Old Dec 31, 2012, 11:56 PM
Heli Pad is online now
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Happy New Year to all my friends.
Heli Pad is online now Find More Posts by Heli Pad
Old Jan 01, 2013, 12:30 AM
leethetreeguy is offline
Find More Posts by leethetreeguy
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
Here is hoping that this year brings you all happiness and joy and prosperity. Cheers my friends.
Lee
leethetreeguy is offline Find More Posts by leethetreeguy
Old Jan 01, 2013, 07:13 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
Happy New Year to all of you!
Old Jan 01, 2013, 07:16 AM
BattleDude is offline
Find More Posts by BattleDude
High Plains Drifter...
BattleDude's Avatar
United States, WY, Fremont County
Joined Aug 2011
Originally Posted by wheelzup View Post
Wow!... Diodes and Doo Doo. I REALLY wish I hadn't brought it up.
On the contrary ole' boy, glad you did. Everything gets discussed here, including what you had for supper, and the general appearance of it, the next day!
BattleDude is offline Find More Posts by BattleDude
Old Jan 01, 2013, 07:17 AM
BattleDude's Avatar
Joined Aug 2011
Is it New Years allready? Man, time flies when we are having fun !!!
Or when we get old !
Old Jan 01, 2013, 10:26 AM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
I'm gonna risk it again... posing a question that is, not messin' with batteries! Please feel free to redirect to a different, more appropriate thread.
The Skywing is starting to get sluggish about halfway through a battery, well before the voltage becomes too low. First thing I notice is a sluggish or non-exsistant response to RH yaw with a corresponding drop in rpm (and altitude). When I land and let sit for a minute or two (cool down?) I get great lift and turn response in both directions. It sure seems like the continuous run time is causing it, suggesting heat. Possibly one of the motors going bad? I've double checked gear clearances and rotational efforts (back-driven by hand) seem smooth and ok.
Advise and thanks again for all your help and photographic contributions...
Feel both motors directly after landing. If one of the motors are very hot, you found the problem. It's highly unlikely both will be hot.
Mike.
Chap1012 is online now Find More Posts by Chap1012
Old Jan 01, 2013, 10:29 AM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Durk, I am waiting on a SD card reader to download a fix to my camera that is only two years old. The camera is over charging the battery...AARRGG. I take my pics/vids, then remove the battery for now
Mike.
Old Jan 01, 2013, 10:43 AM
Heli Pad's Avatar
Joined Aug 2011
Mike.
+1. Of course it is possible for a motor to good bad. But in the case of a coaxial when the two motors have to match speed, having one motor gone bad will be very very obvious, because the coaxial will be way out of shape. Is it possible for both motors to go bad at the same time at the same rate? Possible but very unlikely.
Therefore, I would attribute the sluggishness to the battery. I think the battery is not so healthy, and its internal resistance is building. When it is working on a load, the voltage drops faster than before, and the max current draw is limiting. But if you let it rest and cool off, when it is not under load, it bounces back up a little, until it is under load again, and it starts to fall rapidly after a short initial thrust. It's just my theory.
Old Jan 01, 2013, 11:35 AM
frieslander is offline
Find More Posts by frieslander
To Soar Like An Eagle!
frieslander's Avatar
Canada, ON, Woodstock
Joined Dec 2007
Mike.
Can you not just take the battery out to charge it? That is how my Canon cameras do it. The batteries last quite s long time between charges and I have spares.
I hope the firmware fix does the trick, no card reader on your PC?
frieslander is offline Find More Posts by frieslander
Old Jan 01, 2013, 12:24 PM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
The battery remains in the camera while charging via USB to PC or wall plug. Without the new "fix" if I leave the battery in the camera, it sucks the juice right out of it. I already sent two batteries back with zero voltage after leaving the battery in the camera. So, you see, it over charges and when left alone will draw the juice out.
No, my PC does not have a card reader. I never heard of that. I thought card readers were all external
Mike.
Old Jan 01, 2013, 01:34 PM
Heli Pad's Avatar
Joined Aug 2011
They have card readers on the desktop front panels, too. I use mine all the time.
Old Jan 01, 2013, 02:13 PM
Joined Dec 2007
I would be lost without a card reader in my PC's. Even my printer has a card reader that I can access from my PC's even over my wireless network.
Old Jan 01, 2013, 03:13 PM
Winder Ga
Joined Sep 2008
Poor Mike is still living in the 70's. ahahahahahaha
Lee
Old Jan 01, 2013, 07:16 PM
wheelzup is offline
Find More Posts by wheelzup
wheelzup's Avatar
Mid-MI (Lansing)
Joined Sep 2010
Mike & Heli,
Spot on Mike. Does anyone else hold stuff up to their lips to feel slight temp differences? No? Then never mind... I don't either. So, when I hold the heli up to my receptors (wink), the front motor definitely feels warmer than the rear. Sure enough, it would be responsible for increasing relative rotation for the "poor" rh turn performance. Moreover, that motor is surrounded by the battery and the canopy.
Experiment... removed canopy and it operated almost flawless through most of the batt. Did this enough to be repeatable, then re-installed canopy. Obvious and within 2 min of continuous flight, lh turns will allow climbs while rh turns sends to the ground.
Sounds like a motor change in my future?
Heli, power loss is dramatic only in rh turn. Will only climb with full left ail.
Thanks again.
wheelzup is offline Find More Posts by wheelzup
Old Jan 01, 2013, 07:29 PM
Heli Pad's Avatar
Joined Aug 2011
Okay, that does sound like a bad motor. Plan on replacing both of them at once. (Like you would replacing tires).
Discussion why is the "Why is the "Can anything be done about gas prices?" thread closed? 62pilot Life, The Universe, and Politics 24 Sep 19, 2012 12:28 AM
Discussion general 4ch Coax(and beyond) thread ... group to help ... REPRISE! erdnuckel2 Coaxial Helicopters 1711 Mar 18, 2011 05:37 PM
Mini-Review Multiplex Park Master 3d or talk about anything MPX PM3D shockflyyer3d Foamies (Kits) 4 Jun 26, 2009 07:51 PM
Discussion Why is the "Can anything be done about gas prices?" thread closed? lakedude Life, The Universe, and Politics 2 May 14, 2008 08:09 PM
Discussion Thread about anything 400-450 Dragonus doogie Mini Helis 4 Feb 04, 2007 02:46 AM
