Old Nov 19, 2012, 12:46 AM
bobmixon is offline
Find More Posts by bobmixon
bobmixon's Avatar
United States, AZ, Glendale
Joined Oct 2009
Originally Posted by pilot_keeter View Post
I accidentally cut down my push rods based on the inner hole and not the outer hole. I have at least half the insertion length of the metal clevis on both ailerons. Should this be enough to still get a strong enough connection? I'll be using 30 min. epoxy for the strongest possible bond.
It doesn't sound as though you don't have any choice. Try what you have, with 30-min epoxy, and test them. I was able to really pull quite hard on mine and they didn't come apart.
If you find they won'y hold, you may need to go back to PA and get replacements. If you do this, I would recommend not cutting them at all. I was able to accomplish a good fit by using a sanding block alone. I simply sanded the rod's to length.
And one last thing; don't forget to use a small jewelers file, or the edge of a file, to create small grooves in each end; as per the instructions. This is really important to get a good hold...
bobmixon is offline Find More Posts by bobmixon
Old Nov 19, 2012, 06:59 AM
pilot_keeter is offline
Find More Posts by pilot_keeter
pilot_keeter's Avatar
United States, GA, Atlanta
Joined Nov 2008
I filed everything per the manual
I went ahead and glued everything last night. Let it set overnight and tested everything this morning. The movements themselves are fine and I tried pulling the rod from the metal clevis almost as hard as I could with no budge at all. I wish I had a little more length to ease my mind, but I think everything will hold up.
pilot_keeter is offline Find More Posts by pilot_keeter
Old Nov 19, 2012, 10:20 AM
bmschulman is offline
Find More Posts by bmschulman
VP of Policy & Legal at DJI
bmschulman's Avatar
United States, NY, New York
Joined Oct 2006
Originally Posted by demonGti View Post
Use the outer holes. The geometry is such that the control rods will be 90 to the control surface at full deflection, which is where you need the most torque from the servos. When the ailerons are neutral you end up with control rods that are not parallel to the ribs in the wing but this is as intended.
But didn't you use red lock-tite on the screw and nut, making it impossible to move the linkage to another hole? That's what they tell you to do. It's one example of why this is a frustrating plane to build -- to answer a question posed recently. They use techniques other companies don't, perhaps to save an ounce, but they are difficult. Like cutting out slots for the control horns and gluing them in. The slots are not the right size, so you need to sand the CF horns, and of course it's hard for them to come out perfectly straight, putting strain on the linkage when in use. It looks good, but it's 10 times more work and a lot easier to make a permanent mistake (because those are glued with epoxy -- you only get one chance, unlike screw-on horns used on most models).
bmschulman is offline Find More Posts by bmschulman
Old Nov 19, 2012, 03:50 PM
Joined Nov 2008
Those pictures I took were of the push-rod test fitted, not loctitied yet.
I kept testing those rods this afternoon, trying to pull apart from the clevis pretty hard with no indication of weakness. I think they'll be okay. The real test will be in high stress/force maneuvers. I'll just have to keep an eye on them.
Old Nov 19, 2012, 04:23 PM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
The servos are only capable of about 2.5 to 3 kgcm torque. If you're using say a 2.5cm servo arm, the maximum force the servo can exert is only 1kg. If you're confident your testing is well over that force, you should be good.
scirocco is offline Find More Posts by scirocco
Old Nov 19, 2012, 04:34 PM
Joined Nov 2008
Good to know, thanks for the assurance!! I'm pretty confident that it will hold. I did my best to roughen up the CF as well I putting plenty of notch groves in the rod.
Old Nov 20, 2012, 12:54 AM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
That's static loading. Dynamic loads could be much higher.
A person abseiling will exert say 80kg of static load on the rope and anchors. However, if they tie themselves with that same length of rope and leap off the edge of a very tall cliff (a "factor one" fall), dynamic loading on the rope could easily exceed 800kg or more, depending on the rope material (how much it stretches).
A servo linkage capable of (barely) holding 2.5kg statically may easily fail when the plane does a high-stress maneuver like a wall or tumble.
H2SO4 is online now Find More Posts by H2SO4
Old Nov 20, 2012, 03:21 AM
scirocco is offline
scirocco's Avatar
Joined Feb 2001
I wonder whether I'm missing something here. I'd have thought that higher loads than the servo is capable of resisting would just drive the servo backwards. It's not like the control linkage is connected to an irreversible worm drive, or is like a rope fixed to a immovable anchor.
