Old Jan 31, 2013, 07:57 AM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
Does the bandit ARF only come with the CF servo arms?
Wingbreaker is offline Find More Posts by Wingbreaker
Old Jan 31, 2013, 08:09 AM
Arcturus97 is offline
Find More Posts by Arcturus97
Retreating Blade Stall
Arcturus97's Avatar
United States, VA, Woodbridge
Joined Apr 2011
It does not come with any servo arms, nor does the bling package come with servo arms. The PA CF servo arms are sold separately. I would get them though. I thought they were included in the bling package that I ordered - wound up using Dubro extra long servo arms (plastic) and they bend under load / large deflection. I eventually got the CF servo arms and more pleased with those.
Arcturus97 is offline Find More Posts by Arcturus97
Old Jan 31, 2013, 09:22 PM
aquaanox is offline
Find More Posts by aquaanox
United States, MD, Rockville
Joined Feb 2010
Originally Posted by zemkes_wolfpack View Post
The prop adapter comes with the drive package. One thing I would recommend adding is the Vox 14x7 for a 3S setup or Vox 12x6 for 4S setup if you haven't already planned on doing so.
We look forward to helping you out.If you have any question please don't hesitate to contact us.
You can't go wrong with either of the colors. I thought the blue would be difficult to see but it really isn't.
Best Wishes,
Jim
Precision Aerobatics USA
thanks - i ordered the kit yesterday in green and it looks like its already in the mail So any one running the ds11AMB's ? any issues with fitment etc ? recommended ? cheers
aquaanox is offline Find More Posts by aquaanox
Old Feb 01, 2013, 06:52 PM
Evant28 is offline
Find More Posts by Evant28
United States, WA, Seattle
Joined Nov 2012
Hi I was wondering about the c clip on the thrust 40 motor. What does it look like? If I am correct there is a bronze washer under it. Does this come out too?
Please help.
Evant28 is offline Find More Posts by Evant28
Old Feb 01, 2013, 06:58 PM
pilot_keeter is offline
Find More Posts by pilot_keeter
pilot_keeter's Avatar
United States, GA, Atlanta
Joined Nov 2008
Please help.
The C clip is the black clip before the ring that dosen't make a full circle around the shaft. You'll want to remove both as they are not needed and get in the way when installing the motor. Removing the C-clips on my motors I always end up bending them/breaking then to get them off. No big deal if this happens to you, you shouldn't ever need it.
pilot_keeter is offline Find More Posts by pilot_keeter
Old Feb 01, 2013, 07:06 PM
Evant28 is offline
Joined Nov 2012
OK thanks. I noticed that after I removed the clip the front of the motor seems very loose. What holds the motor together?
Old Feb 01, 2013, 07:11 PM
Joined Nov 2008
At this point nothing. You can pull it apart if you wanted to. The housing can only come off when pulled from one direction. The way that the motor is mounted makes it impossible for any part of the motor to come loose or apart.
Old Feb 01, 2013, 07:14 PM
Evant28 is offline
Joined Nov 2012
Old Feb 02, 2013, 12:51 PM
aquaanox is offline
Joined Feb 2010
Got my ipa pack in the mail but no spinner or backplate included ??? Kinda misleading based on pics.. Did they just forget to throw it in ? Thx
Old Feb 02, 2013, 12:57 PM
Joined Nov 2008
At the bottom of all the iPA pages it says:
Note: the Carbon Fiber 2.17" Spinner and Vortex Generators are not included in the kit.
Old Feb 02, 2013, 07:18 PM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Just my personal opinion of course - prop spinners are entirely useless for 3D planes. Their only positive effect is cosmetic, and even that is debatable, but they block airflow and make it that much more difficult to balance the prop.
What's the purpose of those four holes through the motor mount plate - the ones which match up with similar cooling holes in the motor itself - if they're all going to be blanketed by a spinner?
I suggest saving the not-inconsiderable amount of money and putting it toward another airframe instead. Same with the carbon wheel pants. Just unnecessary bling.
H2SO4 is online now Find More Posts by H2SO4
Old Feb 02, 2013, 07:28 PM
gtoguy is offline
Find More Posts by gtoguy
gtoguy's Avatar
USA, CA, Healdsburg
Joined Dec 2007
Maiden Today
Finally had an open weekend and perfect weather - got to maiden the Bandit today. I had set the CG at 101mm per the manual, and it was still too tail heavy for my tastes. Pushed the battery forward about 8-10mm and it was just about right. It flies very nicely and is super floaty yet has smooth power. I do like the flight envelope. After a few more flights, this might become one of my favorites.
I'd advise against the Voltec servos though, they just don't center very well. I'm looking into alternatives. Move the elevator down then back up and the control surface is about 1-2mm off. I'll probably get some small digitals. Thanks, Paul
gtoguy is offline Find More Posts by gtoguy
Old Feb 02, 2013, 07:33 PM
Joined Nov 2008
Anyone using 65mg's in this rig? I'm thinking about switching to those.
Old Feb 02, 2013, 08:52 PM
Evant28 is offline
Joined Nov 2012
Just wondering, in the manual it seems like you need the spinner to align the cowling and to do a couple other things with the motor mount.
Old Feb 02, 2013, 09:25 PM
Joined Nov 2008
It is helpful to have the backplate when position the cowl but not 100% needed to get it right. Eye-balling from the front/using a ruler to measure will do just fine.
New Product Precision Aerobatics Addiction X Official thread / Video just posted!!! aerofundan 3D Flying 5838 Jun 07, 2016 02:18 PM
Discussion Anyone else wish Precision Aerobatics would make a larger electric 3D monoplane! Neil_SC 3D Flying 19 Sep 24, 2014 11:14 AM
Wanted Precision Aerobatics Katana MD or Precision Aerobatics Mini Katana mixer911 Aircraft - Electric - Airplanes (FS/W) 5 Jul 16, 2009 12:52 PM
Found 3d hobbyshop/precision aerobatics/greatplanes**3d yak/suk/katana/edge/extra helifryer Aircraft - Electric - Airplanes (FS/W) 10 May 20, 2009 09:13 PM
Discussion Precision Aerobatics How To Series, 3D Aerobatics & Repair Guide aerofundan 3D Flying 22 Jan 03, 2009 09:52 AM
