Old Mar 28, 2011, 07:55 AM
perfeet is offline
Find More Posts by perfeet
Internal Paradigm Consultant
perfeet's Avatar
Joined Dec 2009
Pilot camera - What lense do you like to fly with?
I wonder what kind of lens everyone flies with.
From Hobbywireless:
1.7mm lens has approximate 170 degree field of view
2.1mm lens has approximate 158 degree field of view
2.5mm lens has approximate 147 degree field of view
2.8mm lens has approximate 130 degree field of view
2.9mm lens has approximate 127 degree field of view (Natural Human eye)
3.6mm lens has approximate 92 degree field of view
4.3mm lens has approximate 88 degree field of view
6.0mm lens has approximate 78 degree field of view
8.0mm lens has approximate 58 degree field of view
12 mm lens has approximate 28 degree field of view
I fly with a 3.6mm on a KX181.
Also have a 2.9mm I would like to try.
What lense do you prefeer to fly with?
I would like to see some videos from flights made with a lens wider than 3.6mm.
perfeet is offline Find More Posts by perfeet
Old Mar 28, 2011, 08:25 AM
nexstarselect is offline
Find More Posts by nexstarselect
Azerbaijan FPV
nexstarselect's Avatar
Joined Nov 2009
i like 4.3mm )
nexstarselect is offline Find More Posts by nexstarselect
Old Mar 28, 2011, 08:48 AM
diem is offline
Find More Posts by diem
FPV Freak :)
diem's Avatar
Radzionkow, Poland
Joined Sep 2008
I use 2.8 for everything. Btw. are u sure about that data for 1/3 sensor? I though that 2.8 is about 90 degree Its not 130 for sure.
2.8 quadrocopter
Quad over the trees (4 min 31 sec)
2.8 plane
Pierwsze plecki FPV (4 min 51 sec)
diem is offline Find More Posts by diem
Old Mar 28, 2011, 08:53 AM
Azerbaijan FPV
Joined Nov 2009
i have 2.8 but i don`t like fly with 2.8mm lens ) when 100m alttitude looklike 300m altittude
Old Mar 28, 2011, 09:10 AM
BlueAngel2000 is offline
Find More Posts by BlueAngel2000
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
i fly:
1,8mm
2,1mm
2,5mm
2,8mm
3,2mm
3,6mm
4,0mm
but you are right, with lenses like 2,8mm or less, altitude is hard to estimate.
thats why this crash happened:
2,1mm lens (edges are blurred)
FPV Celaeno Quadro Copter - Fun flying & Crash (1 min 45 sec)
I have change to 2,5mm on this quadro copter and its much better.
here is my Swift Mini with 2,8mm lens:
FPV MS Mini Swift - Fun with trees (4 min 12 sec)
i have changed already to 1,8mm lens, to see more especially in curves.
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Old Mar 28, 2011, 09:15 AM
perfeet is offline
perfeet's Avatar
Joined Dec 2009
On NGHobbies 2.8mm is stated as 115 degrees. 3.6mm as 90 degrees.
Cool videos.
Old Mar 28, 2011, 09:22 AM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
I'm using 3.6 mm now.
But moving towards 4 mm and above. Hoping for better resolution as I fly higher altitude and longer distances.
borneobear is offline Find More Posts by borneobear
Old Mar 28, 2011, 09:28 AM
diem is offline
FPV Freak :)
diem's Avatar
Radzionkow, Poland
Joined Sep 2008
Cool videos.
I dont think they are right. Try some lens calc
Found smth like that and it looks fine, horizontal 81 fov.
http://www.aventuracctv.com/lens_calculator/
Maybe they gave diagonal info...?
Its really up what kind of flights you like. If you like acro - use 2.8 and wider. If you like to fly high... use 3.6 or narrower.
And always.... wider lens for beginning. If u see more, you wont lose yourself
Old Mar 28, 2011, 11:02 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
3.6 with headtracker...
Shikra is offline Find More Posts by Shikra
Old Mar 28, 2011, 11:24 AM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
FOV is different between a 1/4, 1/3 or 1/2.5 imagers. I use either a 4mm or 3.6 on a
kx-191.
Martin Y is online now Find More Posts by Martin Y
Old Mar 28, 2011, 01:06 PM
perfeet is offline
perfeet's Avatar
Joined Dec 2009
I am planning to fly low and have fun with chainlink UHF and cloverleaf on the videofeed.
I guess I go for the acro and 2.8mm. Just tried the lens on now in the yard. Looks good.
Old Mar 28, 2011, 01:15 PM
lilphil26 is offline
Find More Posts by lilphil26
Toronto Canada
I am about to try a 6mm lens on a kx131 cam. Hoping for better clarity for long distance objects
lilphil26 is offline Find More Posts by lilphil26
Old Mar 28, 2011, 01:51 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
It won't be more clear. It'll just be shaky and nauseating.
I use 3.6mm lens with a head tracker, like this.
FPV - Skywalker maiden ground recording, antenna demo (14 min 27 sec)
That's a 1/3" CCD camera (RCV922) and FoV is definitely less than 90 degrees, but works
fine with a HT, and there's minimal barrel distortion while panning and tiling.
I might want a little wider if I wasn't using a HT on a fixed wing aircraft.
Here's a vid using a 3.6mm lens on a different 1/3" CCD camera (VSN500 aka SN777) from my tricopter
which gives an idea of what it's like to navigate around stuff with this FoV
FPV - First day Tricopter (5 min 35 sec)
Note that the same lens on a 1/4" sensor will produce a narrower FoV.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 28, 2011, 01:54 PM
CaliDave is offline
Find More Posts by CaliDave
CaliDave's Avatar
Bay Area
Joined Dec 2010
Sorry, for clarification, are you asking about experience with "aftermarket lenses" only from your list, or just in general what FOV (field of view) we prefer to fly using even if it's the stock lens?
CaliDave is offline Find More Posts by CaliDave
Old Mar 28, 2011, 02:34 PM
perfeet is offline
perfeet's Avatar
Joined Dec 2009
What field of view (FOV) you prefeer to fly with. And what lens you use.
The lenses in the list was just examples
Question What gliders do YOU fly in competition aeajr Thermal 47 Nov 11, 2010 08:27 PM
Data What Camera(s) Do You Use? How Do You Like It/Them? New to AP/AV? Please Participate! BD Flyer Aerial Photography 22 Oct 06, 2007 07:16 PM
Discussion What Camera(s) Do You Use? How Do You Like It/Them? - Discussion Thread BD Flyer Aerial Photography 43 Aug 22, 2007 07:42 PM
Well.. it looks like you fly 3D.. but.. What mixes do YOU like? Tram 3D Flying 9 Nov 08, 2003 01:59 AM
