Old Mar 28, 2011, 01:54 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Anone interested in trying glow? Every GQF/AMA member should try it at least once
Forgive me Father for I have sinned...
I have 3 nitro powered planes now. Scored two .60 sized planes this weekend and a little .049 2 channel last week. The .049 is more of a walk down memory lane but the 2 big ones... well, the deal was too good to pass up.
One of these is the Nitro Planes Explorer, same as the one I had a mid air with a german plane at the Rodeo grounds and nose planted close to the porta-potty. This is also the same model Varley used to power slide like a sprint car on our gravel runway.
Anyhow, I fired it up last night and now understand what the nitro guys go through every time they want to fly. Honestly, every one of us needs to take a flight on my new 65" w/s trainer to fully understand and appreciate what they go through. I am SURE many of the GQF'ers would hang up their radio's if they had to fly glow 100% of the time. You may not have a choice... read on...
I flew glow in the mid 70's so I rememberd most of the procedures, after all it is basically just an engine with a carb... BUT, what I did not recall until last night was how scarry it is to start a .60 sized motor on a 3' x 6' table with nothing holding the plane but my flip flop shoe material plane holder.
I had the glow plug warmer connected to the glow plug, stood in FRONT of the plane, used the hand held starter to spin the motor to life and then REACH AROUND THE SPINNING PROP to unconnect the glow warmer. Then to the back to wind it up some and adjust the needle jet on the carb that resides on FRONT OF THE MOTOR, just behind the spinning prop. Of course it died several times until I got some things figured out.
Oh, did you know the throttle channel has a servo attached? DOH, right? Well... did you know that servo "could be" REVERSED? HOLY POO POO BATMAN. Forgot that one.
Well, I am pleased to announce (more like brag) that I have all 10 digits on my hands and 10 more still on my feet but after some ground taxi loops in my back yard I shut it down (throttle trim to get carb shut down enough to starve the motor to death) and was exhausted. Why? Perhaps from the stress of reaching around a spinning prop? I dunno but honestly, it would be a good idea for all of us to do a complete flight on a glow powered plane so we learn to respect anyone that chooses to fly IC over electrics.
As for my future with glow,,,, I have 2 gallons of fuel at $10 each from the sale yesterday. After these are burned through I will go back to throwing electrons in my prop wash, not caster oil. Oh, by the way, what a mess to clean up. One other side note. Did you know that if you set your radio on the table when starting/running up a glow motor the radio may get coated in caster oil?
So, the next time we are out at the AMA field be sure to give some space to the glow guys. They need it.
Rick
rampman is offline Find More Posts by rampman
Old Mar 28, 2011, 05:43 PM
greenseaships is offline
Find More Posts by greenseaships
Registered Airplane Offender
greenseaships's Avatar
Scottsdale, Arizona
Joined Jun 2006
When I first dabbled in radio controlled airplanes back in the mid 90s, I flew glow a few times.
There.
I've done it.
And now I shall return to my electric semi-profile Hellcat build.
greenseaships is offline Find More Posts by greenseaships
Old Mar 28, 2011, 06:16 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I had a built trainer with an OS .40 in it when I was like 16. Got maybe 3 flights on it with an instructor, and pretty much burned the rest of the fuel up taxiing it up and down my neighborhood street.
And Rick, it's not the flying of the plane that commands respect. Flying is the easy part. It's the engine breaking in/tuning, fouled glo plugs, engine running backwards, shredded electric hand starter rubber, busted knuckles, $30 gallons of fuel, castor oil slimey mess that defines a true glo flyer.
BTW, did you happen to see John Mangino starting his plane during the fun fly yesterday? First time it started up, his glo plug warmer came loose and the handle found the back side of the prop. Brrrraaaaaaappppppp! Yikes!
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Mar 28, 2011, 06:19 PM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I wondered if that could happen last night. It kept leaning forward and I squenched. Made me exhausted afterwards. LOL
Old Mar 28, 2011, 06:56 PM
12345 is offline
Find More Posts by 12345
I am Bill
12345's Avatar
United States, AZ, Mesa
Joined Feb 2010
You'll have to make a "Chicken Stick" I have plans.
