Old Oct 23, 2012, 01:23 PM
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
Originally Posted by capt View Post
Anyone interested? I would take a pair for 30 +shipping.
http://www.ebay.com/itm/5x-MyVu-CRYS...item460905a38f
LOL - 100% useless if you have no dongle to the glasses.
as a backup if you already have glasses they work ok...luckily I have 2 dongles in working condition.
UndCon is offline Find More Posts by UndCon
Old Oct 23, 2012, 01:39 PM
capt's Avatar
Nevada, USA
Joined Sep 2007
OK, disregard then.
capt is offline Find More Posts by capt
Old Nov 07, 2012, 12:43 PM
Mexico, GTO, León
Joined Nov 2008
Originally Posted by vantasstic View Post
is yours still the hazing issue? You can send it to me, if you'd like, for a look see. I can try one of the resistors i use...they seem to work fine. Pm me and we can work out details.
i sent you a pm to see if i can send them to you i actually got a second pair taht i would not dare to make the mods maybe you can do them for me ?
cdenora is offline Find More Posts by cdenora
Old Nov 08, 2012, 12:30 PM
... where is it ?!
ro.bi.'s Avatar
United States, CA, SF
Joined Jul 2011
MyVu Crystal goggles w/ SunSky 1.2 vrx
my MyVu Crystal goggles don't work with the SunSky 1.2 vrx ?! I have 2 sets of goggles and both work w/the 5.8 receiver but not w/the 1280 one!? Sometimes I get an image in the first second but then it dissapears as if it lost the signal? So I don't think it's the connection ... Can it be that the voltage of the signal is incompatible or something? It works w/an external display screen I have ... What can it be?
ro.bi. is offline Find More Posts by ro.bi.
Old Nov 13, 2012, 07:06 AM
-plancks only-
Franck's Avatar
Pays Bas
Joined Oct 2001
Realized that i had a pair of myvu's with white haze syndrome lying about. Added a 21 Ohm resistor and did the static mod. Works nice....for couple of minutes...darn. Indeed it looks like a temperature/drift issue, but after reading this whole thread from beginning to end...i did not yet see actual measurements or analyses of what is really going wrong with these goggles, apart from that is has someting to do with the supply voltage to the LCD units. In my case they are : Kopin KD040922K-K 280206003-J-8514 labelled units. I looked for datasheets at kopins site, to no avail, but checked on same problems on LCD screens (washed out LCD)
It might just be a backlight issue.... if I only had schematics....
Lets assume that it is a backlight issue, IC for backlight is on the mainboard, L3509 wich is a booster IC for white leds. (with two outputs....hmmmm)
http://www.ti.com/product/LM3509
Hmm, lets do some measurements tonight, you never know
[edit] Hmm, not really i think....the wash is also visible at lower brightness settings/incluiding vertical striping ...hmmm so it appears to be no "overlighting" the LCD's....
Franck is offline Find More Posts by Franck
Old Nov 14, 2012, 04:27 PM
Joined Jan 2012
Great idea to start measurements in that direction.
My glasses are still producing the haze with resistor mod too.
Hope you will find a solution.
FalconXY is offline Find More Posts by FalconXY
Old Nov 17, 2012, 04:10 AM
-plancks only-
Franck's Avatar
Pays Bas
Joined Oct 2001
Ive been experimenting the led booster, but that component is ruled out. Now, is there someone with sharp eyes that can id other ic's on the unit. I just cant read the numbers even with a magnifying glass. I also send an email to support Kopin, if they have datasheets for the LCD's.
Does anyone tested the haze with temperature ? like putting the unit in the fridge for a while and measure how long(er) it takes for the haze to appear ?
I used to have cooling spray, with this you could very locally cool components to freezing point and identify temperature issues on pcb's
Old Nov 19, 2012, 04:54 PM
... where is it ?!
ro.bi.'s Avatar
Joined Jul 2011
Huuuuuge props to Vantasstic for working his magic on my goggles!
The MyVus now work w/my sunsky 1.2 vrx! Thank you!
Old Nov 20, 2012, 04:37 PM
Joined Jan 2012
That was exactly what I did too. I thought it must be a heat problem.
But there was absolutely no result in cooling the LCDs or PCBs down when the haze began.
