Old Dec 30, 2011, 04:49 PM
Wilkas is online now
Find More Posts by Wilkas
Vilnius, Lithuania
Joined Feb 2011
All-in-one with GPS. Is it correct?
Some time ago I bought controller ALLINONE II with GPS: http://www.ebay.com/itm/HMC5883L-BMA...item3cba059182
Now I found time to test it. Connect it to Arduino Mega, load software MultiWiiConf_dev_20111220. All seems to work more or less normal. I only have couple of questions: counter Debug2 is counting errors. Not many, but after 5 min. of working there are 500 -1000 errors.
And second question: while controller lies on the table (GPS antenna outside), distance from home is increasing - after 5 min. of work - more than 50 meters.
Is it normal? What I should check?
There is short video how it looks:
All-in-one with GPS test (1 min 24 sec)
Errors appearing when GPS enabled in software and GPS RX ir connected to Arduino RX2 (pin 17). When GPS disabled and nothing connected to pin17 no errors.
Wilkas is online now Find More Posts by Wilkas
Old Jan 02, 2012, 04:43 PM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
If I want to get the sensor board to use with paris v4, where would VDD on the sensor board go to? In paris v3 it goes to D12, would it go to the one labelled pin 12 for paris v4?
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Jan 09, 2012, 06:43 PM
Flyingflow is offline
Find More Posts by Flyingflow
has built nothing yet
Flyingflow's Avatar
Joined Mar 2011
Another Allinone Acc problem
Hi all,
I purchased the Allinone board with HMC5883L, ITG3200, BMA180 BMP085 a year ago. Now that I finally get to try it, I get no response from the accelerometer, the rest is fine.
There has been talk about setting the I2C-address, but I can't find that in the current code (20111220). The sample code posted by csg_eu some posts ago gives a compiler error.
Any ideas, anyone?
By the way, I have soldered the jumpers.
Regards,
Flow
Flyingflow is offline Find More Posts by Flyingflow
Old Jan 10, 2012, 03:14 AM
Flyingflow's Avatar
Joined Mar 2011
Hi again,
I found it: In def.h in the if-clause
#if defined(ALLINONE)
i added:
#define BMA180_ADDRESS 0x82
Now everything is fine!
Old Jan 31, 2012, 07:37 AM
cestb is offline
Find More Posts by cestb
France, Pays de la Loire, Carquefou
Joined Mar 2009
Hi, i have the same problem with accls. Allinone works perfectly with Megapirate code but accls didn't work with multiwii (gyro, baro and compass seem ok).
I've tried to define bma address without success.
Should i solder something more than with MP code ?
cestb is offline Find More Posts by cestb
Old Jan 31, 2012, 03:28 PM
cestb is offline
Joined Mar 2009
Its ok now, i've modified the if !#defined bma180_address
Old Mar 07, 2012, 03:26 PM
ted33 is offline
Find More Posts by ted33
ted33's Avatar
Joined Mar 2012
Originally Posted by CSG_EU View Post
You need this pin
+5V
GND
SDA
SCL
GPS rx
GPS tx
Hi
i have received my allinone II board
I'm research the pinout
thanks
ted33 is offline Find More Posts by ted33
Old Mar 08, 2012, 06:30 AM
CSG_EU is offline
Find More Posts by CSG_EU
Joined Apr 2011
Originally Posted by ted33 View Post
Hi
is it possible completed picture ?
thanks
Did you have 3.3 or 5V logic version?
CSG_EU is offline Find More Posts by CSG_EU
Old Mar 08, 2012, 06:44 AM
ted33 is offline
ted33's Avatar
Joined Mar 2012
hi,
this version is 5v
Old Mar 08, 2012, 03:16 PM
CSG_EU is offline
Joined Apr 2011
hi,
this version is 5v
Please write me PM with your email
Old Mar 12, 2012, 12:06 PM
Nightwalker84 is offline
Find More Posts by Nightwalker84
Joined Feb 2012
Can anybody tell me the gps i2c-adress from the All in ONE II MS ?
Nightwalker84 is offline Find More Posts by Nightwalker84
Old Mar 12, 2012, 02:21 PM
CSG_EU is offline
Joined Apr 2011
What sensors?
Old Mar 12, 2012, 05:14 PM
Joined Feb 2012
its an u-blox neo-6Q
Old Mar 23, 2012, 01:44 PM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
CSG_EU, please, can you list all your IMUs sold on your site and for each the software supporting it ?
Or, more exactly, which of your IMU works with ArduCopter 2.5 ?
You are replying very slow on eBay, or via your site Contact page, maybe here I get a faster reply. Because I want to buy !
renatoa is online now Find More Posts by renatoa
Old Mar 25, 2012, 10:42 AM
CSG_EU is offline
Joined Apr 2011
ArduCopter have other sensors and you need make code porting.
Sold Two NIB CMOS Board Cameras 420 TVL 3.6mm lens (Only one left!) bah7566 FPV Equipment (FS/W) 0 Feb 10, 2011 05:49 AM
For Sale: PHA 01 All in one board skeppley Aircraft - Electric - Helis (FS/W) 3 Sep 10, 2004 10:33 AM
I need an all in one board for a feda dragonfly zoom boy Micro Helis 11 Aug 13, 2004 12:56 PM
Feda All-in-one board problem Chris07 Micro Helis 2 Nov 23, 2003 10:35 AM
Feda all in one board repairs Yukonho Micro Helis 7 Oct 08, 2003 06:22 PM
