Old Mar 29, 2011, 08:09 PM
gaaunapoi is offline
Find More Posts by gaaunapoi
gaaunapoi's Avatar
Nebraska, USA
Joined Jul 2010
What do you all think of the Nine Eagles Solo Pro
What are the pros and cons? Is it worth it?
Here is a link to where I think I would buy it from: http://www.miracle-mart.com/store/in...oducts_id=4382
gaaunapoi is offline Find More Posts by gaaunapoi
Old Mar 29, 2011, 08:35 PM
Frank_fjs is offline
Find More Posts by Frank_fjs
2011 - Year of the clones!!!
Frank_fjs's Avatar
Australia, SA, Adelaide
Joined Nov 2010
It's the best value for money micro FP in its class.
If you get it, order this as well: http://www.miracle-mart.com/store/in...oducts_id=3930
It's a wall charger that can charge 2 batteries at a time. You won't get by without it, charging off the transmitter takes too long and drains the TX batteries very quickly.
Also worth noting that HeliPal have the deluxe version for $99. It comes in a nice aluminium case and includes the wall charger and 2 batteries.
You could also order the case from Miracle-Mart separately if you wanted to as well, it's only $16: http://www.miracle-mart.com/store/in...oducts_id=4109.
There's a nice range of aftermarket parts available too, the landing skids are of interest: http://www.miracle-mart.com/store/in...ha_filter_id=0
Frank_fjs is offline Find More Posts by Frank_fjs
Old Mar 29, 2011, 09:28 PM
Balr14 is online now
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
If you have experience with other single rotor micros, you will find it's performance and movement authority quite gentle. If not, you will like it just fine. I found the posts in the main shaft, where the bladeholders attach, to be very fragile. If you cut them off, drill through the shaft and replace them with CF rod, you will eliminate a major annoyance.
Balr14 is online now Find More Posts by Balr14
Old Mar 29, 2011, 10:25 PM
gaaunapoi's Avatar
Nebraska, USA
Joined Jul 2010
I have never flown a single rotor heli except for a friends msr for a short while. I also own a mcx.
Is it the same as these: http://www.rcuniverse.com/magazine/a...rticle_id=1281
Old Mar 29, 2011, 10:42 PM
Frank_fjs's Avatar
Joined Nov 2010
Yes, the Solo Pro is exactly the same, minus the cosmetic differences. The Proto Max is just a re-branded version of it.
Old Mar 29, 2011, 11:00 PM
gaaunapoi's Avatar
Nebraska, USA
Joined Jul 2010
OK Thank you all.
Old Mar 30, 2011, 03:49 AM
TeeJayBee is offline
Find More Posts by TeeJayBee
United Kingdom, Swansea
Joined Mar 2011
It's a great micro heli
I got the deluxe version as it worked out best value in the long run
It's tough as a pair of old boots, can'r recall how many times it's been into the wall or floor and the only time anything broke was when I let my good lady have a go and she managed to break the blade head (like stated above)
I used a 2mm hex key cut down to 13mm long and drilled a hole right through for it, it took me about 10 minutes to do, easy and permament fix
You might want to get a spare linkage set as these are plastic and fragile, I managed to break one or two due to being ham fisted when removing them
As for it being less than responsive than some others, well I'm not so sure
There are two postions for the linkages on the swash plate, one for advanced and the other for novice, when I first had mine on advanced I couldn't control it so I set it to novice mode and learned for a while before putting it back to advanced
Not to be confused with the two modes which are switchable on the controller
TeeJayBee is offline Find More Posts by TeeJayBee
Reply With Quote  (Disabled)
Old Mar 30, 2011, 08:59 AM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Please keep in mind the Solo Pro really is the most gentle of the self-stabilizing single rotor micros. This type of heli is a very good place to start, but is a long way from being able to fly a conventional non-stabilized heli. It's a baby step, so don't get over-confident.
Old Mar 30, 2011, 12:38 PM
gaaunapoi's Avatar
Nebraska, USA
Joined Jul 2010
I understand So get an extra rotor head? And I don't understand what you are saying to cut and drill.
Old Mar 31, 2011, 05:54 AM
Joined Mar 2011
See what I did here:
http://www.rcgroups.com/forums/showthread.php?t=1412831
Old Mar 31, 2011, 10:56 PM
gaaunapoi's Avatar
Nebraska, USA
Joined Jul 2010
Ok thanks.
Discussion Do you think Nine Eagles will develop a model similar to the Blade mCP X? novasp Micro Helis 9 Feb 07, 2011 09:40 AM
Wanted Nine (9) Eagles Solo Pro - 'copter only. emarkay Aircraft - Electric - Helis (FS/W) 3 Oct 07, 2010 11:00 AM
Sold NIB nine eagles solo pro single rotor luvmykids2 Aircraft - Electric - Helis (FS/W) 3 Oct 01, 2010 04:07 PM
Discussion Revell Proto MAX RTF/Nine Eagles Solo Pro RTF $69.99 at Tower Hobbies Firehawk989 Hot Online Deals 1 Sep 29, 2010 12:16 AM
Wanted Nine Eagles Solo pro radio flyerjs Aircraft - General - Radio Equipment (FS/W) 0 Sep 20, 2010 04:10 PM
