Old May 21, 2012, 09:57 AM
gluemaster is offline
Find More Posts by gluemaster
Cub-O-Holic
gluemaster's Avatar
Deltona, FL
Joined Dec 2006
Simply stunning.
gluemaster is offline Find More Posts by gluemaster
Old Jun 02, 2012, 03:35 PM
Keith Pyrah is offline
Find More Posts by Keith Pyrah
Keith Pyrah's Avatar
Newport South Wales
Joined Jul 2008
We abandoned our proposed trip to a scale weekend due to the very bad weather forcast for Sunday. We decided to take the model to our own field for the maiden. the weaher was very murky with drizzle and rather miserable and the runway grass was wet and longer than we would like. We decided to go for it anyway.
First take off was a bit sluggish and at one point we experienced some elevator flutter on full power straight and level which stopped when Doug reduced power Doug had to hold in up elevator to keep her in the air so the first landing was not perfect but quite acceptable.
Doug retrimmed the all moving tailplane and off he went again, take off was still a bit sluggish we thought due to the drag from the wet grass but the flight was very smooth and she flew straight and level hands off. After two more take offs and landings we decided to call it a day because the weather was deteriating and the model was becoming difficult to see in the air.
Doug felt the model flew "heavy" so we carried out some detailed checks back at home and made some adjustments to the CogG. We also massbalanced the all moving tailplane by the insertion of 1/4" sleel bar just behind the leading edge which we hope will cure the flutter at full power straight and level.
A few pictures of the maiden below.
Keith Pyrah is offline Find More Posts by Keith Pyrah
Old Jun 02, 2012, 03:40 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Except for the first picture are you sure this wasn't the full scale plane?
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: 1/4 scale J-3 by Hangar 9
Old Jun 02, 2012, 03:55 PM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Congrats!
Thank you for sharing your build.
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Jun 02, 2012, 04:47 PM
jetcaptain is offline
Find More Posts by jetcaptain
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
Congratulations! What an astounding job you both have done.. It looks very real in the air.
jetcaptain is offline Find More Posts by jetcaptain
Old Jun 02, 2012, 05:06 PM
Sperling234 is offline
Find More Posts by Sperling234
Sperling234's Avatar
Los Angeles, Ca.
Joined Jun 2010
Wonderful!
Looks utterly convincing.
Great, great work!
Cheers,
Sperling
Sperling234 is offline Find More Posts by Sperling234
Latest blog entry: Raiders Wing from Scratch
Old Jun 02, 2012, 06:47 PM
supercubman is offline
Find More Posts by supercubman
supercubman's Avatar
Slaton, TX
Joined Oct 2008
Keith, as usual a magnificent job!!!
Trey
supercubman is offline Find More Posts by supercubman
Old Jun 02, 2012, 07:13 PM
the goon is offline
Find More Posts by the goon
boat butcher
the goon's Avatar
Whittier CA.
Joined Oct 2009
Think it's time for a wider taxi way . A truly fantastic model.
Mark
the goon is offline Find More Posts by the goon
Old Jun 11, 2012, 12:13 PM
Newport South Wales
Joined Jul 2008
We took the model down to our own field and carried out further trials.The change of CofG and the mass balancing of the all moving tailplane improved the handling considerably but Doug was still not quite happy with the horizontal stability. We found that the all moving tailplane did not reliably centre after up or down movements so trimming was inconsistent.
One of our club members who is very much into large 3D flying advised us that the Hitec 645 MG servo that we had on the tilplane would never reliably centre hence the unstable horizontal trim.
We are taking his advice and will fit a 15kg digital servo which should reliably centre every time.
We hope then to be able to set up a mix so that when flap is used some down elevator is applied to keep the model horizontal and not nose up when landing.
We found such a mix very helpfull with our third scale Cessna 182
Old Jun 11, 2012, 02:44 PM
Won2Race is offline
Find More Posts by Won2Race
Won2Race's Avatar
United States, MA, Boston
Joined Jun 2006
keith, just some friendly advice.
Generally, low wing aircraft require UP trim to compensate for flap deployment. High wing aircraft generally pitch up (requiring down elevator to compensate) because the center of drag moves upwards with flap deployment which in turn creates a nose up moment.
In contrast, low wing aircraft generally experience a net nose down moment because the center of drag moves downwards with flap deployment which necessitates up trim to compensate.
Of course, this is a rule of thumb and not applicable to every design.
Here is a good synopsis I found elsewhere:
Low wing, low tail aircraft (eg. B737)
When extending flap on these aircraft, two main things happen.
1. Center of lift moves back, creating a negative pitching moment
2. Drag increases BELOW the CoG creating a negative pitching moment
RESULT: Aircraft pitches DOWN
Low wing, high tail aircraft (eg. MD80)
High wing, low tail aircraft (eg. C172)
2. Downwash from the wing increases in angle over the stabilizer creating
a positive pitching moment.
3. Drag increases ABOVE the CoG creating a positive pitching moment
RESULT: Aircraft pitches UP
High wing, high tail aircraft (eg. Dash8)
2. Drag increases ABOVE the CoG creating a positive pitching moment
Won2Race is offline Find More Posts by Won2Race
Old Jun 12, 2012, 01:28 AM
Newport South Wales
Joined Jul 2008
UNDPRU
Very interesting and logical comment re flap deployment effects. We shall persue this and also ask James what the effect is on the full size.
Keith
Old Jun 12, 2012, 01:58 AM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
If I remember while flying the Piper Cruser that when the flaps were deployed, the plane would balloon a bit and the nose would drop....while the Arrow the nose would raise. But that was many years ago.....
Old Jun 13, 2012, 12:10 AM
sj3cub is offline
Find More Posts by sj3cub
North Carolina
Joined Sep 2003
Every full scale Cherokee I have flown, the nose pitches up when flaps are deployed.
sj3cub is offline Find More Posts by sj3cub
Old Jun 13, 2012, 08:13 PM
Won2Race is offline
Won2Race's Avatar
Joined Jun 2006
That's interesting because i found several discussions online regarding cherokees and their pitching down with flap deployment. Its quite possible that the set trim of the plane has an effect. The nose down effect on low wing low tail aircraft with flap deployment is an aerodynamic fact due to the changes in drag and lift centers.
Old Jun 14, 2012, 07:02 AM
Newport South Wales
Joined Jul 2008
James who pilots the full size G-BEYL has confirmed that when flaps are deployed the nose pitches up.
The model still seems to fly "heavy" so we are going to do some very detailed checks re CofG.
The full size manual shows a very wide range for the CofG so we are going to calculate the model using the same system of weighing and calculating then we can move CofG towards the forward limit which will make the model more responsive.
Discussion "MRC" 1976 Piper Cherokee Archer- To be Re-born sbrackets Scale Fuel Planes 21 Apr 07, 2014 03:37 PM
Sold Piper Cherokee C-ME-FLY Aircraft - Fuel - Airplanes (FS/W) 0 Sep 25, 2010 12:11 PM
Discussion Looking for scale Piper Cherokee Ottopilot Scale Fuel Planes 11 Sep 03, 2010 12:30 AM
For Sale Great Planes CHEROKEE ARCHER 40 w/Flaps Browndogbrew Aircraft - Fuel - Airplanes (FS/W) 0 Jun 03, 2008 11:35 AM
Idea ~1/9th scale Piper Cherokee aileron trainer stoneware Parkflyers 24 Apr 15, 2004 07:52 PM
