Old Jan 21, 2013, 07:01 PM
Evant28 is offline
Find More Posts by Evant28
United States, WA, Seattle
Joined Nov 2012
Thanks for trying, maybe someone else can find a way. I've been flying for a while but I never used the forums until this year. I get almost full throw on the rudder but will the position of the elevator cause problems?
Evant28 is offline Find More Posts by Evant28
Old Jan 21, 2013, 07:45 PM
pilot_keeter is offline
Find More Posts by pilot_keeter
pilot_keeter's Avatar
United States, GA, Atlanta
Joined Nov 2008
Looking at it I don't think there will be much of an issue. Especially if you can get almost full throws. I would just make sure that there are no places for control hang-up or binding. If everything can move freely then you should be fine. If you have any spare red covering just throw a piece on that front hole.
pilot_keeter is offline Find More Posts by pilot_keeter
Old Jan 21, 2013, 07:51 PM
Joined Nov 2008
First 4s Experience
Got my first couple of flight on 4s today and WOW. I didn't even go full throttle but a few times and it was nothing short of unlimited power. And the 2450s gave me almost 8 minutes based on my power management. Wind was higher than I would have liked, 9-14 mph with some gusting. But the Bandit handled it very well. Not great weather for 3D practice that's for sure. My fiance snapped a few shots for me
Old Jan 21, 2013, 08:14 PM
Evant28 is offline
Joined Nov 2012
Ok thanks a bunch, oh by the way does anyone know of a place to get cheaper replacement parts for the bandit?
Old Jan 22, 2013, 12:41 AM
gtoguy is offline
Find More Posts by gtoguy
gtoguy's Avatar
USA, CA, Healdsburg
Joined Dec 2007
Slow Build...
I really want to love this plane but it's wearing on me... please forgive my rant:
I've had my Bandit since early December, and I've been plugging away at it. I'm working 60 plus hrs a week so I just don't have a lot of time on this one. However, I'd have to say it's one of the slowest building ARFs that I've done (I'm up to about 10 now). I'm done with the wings, and working on the tail section of the fuse. None of the hinge slots lined up and I had to re-slot the rudder and 1/2 the elevator. While the tail was setting up, I decided to put on the vortex generators (this took several hours). I'm meticulous, and very careful to build as precise as possible so I'm probably my own worst enemy here... I've had limited time on this one but I know I could have finished one of my 3DHS, PilotRC, or any of my E-Flite planes in much less time.
My suggestions for a quicker build:
  • Create a tight joint at the horizontal stab so you can CA it (this may require a 2-piece elevator).
  • Pre-attach the motor box (who does this anymore?)
  • Adjust the size of the motor box so it doesn't interfere with the cowl
  • Ditch the covering in the ele and rudder hinges by recessing them using pockets
  • Use screw-in control rods instead of CF that has to be trimmed and epoxied
  • Ditch the covering on the landing gear and make a single piece of pre-covered balsa that can be glued over the gear yet has holes to remove the gear
  • I don't know what can be done regarding the vortex generators, it takes a long time to do them right...
OK, I feel better now, back to building. I really want to like this plane but the distraction of a protracted build has been dishartening. Maybe in a couple of months I'll have it up and running and my view of it will change.
Thanks guys, I just needed to vent a bit on the difficulty of a seemingly "simple" build... Thanks, Paul
gtoguy is offline Find More Posts by gtoguy
Old Jan 22, 2013, 01:26 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
You have some fair points, but I do not totally agree.
For instance, I appreciated installing the motor box myself so that I could use my preferred adhesive on this joint (wood glue). Also, it let me see how they are assembled in the event I have to replace one down the road.
I have also taken to liking their pushrod methods and have used the same methods on several ships.
Regarding time you spent on the VG's and slotting hinges, that really can save a ton of time for the builder if done properly the first time (with laser) at the factory. None of my hinges lined up either on my X and not one of the VG slots was cut all the way through. I spent a good amount of time on those two issues.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Jan 22, 2013, 01:39 AM
gtoguy is offline
gtoguy's Avatar
USA, CA, Healdsburg
Joined Dec 2007
Yeah, I read through most of the posts and knew what I was getting into buying this plane... I suppose you're right on the motor box, I've seen them come apart on some "name brand" models after some abuse.
Fortunately I have a GP slot machine with a guide so it's pretty easy to cut new slots - just have to make sure and glue up the old ones.
