Old Apr 03, 2012, 03:15 AM
CSG_EU is offline
Find More Posts by CSG_EU
Joined Apr 2011
Originally Posted by Nightwalker84 View Post
Canīt anybody help me ??
CSG you are the manufacturer...you canīt help me, too ?!
You need I2C address?
CSG_EU is offline Find More Posts by CSG_EU
Old Apr 03, 2012, 10:36 AM
Nightwalker84 is offline
Find More Posts by Nightwalker84
Joined Feb 2012
Yes, i need the correct addresses and can you tell me, why the acc z doesnt work correctly ? I doesnt have an address-jumper
Nightwalker84 is offline Find More Posts by Nightwalker84
Old Apr 03, 2012, 01:46 PM
leprud is offline
Find More Posts by leprud
Trying to learn.
leprud's Avatar
Moscow, Russia
Joined Jun 2010
Finally had time and hooked all-new 10dof with mpu6050 to arduino with llc. Multiwii was born
All works fine, and sometimes even excellent!
Great, thanks!
leprud is offline Find More Posts by leprud
Old Apr 11, 2012, 09:38 AM
Joined Feb 2012
Old Apr 11, 2012, 12:52 PM
CSG_EU is offline
Joined Apr 2011
An I2C compatible Display Data Channel (DDC) interface is available with LEA-6 and NEO-6 modules for serial communication. For more information about DDC implementation refer to the u-blox 6 Receiver Description including Protocol Specification [3]. Background information about the DDC interface is available in Appendix C.1. u-blox 6 GPS receivers normally run in I2C slave mode. Master Mode is only supported when external EEPROM is used to store configuration. No other nodes may be connected to the bus. In this case, the receiver attempts to establish presence of such a non-volatile memory component by writing and reading from a specific location. TX ready indicator (data ready) for LEA-6H (FW 7.01) see 1.7.6
The u-blox 6 DDC interface provides serial communication with u-blox LEON-G100/G200 wireless modules from version LEON-G100/G200-05S and above and LISA.
With u-blox 6, when reading the DDC internal register at address 0xFF (messages transmit buffer), the master must not set the reading address before every byte accessed as this could cause a faulty behavior. Since after every byte being read from register 0xFF the internal address counter is incremented by one saturating at 0xFF, subsequent reads can be performed continuously.
Old Apr 15, 2012, 04:13 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Great, thanks!
Where I can find DECLAREs for the 10dof with mpu6050 5883 5611, please ?
renatoa is online now Find More Posts by renatoa
Old Apr 16, 2012, 05:52 AM
leprud is offline
Trying to learn.
leprud's Avatar
Moscow, Russia
Joined Jun 2010
They are in define.h with separate sensors.
As usual, i must say
Old Apr 16, 2012, 03:37 PM
Joined Sep 2007
Ah, thought there is a version with "all in one" Because orientation is tricky...
Old May 05, 2012, 07:47 AM
bdb is offline
bdb
Find More Posts by bdb
bdb
Joined Jan 2012
Sensor init trouble
Hello! I am in trouble with All in ONE II MS
http://www.csgshop.com/product.php?id_product=40
Megapirateng not init(not see) a MS5611 on this board!!!
Can you provide me a right I2C address for this sensor???
Thank you!
bdb is offline Find More Posts by bdb
Old May 12, 2012, 08:05 PM
modellbaupongo is offline
Find More Posts by modellbaupongo
Joined Jun 2009
how can i use the ppm sum signal?
modellbaupongo is offline Find More Posts by modellbaupongo
Old Aug 01, 2012, 03:59 AM
Baggus is offline
Find More Posts by Baggus
Joined Jun 2010
I still see ppl soldering EEPROM to their ublox gps receivers, but there is no need for it!
I wrote this Arduino code to send the correct settings to the GPS receiver every time the flight controller (or i2c gps board) boots:
Code:
//rctimer CN-06 gps receiver
  delay(1000); //give the GPS receiver time to boot
  Serial.begin(9600);
  byte gps10hz[] = {0xB5,0x62,0x06,0x08,0x06,0x00,0x64,0x00,0x01,0x00,0x01,0x00,0x7A,0x12,0xB5,0x62,0x06,0x08,0x00,0x00,0x0E,0x30};
  Serial.write(gps10hz,22);
  delay(500); //give the GPS receiver time to process
  byte baudrate57600[] = {0xB5,0x62,0x06,0x00,0x14,0x00,0x01,0x00,0x00,0x00,0xD0,0x08,0x00,0x00,0x00,0xE1,0x00,0x00,0x07,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0xE2,0xE1,0xB5,0x62,0x06,0x00,0x01,0x00,0x01,0x08,0x22};
  Serial.write(baudrate57600,37);
  Serial.end();
It will set the refresh to 10Hz, message type to NMEA and the baudrate to 57600 by sending UBX CFG messages to the ublox gps receiver.
I had already posted it here:
https://code.google.com/p/i2c-gps-na...es/detail?id=4
But doubt anyone has seen it.
ps. Q: Why no higher baudrate? A: 57600 is more than high enough, higher baudrate = more errors.
Baggus is offline Find More Posts by Baggus
Old Aug 19, 2012, 11:17 AM
claustro is offline
Find More Posts by claustro
Joined Aug 2011
Hi guys ,
I have a IMU 10DOF ALLINONE IMU ITG3050 HMC5883L BMA180 MS5611 sensor board 5V LLC from csgshop
there isn't this imu on config.h of multiwii 2.1 there is an ALLINONE imu 9d0f but with BMP085 instead of mine MS5611.
with this setting the quad fly well only in acro and in stable, obviously no alt hold mode. In the wingui the alt si always at -120.
I sent a message and he answered to me to solder the jumper but without specify which one .
I tried to change in def.h #if defined(ALLINONE) changing BMP085 with MS5611 worked but after a new reflash now it doesn't work anymore maybe I changed an i2c address that now I can't remember.
any idea?
Thank you
Andrea
claustro is offline Find More Posts by claustro
Old Aug 20, 2012, 07:04 PM
claustro is offline
Joined Aug 2011
Ok solved
soldered the last jumper on the left one on the photo ( maybe vcc) and with I2c scanner I optained
I2C device found at address 0x1E !
I2C device found at address 0x41 !
I2C device found at address 0x68 !
I2C device found at address 0x77 !
done
changed sensor and ports on multiwii firmware and now it works.
Sold Two NIB CMOS Board Cameras 420 TVL 3.6mm lens (Only one left!) bah7566 FPV Equipment (FS/W) 0 Feb 10, 2011 04:49 AM
For Sale: PHA 01 All in one board skeppley Aircraft - Electric - Helis (FS/W) 3 Sep 10, 2004 09:33 AM
I need an all in one board for a feda dragonfly zoom boy Micro Helis 11 Aug 13, 2004 11:56 AM
Feda All-in-one board problem Chris07 Micro Helis 2 Nov 23, 2003 09:35 AM
Feda all in one board repairs Yukonho Micro Helis 7 Oct 08, 2003 05:22 PM
