I have also been waiting for the Thrust 40 to be re-stocked! I've been calling every two weeks or so for status updates and Steve (PA USA) has always been very forward with what info he has! Returned phone calls have been about 50/50, but I suspect they have been getting a lot of calls about this.
I called today and was told that the back orders would start shipping TOMORROW!!!! Which is good news for my Bandit!... Its been looking a little sad sitting on the shelf without any guts. Although they said they were dealing with at least three sheets worth of back orders... so it may be a few days depending on my orders position. Cant wait!!! Justin |
United States, TN, Sharps Chapel
Joined Apr 2011
It will be worth the wait. I'm running a Thrust 30 and a Thrust 50 in my other PA planes, and find the quality of Thrust motors to be excellent. Byron |
Just replaced all my Voltec 70's with Hitec HS-65MG's although I used the standard servo arms and not the CF arms provided with the bandit. The bolt/nut combo to fix the control rod to the servo arm only just bit (looks like it stripped when out through the previous CF arm) so I doused it in red loctite and hope it holds! The Hitec's already feel so much better, a bit smoother and a lot quieter. However time will tell whether they hold up. They should be fine.... I hope haha! |
Joined Apr 2011
Byron |
I come from the world of Hextronic HXT-900 servo's, Aim low and avoid disappointment. Hey that saying works in 3D too! |
Joined Feb 2012
Hi!
First post on this forum and looking some good advice. Considering a Bandit as my second plane after learning on my Funcub this winter. Trying to keep the cost down a bit, I was planning to get some HobbyKing esc and motor for the Bandit, but i am not sure what would be the best choice. I have several 3s 2200 Mah for the Funcub and from what i read here thats all I need
I would suggest that if you want to get into 3d and have a desire to move on - look at epo foam planes...they bounce and they can easily be repaired and you will crash ![]() I would recommend the ST models MX2 very stable and a great 3d plane...for a bigger plane - or try any epp plane... Balsa doesn't bounce and picking up lots of broken matchsticks and trying to put it back together again isn't an easy task ![]() When you have mastered epp or epo foam and are less likely to crash then move into balsa
| Thread Tools | |
| New Product Precision Aerobatics Addiction X Official thread / Video just posted!!! | aerofundan | 3D Flying | 3616 | May 22, 2013 10:13 PM |
| Discussion Anyone else wish Precision Aerobatics would make a larger electric 3D monoplane! | Neil_SC | 3D Flying | 18 | Apr 17, 2011 06:04 PM |
| Wanted Precision Aerobatics Katana MD or Precision Aerobatics Mini Katana | mixer911 | Aircraft - Electric - Airplanes (FS/W) | 5 | Jul 16, 2009 12:52 PM |
| Found 3d hobbyshop/precision aerobatics/greatplanes**3d yak/suk/katana/edge/extra | helifryer | Aircraft - Electric - Airplanes (FS/W) | 10 | May 20, 2009 09:13 PM |
| Discussion Precision Aerobatics How To Series, 3D Aerobatics & Repair Guide | aerofundan | 3D Flying | 22 | Jan 03, 2009 09:52 AM |