12345 is offline Find More Posts by 12345
Old Mar 28, 2011, 06:58 PM
neck is offline
Find More Posts by neck
Jeremy-I'm crash proof!
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
Pat
I think I saw/heard that. Guy had quick reflexes.
neck is offline Find More Posts by neck
Old Mar 28, 2011, 07:39 PM
wyldkrd is offline
Find More Posts by wyldkrd
Yeah, I can fly...
wyldkrd's Avatar
Mesa, Arizona
Joined Jun 2005
I still have a Sullivan 12v starter that works. I had a battery holder for a 7ah 12v I used to have made back in my hobby shop days but they drilled the holes wrong on half of them. I also have a contraption someone came up with back in 1995. It looks like a flashlight but its a coil spring starter. You crank it up and when you push it on the spinner it spins it. Takes a few tries unless your motor is dialed in but it still works.
It had a life time warranty. The company is long gone....
wyldkrd is offline Find More Posts by wyldkrd
Old Mar 28, 2011, 07:58 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I have one. I take it with me everywhere I go. So far I have not lost it.
Pat
Old Mar 28, 2011, 08:37 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Did my glow from the late 60's to mid 90's. Switch to full time electric never looked back.
Bob
bruff is online now Find More Posts by bruff
Old Mar 29, 2011, 08:00 AM
TBolt is offline
Find More Posts by TBolt
TBolt's Avatar
United States, AZ, Chandler
Joined May 2004
Thanks for the trip down memory lane, Maybe I won't dust off the Utter Chaos hanging in the Garage.
TBolt is offline Find More Posts by TBolt
Old Mar 29, 2011, 10:48 AM
neck is offline
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
Rick I'm curious does the bottle of fuel you purchased...does it say it could cause cancer? I remember reading the warning labels on those bottles.
Old Mar 29, 2011, 12:03 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Jeremy,
According to the State of Commie.... I mean California, EVERYTHING on earth causes cancer. Didn't you know that?
Pat
Old Mar 29, 2011, 12:10 PM
neck is offline
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
Yeah I was breast fed so California insists I have cancer.
Old Mar 29, 2011, 12:17 PM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
It will cause blindness if you drink it.
Teik-Ee told me they counter this effect by injecting alcohol into the patients veins. Not bad, drink glow fuel, go to ER and your insurance will pay for you to get drunk. Gotta love it.
Jeremy, don't overthink stuffs like this. Gas is bad for us, oil is bad for us, Ethylene glycol (anti-freeze) will skunk our livers. How many people do you know that have died or even received medical attention from any of the above.
Lastly, did you see the age of some of the glow pilots at our club? It can't be that bad and surely not as bad as when Jim Smith and his buddy used CA at our field. (before your time, sorry )
Rick
Old Mar 29, 2011, 12:25 PM
neck is offline
neck's Avatar
USA, AZ, Gilbert
Joined Mar 2008
I just remember reading the menacing label. Shoot I've practically had a bath in jet fuel.
Discussion Sometimes Being an AMA Member Does Come in Handy turbored21 AMA (Academy of Model Aeronautics) 14 Feb 19, 2012 09:56 PM
Discussion How things work at the AMA's member forum Red Scholefield Other Websites 0 Mar 15, 2011 10:01 AM
For Sale Polycharge 4 lipo charger -new in box-charge four bats at once- $55 shipped thorpdrvr Aircraft - Electric - Batteries & Chargers (FS/W) 1 Dec 25, 2010 07:14 AM
Poll Yes or No. I am an AMA Member (For Gas & Glow Pilots) Murocflyer Fuel Plane Talk 13 Jun 14, 2009 06:22 PM
Discussion Annoying Club Member, Who Doesn't Have at Least One? WACOFlyer Electric Plane Talk 57 Dec 27, 2007 10:42 AM
