. as long as the cone sit flush it won't wobble. Sometimes the mounting drills needs to be filed a bit to allow the bolts to fit well but that takes seconds to do with a needle file. I re-designed the prop adapter used on the Bandit and KMX to be longer in order to have a better grip while the front of the collet to be a tad shorter. Shaun Precision Aerobatics Team |
I purchased a pair of HS-5065MGs and will try on the rudder and the elevator next weekend. Let you guys know if the repeatability of a digital servo (hopefully improving centering) will help with my pitch sensitivity problem. Hard to say if the resolution is actually improved over the Voltecs.
What's the difference? I'm not being a smart alec - I just want to understand.
Thinking out loud, perhaps a hypothetical airframe could be said to lack directional stability, which would mean that frequent input from the pilot is required to keep it pointing in any given direction, maybe because its tail surfaces are comparatively small. Personally, I don't detect any such tendencies with the Bandit. It doesn't appear to want to pitch up or down on its own, meaning its directionally stable in that plane. But if I do crank the elevator input, it can respond very strongly, if that's the current rates+expo setup. That's what I'd assume is meant by "pitch sensitivity" - the aircraft is sensitive to pitch input from the pilot. Or is there a better definition for "pitch sensitivity"? |
Joined Sep 2008
Whereas pitch authority means it still has excellent response when you yank on it and that ability to flip in it's own length yet isn't such a pain to get on line and is still smooth around centre and you don't find yourself over-correcting when trying to get on just the right line. |
| Thread Tools | |
| New Product Precision Aerobatics Addiction X Official thread / Video just posted!!! | aerofundan | 3D Flying | 3610 | May 19, 2013 11:26 PM |
| Discussion Anyone else wish Precision Aerobatics would make a larger electric 3D monoplane! | Neil_SC | 3D Flying | 18 | Apr 17, 2011 06:04 PM |
| Wanted Precision Aerobatics Katana MD or Precision Aerobatics Mini Katana | mixer911 | Aircraft - Electric - Airplanes (FS/W) | 5 | Jul 16, 2009 12:52 PM |
| Found 3d hobbyshop/precision aerobatics/greatplanes**3d yak/suk/katana/edge/extra | helifryer | Aircraft - Electric - Airplanes (FS/W) | 10 | May 20, 2009 09:13 PM |
| Discussion Precision Aerobatics How To Series, 3D Aerobatics & Repair Guide | aerofundan | 3D Flying | 22 | Jan 03, 2009 09:52 AM |
