Old Mar 27, 2011, 06:08 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Room Toon (now with Video)
Weight = 15.25g
Span = 18 in
Loading = 0.50 oz/sq.ft
More details to come, and hopefully video.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Mar 27, 2011, 06:30 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
It never stops! Looks like it ought to get the job done.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Mar 27, 2011, 06:36 PM
Boston, Mass
Joined May 2001
It's like an itch!
Old Mar 27, 2011, 07:03 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
That's it I can't take it any more, I'm selling my house and buying a Laser cutter.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Mar 27, 2011, 07:16 PM
JohnM is offline
Find More Posts by JohnM
Lifetime Member
JohnM's Avatar
Providence, RI, USA
Joined Dec 1996
Looks great Gordon! Is it elevator only?
John
JohnM is offline Find More Posts by JohnM
Old Mar 27, 2011, 07:19 PM
Boston, Mass
Joined May 2001
No rudder, to save weight. Just delta wing tailerons instead. On the non-skeleton Toon Jet we've found we rarely use the rudder. So, I've skipped it on both skeleton Toon Jets.
Gordon
Old Mar 27, 2011, 08:14 PM
Boston, Mass
Joined May 2001
Some initial flights in my family room with my son indicate that we'll have to sort it out in a larger gym before flying it in our house. It's not a given yet that we can fly one with this low wing loading without a rudder. It's a work in process experiment and may require a version two with rudder.
Gordon
Old Mar 27, 2011, 08:25 PM
356Jim is offline
Find More Posts by 356Jim
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
Gordon
Gordon, stop it!!! I can't even start to keep up!!!
Just kidding. Push the envelope..................hard!!!
Just be careful of the cutting edge of technology. It's darned sharp!!!
356Jim is offline Find More Posts by 356Jim
Old Mar 28, 2011, 02:39 AM
cabman1969 is offline
Find More Posts by cabman1969
cabman1969's Avatar
Melbourne, Australia
Joined May 2008
Ouch!! Band-aid please!!!
cabman1969 is offline Find More Posts by cabman1969
Old Mar 28, 2011, 12:11 PM
fmhans is offline
Find More Posts by fmhans
Westbrook Maine
Joined Apr 2003
Looks great Gordon! That is an awsome design. What thickness depron are you using?
fmhans is offline Find More Posts by fmhans
Old Mar 28, 2011, 12:51 PM
Inari is offline
Find More Posts by Inari
Las Vegas Realtor
Inari's Avatar
Las Vegas
Joined Feb 2002
Looks "cute" (in all of the good connotations and none of the bad). I'm surprised you could get the CG to work out, I assume the battery is mounted all the way forward?
Inari is offline Find More Posts by Inari
Old Mar 28, 2011, 01:22 PM
Jim_Marconnet is offline
Find More Posts by Jim_Marconnet
Fly long and land softly
Jim_Marconnet's Avatar
Madison, Alabama USA
Joined Oct 2005
I Like It!
Great work, Gordon!
Jim
Jim_Marconnet is offline Find More Posts by Jim_Marconnet
Old Mar 28, 2011, 03:54 PM
Boston, Mass
Joined May 2001
Fritz,
It is all 3mm Depron.
Inari,
Well, the CG is a question at the moment. I know where the CG is on the 15-inch 40g all Depron version I made a year ago for my son. So, this one is designed to have the same CG, which is right under the brick. The battery is mounted just in front of the brick to achieve that CG, but can be adjusted most of the way forward on Dualock. Whether it will require a different CG from the solid Depron version I don't know at this point. Actually, the tail is so light I had to move the brick back to achieve this CG. The entire airframe with CF wing braces weighs about 5.5g, so it's pretty feathery light back there.
Jim,
Glad you like it. Now I just have to sort it out and figure out whether it can dispense with the rudder after all, what the CG is, etc.
Gordon
Old Mar 28, 2011, 03:56 PM
Inari is offline
Las Vegas Realtor
Inari's Avatar
Las Vegas
Joined Feb 2002
I really like it and i'm jealous!
Old Mar 29, 2011, 02:05 AM
Slider2732 is offline
Find More Posts by Slider2732
Storm Runner guy
Slider2732's Avatar
USA, OK, Muskogee
Joined Nov 2008
Great design, talk about wing area !
I'd imagine the left/right to be very crisp without rudder, because of the continuation of lift throughout the length there. As I understand things, while it's wide and thin from front to back, the rear will continue to lift through a turn and so tailerons 'should' be an efficient means of sidling around small areas.
Loops could well be fun...how did the heavier one fair ?
Broadly speaking, i'd think you could base flight on a Nutball or other large wing area model.
Anyhow..looking forward to video if you can and to the controls findings
Slider2732 is offline Find More Posts by Slider2732
Discussion Skeleton Toon Jet Gordon Johnson Scratchbuilt Indoor and Micro Models 19 Aug 17, 2012 09:08 PM
Build Log Toon Scale Vickers Vimy derk Scratchbuilt Indoor and Micro Models 12 Dec 30, 2010 03:42 PM
Video Toon Scale Vickers Vimy derk Electric Plane Talk 0 Dec 18, 2010 10:03 PM
Beta build of the Toon-E TooTall Parkflyers 31 Mar 08, 2004 12:31 AM
