Old Oct 01, 2012, 08:39 AM
Josef086 is offline
Find More Posts by Josef086
Joined Jan 2010
My Bandit died this weekend. I have found the translucent green and white to be a bad combo. I would loose orientation a few times every flight. The last time I came out of a KE spin a little low and I thought I came out inverted. Turns out I was wrong it a put her down into the trees.
Wings have only some minor damage (SFGS broke on one wing). Tail Section section is okay. Forward of the cowl is okay and the prop did not break....
That whole left side may still be up in a tree. If I there are enough pieces on the right side remaining maybe I can fix her up.
Josef086 is offline Find More Posts by Josef086
Old Oct 01, 2012, 08:49 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Sorry to hear Jose.maybe just order another fuse.if the rest is ok and you only need a fuse,it will be worth ordering another fuse for it
chop stiX is offline Find More Posts by chop stiX
Old Oct 01, 2012, 11:41 AM
Josef086 is offline
Joined Jan 2010
Its hard to say what I am going to do at this time. If I can take the tail apart with out breaking anything and if I can take the motor box off with out breaking it I will order a new fuse. If it needs any other parts I may look into a new airframe. I am thinking of removing the the translucent covering from the bottem and replacing it with a solid color. But thats only if I can reuse the rest of the plane.
Old Oct 01, 2012, 11:44 AM
javabeans is offline
Find More Posts by javabeans
Bedford, Mass. USA
Joined Dec 2007
Josef,
I'm with you. I damaged the fuse, battery mount, and cowl and it was only a couple of bucks more to get a new airframe.
On mine I put stripes on the bottom of the wing because of the translucent film (I flew in bright sunlight and the color bled right through so I couldn't tell which way was up).
javabeans is offline Find More Posts by javabeans
Old Oct 01, 2012, 12:30 PM
Josef086 is offline
Joined Jan 2010
It does okay in low light conditions. On cloudy days or really sunny days it runs into problems.
Old Oct 01, 2012, 05:48 PM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
I'd like to see PA adopt a black'n'white rectangle pattern on the wing underside. It may not be as pretty, but its got a certain functional beauty which is appropriate for a 3D machine. Save the pretty for something which isn't meant to do rolling harriers a couple of metres off the deck.
H2SO4 is online now Find More Posts by H2SO4
Old Oct 01, 2012, 06:01 PM
blakevan is offline
Find More Posts by blakevan
Ta-dah!
blakevan's Avatar
United States, TX, Richardson
Joined May 2007
I think the translucent film is a lot lighter than the solid film and maybe that is why they choose to use it.
blakevan is offline Find More Posts by blakevan
Old Oct 02, 2012, 02:18 PM
Josef086 is offline
Joined Jan 2010
I think your correct. Do all of the colors have the same issue with the sun? I had thought about getting a different airframe but this one flew so good and the thrust motor only works when its mounted behind the firewall
Old Oct 02, 2012, 02:34 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
Some people have issues with the clear colors and how top looks like the bottom- I have found no issues with orientation.
IMHO I would hate it if PA adopted the used-to-death scheme of rectangle patterns on the bottom of wings. I say if you can't see it, fly it lower and closer and your problem is solved! (and your flying will look much cooler the closer you bring it in)
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Old Oct 02, 2012, 02:37 PM
USA, GA, Atlanta
Joined Nov 2008
The BIG Question I have is:
When is the next Mafia Video release
They set the standard for RC vids and I am itching for a new one
Old Oct 02, 2012, 03:21 PM
H2SO4 is online now
H2SO4's Avatar
Joined Jan 2011
There's a very valid reason why that scheme is widely used - because large high-contrast areas of alternating light and dark are picked up by the eye long after subtleties of colour and pattern have been obliterated by atmospheric haze.
Whatever the distance between the pilot and their plane, increased differentiation between the top and bottom of the wing can only help. Personally, I definitely find the Bandit's comparative lack of differentiation to cause problems closer in and earlier at dusk than planes with that "done-to-death" pattern. Some of them continue flying after the Bandit is grounded - because I can no longer reliably tell which way it came out of a tumble in the failing light. For me, that's a pity because I enjoy flying the Bandit, and many of my sessions inevitably take place during twilight, after work.
Old Oct 02, 2012, 03:40 PM
Josef086 is offline
Joined Jan 2010
Unless I am flying at indoor foamie distances the contrast has a lot of issues for me. I think just going from translucent to solid would fix it.
Old Oct 03, 2012, 12:46 AM
chop stiX's Avatar
Joined May 2011
I've been wondering the same....their vids are always amazing
Old Oct 03, 2012, 12:52 AM
bmschulman is offline
Find More Posts by bmschulman
VP of Policy & Legal at DJI
bmschulman's Avatar
United States, NY, New York
Joined Oct 2006
I must be missing something. The Bandit is solid white on top, and one of four translucent colors on the bottom. To me, at distance, it looks like a uniform color on the bottom and white on top (with a bit of color trim). I'm flying the blue one, so maybe it just looks darker than other colors.
There are many planes that are the same translucent color on both sides (such as the Addiction), making it difficult to judge orientation. The Bandit isn't one of them.
bmschulman is offline Find More Posts by bmschulman
Old Oct 03, 2012, 02:04 AM
USA, GA, Atlanta
Joined Nov 2008
H2SO4~ I was in the same position, flying at night with poor eyes... you can always throw some LEDs inside like my Ad-X
New Product Precision Aerobatics Addiction X Official thread / Video just posted!!! aerofundan 3D Flying 5904 Sep 08, 2016 10:19 AM
Discussion Anyone else wish Precision Aerobatics would make a larger electric 3D monoplane! Neil_SC 3D Flying 19 Sep 24, 2014 11:14 AM
Wanted Precision Aerobatics Katana MD or Precision Aerobatics Mini Katana mixer911 Aircraft - Electric - Airplanes (FS/W) 5 Jul 16, 2009 12:52 PM
Found 3d hobbyshop/precision aerobatics/greatplanes**3d yak/suk/katana/edge/extra helifryer Aircraft - Electric - Airplanes (FS/W) 10 May 20, 2009 09:13 PM
Discussion Precision Aerobatics How To Series, 3D Aerobatics & Repair Guide aerofundan 3D Flying 22 Jan 03, 2009 09:52 AM
