Old Jun 03, 2011, 01:47 AM
thnilsen is online now
Find More Posts by thnilsen
thnilsen's Avatar
Norway, Hordaland, Os
Joined Nov 2004
Originally Posted by Gixxerdude View Post
I've purchased a 3.7 v lipo from the local hobbie store but can't figure out where the blue wire should connect on the battery. Any help much appreciated.
You will need to desolder the small electronic circuit that is attached to the orginal battery. If you take off the protective sellotape wrapped around the wires/circuit coming of the battery, you should then be able to unfold the circuit and desolder it from the existing battery.
Reverse the process on your new lipo and you should be good to go.
I hope that helps.
- Thomas
thnilsen is online now Find More Posts by thnilsen
Old Jun 03, 2011, 08:36 PM
Gixxerdude is offline
Find More Posts by Gixxerdude
Joined Jun 2011
I hope that helps.
- Thomas
Thomas ,
Thanks for the quick response and I'll give it a try. Do you happen to know what type of USB wall charger I should get 5v 1000 mAh?
Gixxerdude is offline Find More Posts by Gixxerdude
Old Jun 04, 2011, 06:02 AM
thnilsen's Avatar
Joined Nov 2004
I guess 5v 1000mah would work. A normal PC usb port delivers about 500mah and according to the Myvu documentation it takes twice as long to charge using a PC to charge as it does with a wall charger. So the 5v 1000mah should work fine.
- Thomas
Old Jun 04, 2011, 01:46 PM
volto is offline
Find More Posts by volto
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
I've been using my PC, no wonder it never seems fully charged. Although that could also have to do with my lipo being badly puffed. I charged it up @ 100ma from ~1v. I need to put a new battery in it, it's so puffed that the case will not even close all the way. I don't think I would risk putting this on a 1a charge.
volto is offline Find More Posts by volto
Old Jun 04, 2011, 04:52 PM
thnilsen's Avatar
Joined Nov 2004
I believe the charge circuit attached to the battery reduces the input. So even if you use a 5v 1000mah usb charger, the battery won't be charged with that input. A USB 2.0 port spec delivers 500mah and it takes up to 4 hours according to the manual to charge with this. So it's obvious that the internal circuit on the Myvu is doing something to control the input.
That's my theory anyway.
I charged mine up with a 100 mAh charge by connecting it directly to the lipo sidestepping the charge circuit on the battery.
- Thomas
Old Jun 05, 2011, 01:12 AM
volto is offline
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
I'm sure you're right. The battery is what, 200 mah, so for it to take 4 hours to charge, that means it is only delivering 50ma? 100ma is the lowest setting on my charger, maybe thats why I ruined the battery, but at less than 1v for a lipo, it was probably doomed anyway.
Old Jul 27, 2011, 03:48 PM
firebreather6969 is offline
Find More Posts by firebreather6969
Joined Jul 2011
Help
Hi all,
So after finding a broken pair on ebay for 17 I though what the heck! Batt was seperate so re soldered it on nothing, plugged it in to charge and solid orange light came on and then when you pressed the button the sloid blue light came on.
After reading this thread about 20 times I'm now stuck!! I have done every thing mentioned but now feel as though the "brains" are dead as even with it plugged in and av connected I STILL don't get any picture.
Any advice?
Thanks.
firebreather6969 is offline Find More Posts by firebreather6969
Old Jul 27, 2011, 09:22 PM
volto is offline
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
Originally Posted by firebreather6969 View Post
Hi all,
Any advice?
Thanks.
I see your problem, problem is you soldered it on nothing. You have to solder it to something.
Old Jul 28, 2011, 01:08 AM
volto is offline
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
On a serious note though firebreather, check the voltage of that battery, I wouldn't be surprised if it was well under 3v, in which case the internal charger won't even bother with charging it. I had to desolder it from the charging circuit, and hit it with 4.5v until the cell was over 3v, and then solder it back on. Then the charging circuit began charging it, it will blink orange when charging, solid orange when it's done.
Old Jul 31, 2011, 01:54 PM
thnilsen's Avatar
Joined Nov 2004
Solid blue light indicates that the unit is reading a valid AV signal. Could be that the goggles are damaged beyond what a new battery will fix.
- Thomas
Old Jul 31, 2011, 11:46 PM
volto is offline
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
I have a feeling he is getting solid blue/orange, not just blue. It looks kinda purple. Thats what I was getting when I tried to turn mine on when connected to the charger, before the battery was fixed.
Old Jul 31, 2011, 11:47 PM
volto is offline
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
BTW I have two pairs of myvu crystals, and I replaced the batteries with cells from a zippy 2s 500mah, they fit in the case nicely.
Old Aug 01, 2011, 01:59 AM
doggit is offline
Find More Posts by doggit
doggit's Avatar
northenden, manchester, england
Joined May 2009
what do you guys use to block the light from these, have you modded the ski mask or made some cover for them
carl
doggit is offline Find More Posts by doggit
Old Aug 01, 2011, 03:34 AM
volto is offline
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
Rob (fpvplastics) is developing a mask for the myvu crystal. http://www.rcgroups.com/forums/showp...&postcount=838
Old Aug 04, 2011, 02:24 PM
doggit is offline
doggit's Avatar
Joined May 2009
ok guys, anyone having trouble with their goggles, mine keeps loosing picture in the left screen, and also yesterday i was out and while flying my goggles were black and white, i checked my camera in my tv and it was full colour, so maybe my goggles have a fault
carl
Question myvu crystal can't see video rx! Ingo FPV Talk 3 Oct 02, 2011 11:33 PM
Discussion .myvu solo plus ev fo fpv barok FPV Talk 5 Feb 25, 2010 12:42 AM
Sold MyVu Shades for AP FPV beeker_12 Aircraft - General - Miscellaneous (FS/W) 3 Feb 06, 2010 07:05 PM
Alert Solo Plus Personal Media Viewer-$59.95 Big Gunz 45 Hot Online Deals 0 Apr 24, 2009 04:02 PM
Discussion Myvu Crystal for ipod - only ipod? Brian_ FPV Talk 7 Mar 22, 2009 12:53 PM