I gather holding torque, ie resisting movement, can be a fair bit higher than dynamic torque, but most vendors quote the higher static/holding torque only - Hyperion is the only one I've seen with both figures, with dynamic torque half static.
Old Nov 20, 2012, 03:37 AM
luke352 is offline
Find More Posts by luke352
Australia, QLD, Ipswich
Joined Sep 2008
You should've just trimmed the rod a bit shorter and then sourced some Dubro Threaded couplers of the appropriate size (similar to these http://shop.dubro.com/p/4-40-threaded-coupler-qty-pkg-2 ) and glued one to one end which would've fixed your problem and given you an adjustable length control rod like every other manufacturer (hint hint PA).
I but most vendors quote the higher static/holding torque only - Hyperion is the only one I've seen with both figures, with dynamic torque half static.
Which is the reason why most Hitec servos appear to be quite strong compared to the competition, the reality is they are just over rated.
luke352 is offline Find More Posts by luke352
Old Nov 20, 2012, 02:39 PM
Joined Nov 2008
If it comes apart in flight then so be it... I'm almost to the point of not caring anymore. I've gotten so frustrated with this build. I've tried to be patient and delicate with everything, but I always seem to break or mess something up through the process. Maybe I'm just clumsy and too inexperienced to be building this plane.
Old Nov 20, 2012, 04:18 PM
H2SO4 is online now
H2SO4's Avatar
Joined Jan 2011
It would be interesting to see a graph of force over time applied to say the elevator linkage as the plane goes into a 'parachute'. It's the extreme transients that break stuff, and given a solid carbon fibre rod there is no stretch or compression to lengthen the time over which force is absorbed and thereby reduce the transient amplitude. It's just a short, massive jolt.
My guess is that even a relatively small 3D plane like the Bandit would generate 100N of force or more for a split second - way more than the servo's ability to hold. The impulse is so short-lived that it's difficult to observe without test equipment. Unfortunately, it would also mean the link has to be capable of holding more like 10kg - rather than just 1kg - if it's to survive.
Old Nov 20, 2012, 05:22 PM
luke352 is offline
Joined Sep 2008
Don't worry it's not you, it's just PAs way of doing things that makes everything 3 times harder than it needs to be. I've built several ARF, traditional kits, short kits, laser cut kits, and a scratchbuild or two. None of those have been as irritating to build as the Bandit.
Old Nov 20, 2012, 06:04 PM
Mr Kamikaze is offline
Find More Posts by Mr Kamikaze
I'm torquing to you!
Mr Kamikaze's Avatar
Wattle Grove NSW Australia
Joined Nov 2006
And none of them fly as nice as the Bandit either
Mr Kamikaze is offline Find More Posts by Mr Kamikaze
Old Nov 21, 2012, 01:25 AM
demonGti is offline
Find More Posts by demonGti
Precision Aerobatics Team
demonGti's Avatar
South Africa, GP, Randburg
Joined Dec 2006
Originally Posted by mr kamikaze View Post
and none of them fly as nice as the bandit either
+1
demonGti is offline Find More Posts by demonGti
Old Nov 21, 2012, 09:10 AM
aerofundan is offline
Find More Posts by aerofundan
aerofundan's Avatar
Panama
Joined Jul 2005
I have been in this hobby for over 15 years, and i have built kits and many arfs. The PA planes are easy to build, the instructions are very clear, yes they use different methods than standard, but if you take the time to read the instructions it isn't hard. Also they are planes that will last for thousands of flights!
aerofundan is offline Find More Posts by aerofundan
Site Sponsor
New Product Precision Aerobatics Addiction X Official thread / Video just posted!!! aerofundan 3D Flying 5838 Jun 07, 2016 02:18 PM
Discussion Anyone else wish Precision Aerobatics would make a larger electric 3D monoplane! Neil_SC 3D Flying 19 Sep 24, 2014 11:14 AM
Wanted Precision Aerobatics Katana MD or Precision Aerobatics Mini Katana mixer911 Aircraft - Electric - Airplanes (FS/W) 5 Jul 16, 2009 12:52 PM
Found 3d hobbyshop/precision aerobatics/greatplanes**3d yak/suk/katana/edge/extra helifryer Aircraft - Electric - Airplanes (FS/W) 10 May 20, 2009 09:13 PM
Discussion Precision Aerobatics How To Series, 3D Aerobatics & Repair Guide aerofundan 3D Flying 22 Jan 03, 2009 09:52 AM