I'm just ranting a bit, I'll be back out there next weekend plugging away at it... Paul
Old Jan 22, 2013, 01:41 AM
USA, GA, Atlanta
Joined Nov 2008
You have read it before, but once you fly, your few issues with the build will fade away.
Old Jan 22, 2013, 01:44 AM
gtoguy is offline
gtoguy's Avatar
USA, CA, Healdsburg
Joined Dec 2007
Yep, that's what I'm hoping for.
Old Jan 22, 2013, 03:56 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Paul
It took me not even to 2 hours to do VG's on my addy,and I didn't find it tedious to do.yes,be accurate and double check angles ect,but it wasn't an effort for me at all
I like the idea of the pocket hinges for the tails.
Your idea regarding the balsa block for the LG will become a problem when having to replace a LG.I'd mucg rather remove some covering,than try butcher a piece of glued in Balsa and risk damaging the fuse by trying to remove a balsa block.
But I'm sure you'll love it once you have it flying
chop stiX is offline Find More Posts by chop stiX
Old Jan 22, 2013, 04:09 AM
demonGti is offline
Find More Posts by demonGti
Precision Aerobatics Team
demonGti's Avatar
South Africa, GP, Randburg
Joined Dec 2006
Although pocket hinges might look cool and be less hassle to get the plane in the air, I don't think it's a practical idea for a 3D ship.
It's for one going to push the price up a lot, and secondly you won't achieve enough throw on the tail feathers. The PA way works just fine!
demonGti is offline Find More Posts by demonGti
Old Jan 22, 2013, 04:28 AM
Mr Kamikaze is offline
Find More Posts by Mr Kamikaze
I'm torquing to you!
Mr Kamikaze's Avatar
Wattle Grove NSW Australia
Joined Nov 2006
And 3rdly it adds weight at the tail. Which has to be countered up front. After numerous PA builds I'm down to about 8-10 hours per build now. But I'm totes ok with that because I know what I'm going to be getting at the end... Lots of these
Mr Kamikaze is offline Find More Posts by Mr Kamikaze
Old Jan 22, 2013, 05:20 AM
chop stiX's Avatar
Joined May 2011
Originally Posted by mr kamikaze View Post
and 3rdly it adds weight at the tail. Which has to be countered up front. After numerous pa builds i'm down to about 8-10 hours per build now. But i'm totes ok with that because i know what i'm going to be getting at the end... Lots of these :d:d:d
+1000:d
Old Jan 22, 2013, 07:03 AM
Joined Nov 2008
Paul,
If you take a trip back through the pages you'll see all of the trials I went through when building this plane. There were a few times that I got so frustrated I just wanted to give up. But ever since I got it in the air, it's been awesome. I haven't flown it enough to truly get a 3D feel, but I'm on my way to that point. And from the first lift off (especially on 4S) those build troubles seem to go away.
Old Jan 22, 2013, 08:25 AM
zemkes_wolfpack is offline
Find More Posts by zemkes_wolfpack
Team Hitec, Team Sebart RC
United States, IN, Winamac
Joined Jan 2006
Evan,
I recommend finishing the build and flying it as-is. The small amount you are off should not affect the flying that much. If anything you have slightly increased the tail moment.
One issue you may have is that the pushrod won't be long enough to hookup the elevator. Let us know if you have any issues in this area.
Best Wishes,
Jim
Precision Aerobatics USA Support
zemkes_wolfpack is offline Find More Posts by zemkes_wolfpack
New Product Precision Aerobatics Addiction X Official thread / Video just posted!!! aerofundan 3D Flying 5838 Jun 07, 2016 02:18 PM
Discussion Anyone else wish Precision Aerobatics would make a larger electric 3D monoplane! Neil_SC 3D Flying 19 Sep 24, 2014 11:14 AM
Wanted Precision Aerobatics Katana MD or Precision Aerobatics Mini Katana mixer911 Aircraft - Electric - Airplanes (FS/W) 5 Jul 16, 2009 12:52 PM
Found 3d hobbyshop/precision aerobatics/greatplanes**3d yak/suk/katana/edge/extra helifryer Aircraft - Electric - Airplanes (FS/W) 10 May 20, 2009 09:13 PM
Discussion Precision Aerobatics How To Series, 3D Aerobatics & Repair Guide aerofundan 3D Flying 22 Jan 03, 2009 09:52 AM