Old Nov 20, 2012, 05:43 PM
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
The problem of the Myvu Crystal is not really overheating anything per se. It is the LCD screen going blank. LCDs are normally clear panels and when they receive a signal they darken to the desired brightness. For color LCDs the same thing is done, but on 3 different filters (which make up the matrix) at the same time (hence the R, G, and B signals) allowing the mixing of millions and millions of colours. Since the backlight is a pure white, as the LCD goes blank we get a pure white "haze."
I'm assuming that (stock) the matrices are pretty far overpowered, and they experience some sort of failure to the point that they can't properly handle the RGB signals.
In the original fixing Myvu post:
http://www.avsforum.com/t/1331583/my...wer-white-haze
The guy added pulldowns to the RGB lines, I'm assuming that this is to fix up the RGB signals which seem to experience some weird fluctuation when the matrices are at a lower voltage (which is why flicker happens when the resistors are too high of a value).
While this guy soldered the RGB lines in the glasses themselves, they are pretty easily accessible inside the pendant, so that's probably an easy way to eliminate flicker. With the flicker problem eliminated, there is no need to use extremely specific low value resistors to stop the white haze.
I've had the RGB pulldowns and matrix mod soldered in for a few months now, but I can't test it. I would test it so I could give some more concrete answers but all I have is two pendants (the carbon tracks on one of my LCDs came off for no apparent reason, it is unfixable). So if anyone has a pair of glasses please let me know! I NEED THEM!
PLEEEEEEEEAAAAAASSSSSSSSSSSSSSEEEEEEEEEEEEEEEEEEE! !! <-reduced to whining.
Legot is offline Find More Posts by Legot
Old Nov 21, 2012, 04:20 PM
Joined Jan 2012
Sounds interesting. I would like to see where the RGB signals are in the pendant.
To add resistors next to the LCDs is way to small for me to handle there.
So a better place in the pendant would be good. But I have not tried to follow the cables yet where they end in the pendant.
Old Nov 26, 2012, 11:25 AM
Zbig's Avatar
Warsaw, Poland
Joined Oct 2006
Today I've modified Myvu Crystal with white haze after several minutes.
But instead of trying different resistors I've put two diodes in series: one standard silicone one 100mA with 0,7V forward voltage and second 100mA shottky one with 0,35V forward voltage. After soldering it in a place of this small item (probably inductor - its resistance is 0 Ohm) ) voltage drops from 9.26V to 8.05V
and haze gone away on two lowest brightness levels, some flickering on two brightest levels.
Probably only one standard diode will be enough to drop approx 0,7V and screen will be with no haze on all brightness level, but owner was so happy and denied any further experiments.
Zbig is offline Find More Posts by Zbig
Old Nov 26, 2012, 04:38 PM
Joined Jan 2012
Thank you for your solution. But did you run the glasses long enough ?
On mine the reduction of the voltage removed the haze at first but it came later (after 15 minutes).
Maybe you have read my input voltage tests earlier. I have also tried to lower the voltage but it was not possible to keep the haze away.
Old Nov 27, 2012, 04:56 AM
Zbig's Avatar
Warsaw, Poland
Joined Oct 2006
We've checked it at maximum brightness for approx 15 minutes with no problem. Hope it will work well for long time with low brightness level (as it will be used at airfield).
In my opinion any modification (resistor or diode) just "bypass" serious design problem, not solved it :-(.
Old Nov 27, 2012, 08:28 AM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Bypass, fix, doesn't matter to me. As long as they work and don't haze up any more I'm happy. I only use mine as backups now, but they still are nice and compact to have around.
Vantasstic is offline Find More Posts by Vantasstic
Question myvu crystal can't see video rx! Ingo Video Piloting (FPV/RPV) 3 Oct 02, 2011 10:33 PM
Discussion .myvu solo plus ev fo fpv barok Video Piloting (FPV/RPV) 5 Feb 24, 2010 11:42 PM
Sold MyVu Shades for AP FPV beeker_12 Aircraft - General - Miscellaneous (FS/W) 3 Feb 06, 2010 06:05 PM
Alert Solo Plus Personal Media Viewer-$59.95 Big Gunz 45 Hot Online Deals 0 Apr 24, 2009 03:02 PM
Discussion Myvu Crystal for ipod - only ipod? BrianL Video Piloting (FPV/RPV) 7 Mar 22, 2009 11:53 AM
