Old Mar 27, 2011, 09:55 AM
hidaven is offline
Find More Posts by hidaven
United States, NJ, Roseland
Joined Apr 2009
How do you read these servo numbers?
Current Drain (4.8V) 6.0mA / 170mA
Current Drain (6.0V) 6.0mA / 200mA
Is the 6.0mA at idle and say 200mA at full power?
Also, is the mA mean milliamps per hour?
Thomas Edison
hidaven is offline Find More Posts by hidaven
Old Mar 27, 2011, 10:27 AM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
6.0mA is how much current the servo draws just sitting there (idle).
200mA is most likely how much it draws when it's moving at full speed freely through its range of motion. It'll draw a lot more if it's stalled (trying to move but unable because something's holding it).
200mA would be 1/5th of an amp. That's important to know for picking an ESC; most with built-in BEC units will only be able to supply 2-3A to the servos before they fry.
"mA" means milli-amps. One mA is equal to 1/1000th of an amp. It's the same as the current (amps) that your motor draws from your battery and ESC, but it's on a smaller scale. For our purposes, it has nothing to do with time.
"mAh" is milli-amp hours. That's a measure of how long something can supply a given current. A 1000mAh battery will supply 1000mA of current (1A) for an hour.
Piece is offline Find More Posts by Piece
Old Mar 27, 2011, 11:47 AM
hidaven is offline
Joined Apr 2009
TP, have a sailplane using 6 servos with the above specs. I want to use a 850mah LiFe rx pack. Will that be enough and what kind of runtimes can I expect?
If the servos use 6.0 mA amps just sitting there, what does that equal per hour? I figure the 2 flap servos will idle till landing.
Old Mar 27, 2011, 12:02 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
It doesn't equal anything per hour. 6.0mA is 6.0mA. The time gets involved when you have a limited supply of current. If you have a 6.0mAh battery, it can supply 6.0mA of current to the servos for one hour before dying.
If you have a 600mAh battery, it can supply those same 6mA for 100 hours before it's empty.
6 servos x 6mA = 36mA of idle draw (this will probably be a little more, though, because your control surfaces probably aren't mass-balanced so the servos will have to work to hold them in position against gravity).
So, ignoring any servo stresses, you're drawing 36mA off an 850mAh pack. That pack can supply 0.85A for an hour, and you're drawing 0.036A. Divide and you get about 23.6 hours of just sitting there.
Now let's assume all your servos are maxed out at 200mA. This means you've got a total draw of 1.2A..... 0.85/1.2 = 0.7 hours, or 42 minutes of full-draw runtime.
Old Mar 27, 2011, 12:03 PM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
You will want to have another pack on hand for a day's worth of flying, or at least your charger to top off the pack after a couple flights.
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Mar 27, 2011, 12:05 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
the mA = milliamp
Whats missing is the H = hour
What you originally typed..6mA actually is 6mAh
so 6mAh is 6 milliamps drawn per hour...at idle.
Wrong. Read my post
Old Mar 27, 2011, 12:22 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Can't give a definitive answer as it depends on just how often the servos move and the load on them. I also assume you do mean just a glider and not an electric powered glider.
But considering we used to fly IC powered models for quite a long time, (off and on for most of the day), on just a 500mAh 4.8v nicad, (, I don't think you would have any problems, unless you are into continuous aerobatics for a couple of hours.
Actually the transmitter battery would probably give up before the receiver battery.
At 6ma standing current, for 6 servos, that's 6 x 6mA per hour. 36mAh. But I bet you can't fly for an hour without waggling one of the sticks
So my answer would be, 'no problem', as long as you remember to charge the pack before going flying.
eflightray is offline Find More Posts by eflightray
Old Mar 27, 2011, 12:25 PM
hidaven is offline
Joined Apr 2009
Actually, if you can only run the LiFe's down to 25% or so you only have 75% of 850mAh
Cutting it a bit close. As Cry stated, better get another pack just to be on the safe side.
Actually, I can charge at 4c so a recharge should be what 10 min? : )
Eflighttray, it is an electric glider but im running a seperate LiFe rx pack for just the servos.
Old Mar 27, 2011, 12:31 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
TP16 gave a very good, and accurate explanation.
I'll just throw in that the unit of time in this system of measuring is the 'second'.
A servo using 6 mA of current is using .006 coulombs of electrons every second.
"Current' is a 'rate'.
Coulombs is the actual physical quantity.
It'll all become clear as soon as you can say out loud the following sentence, 10 times in a row, quickly....
"A box of biscuits, a box of mixed biscuits, and a bisquit mixer."
NoFlyZone is offline Find More Posts by NoFlyZone
Last edited by NoFlyZone; Mar 27, 2011 at 12:54 PM. Reason: Coulombs added to make it precise.
Reply With Quote  (Disabled)
Discussion How do you do these roll overs? KillerCut 3D Flying 37 Mar 25, 2011 12:33 PM
Discussion How do you tell if a PM has been read or not? Jonathan Ott Site Chat 4 Nov 28, 2010 07:23 AM
Discussion How the heck do you trim one of these things? Democritus Beginner Training Area (Aircraft-Electric) 21 Oct 26, 2010 10:12 PM
Discussion How do you read the spec for a servo? myp Electric Plane Talk 1 Apr 16, 2009 02:13 AM
Discussion How do you read motor numbers? SUPERSPORT Electric Plane Talk 8 Apr 02, 2008 11:12 AM
