Old Mar 26, 2011, 04:25 PM
groovejet is offline
Find More Posts by groovejet
How many planes is too many?
groovejet's Avatar
Australia, VIC, Melbourne
Joined Aug 2007
New Product
Hokusei Sbach 342 EPP HV
This is latest addition to Hokusei's Hard Version (HV) lineup of stiff EPP planes. It's a nice-looking EPP Sbach with a slightly stretched fuselage for a little more precision.
Basic specs:
Wingspan : 1,200 mm
Length : 1,220 mm
Wing area : 33.6d ㎡
Flying weight : 945g (without batteries) 1,140 g (with battery)
Motor : Dualsky XM3542CA-6 KV940 or similar
Prop : HS13x7 (wood) ; depends on motor
ESC : Hobbywing PENTIUM-40A or similar
Battery : 3S 45C 11.1V 1,800 ~ 2,200 mA
Servos: Hyperion HP-DS11-AMB or Hyperion HP-DS13-TMB or Futaba S3156
More details here: http://www.hokusei-japan.com/product...ch-epp-hv.html
Hokusei Model Sbach342 EPP HV Flight Test1 (2 min 20 sec)
Hokusei Model Sbach342 EPP HV Flight Test2 (3 min 13 sec)
groovejet is offline Find More Posts by groovejet
Old Apr 01, 2011, 01:20 PM
QUEBRANTAHUESOS is offline
Find More Posts by QUEBRANTAHUESOS
QUEBRANTAHUESOS's Avatar
Mexico
Joined Jul 2007
Hey Groove thanks a lot for all the information that Sbach flies really great, it would be very nice to have her included on the fleet, but as far as I know is not simple to get her direct from Hokusei Japan, so I wonder if somebody knows another surce, perhaps with the good Feda?
regards from Mexico.
QUEBRANTAHUESOS is offline Find More Posts by QUEBRANTAHUESOS
Old May 16, 2012, 05:38 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
Got mine from f3aunlimited.com and maidened it yesterday with the following setup:
Omega 130g motor
Savox sh-0255 elevator servo and Hitec HS-65mg everywhere else
Xoar 14x7 wood prop
Gens Ace 3S 2200 mah lipo all the way forward to the firewall
With this setup, this plane was very floaty and made 3D flying seem like it was in slow motion, which isn't necessarily bad. It made practicing rolling harriers easier. However, for knife edge spins and tumbles, the 3DHS 48" EPP Extra 330 SC is a more responsive plane. Overall, it's a nice flying plane and is a good addition to the fleet.
Jboy90277 is offline Find More Posts by Jboy90277
Old May 24, 2012, 09:32 PM
Joined Dec 2011
Here's a pic of how the wings attach to the fuse.
Old May 25, 2012, 08:48 AM
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
Thanks for the pic. Are those wood screws? I don't guess it really matters.
It looks like a person could cut the center braces out and move them an inch in either direction to retain fuse strength. Then dremel slots into the wing mounts for hooks and use surgical tubing to lock them together. Removable wings, no tools required!
I
SD One. is offline Find More Posts by SD One.
Old May 25, 2012, 09:13 AM
Joined Dec 2011
I
I used servo screws to hold the wings down - thinking they should shear off in a hard enough crash. I think the wood cross members provide some strength to the fuse and/or wings - might not be able to cut them out. The fuse walls by the wing seem to be only EPP, unlike the 3DHS 330SC.
I'm thinking of using some 4mm plastic wing screws I got for my 3DHS buck huck and putting in blind nuts on the cross members. That will get rid of the need for tools and still hold the wings as the manufacturer intended.
Old May 25, 2012, 10:24 AM
SD One. is offline
USA, TN, Gallatin
Joined Aug 2009
Not ideal but that would work too. I wasn't sure the cross braces would be thick enough for blind nuts but another layer of ply glued underneath would fix that. Sucks about the side walls though. There's no way squeezing the wings together with surgical tubing would work if the walls don't have the strength to handle a bit of pressure.
Ahh well. I'll stick with my Sbach 39 BX and my Extra 330SC for now.
Old May 25, 2012, 10:35 AM
Joined Dec 2011
The Extra 330SC is all that I really needed, but I wanted a Thunderbolt scheme Sbach. I use the HV on the weekdays when I only have time to fly 1 or 2 planes, and use the 330SC on the weekends so I can get more planes in the 4Runner. I haven't taken HV apart since I buillt it.
Old Jun 12, 2012, 01:26 PM
Joined Dec 2011
Omega 130g motor
Xoar 14x7 wood prop
Did back to back flights to see the difference between the two in windy conditions. Although a little different, I really like the way both fly.
Hokusei 48" EPP Sbach 342 HV on windy day (5 min 12 sec)
Old Jun 12, 2012, 01:27 PM
Joined Dec 2011
http://www.youtube.com/watch?v=qSh9r_v3pjg
3DHS 48in EPP Extra 330SC (5 min 11 sec)
Build Log New EPP 42" Sbach 342 Build motorhead 3D Foamies 166 Feb 04, 2013 04:43 PM
New Product Hokusei Yak 55m And Primus EPP HV 3D Planes Get Real 3D Foamies 19 Jan 14, 2012 10:30 AM
Yippee! e-foamy sbach 342 maiden larsy87 3D Foamies 26 Nov 01, 2010 10:25 PM
Discussion sbach 342 at neat fair tee681 NEAT Fair 0 Sep 03, 2010 08:13 AM
Discussion Sbach 342 EPP scratchbuild! Video & Pics! mytmousemalibu Foamies (Scratchbuilt) 9 Feb 25, 2010 09:02 PM
