Old Jul 16, 2011, 07:02 AM
fax8 is offline
Find More Posts by fax8
Fabio Varesano
fax8's Avatar
Torino, Italy
Joined Jan 2011
@ignacvosahlo I've seen similar errors while trying to compile for a MEGA arduino while the real board was a Duemilanove/UNO/Promini compatible. You may need to adjust the following in config.h:
#define PROMINI //Arduino type
//#define MEGA
fax8 is offline Find More Posts by fax8
Old Jul 18, 2011, 03:04 PM
fr3d-nexus is offline
Find More Posts by fr3d-nexus
fr3d-nexus's Avatar
France (near the ch'ti village)
Joined Apr 2007
fr3d flyduino megapirate B8 allinone
I'm waiting my allinone 5v with llc, and I'm searching how to connect it with a flyduino (without llc) with the megapirate code's B8
--I must solder to ground following this picture :
--following this orientation :
--for the wires I will step over the flydusense on this picture
soldering directly wires following thoses colors.
Is it correct ?
did I missed something ?
greetings.
fr3d-nexus is offline Find More Posts by fr3d-nexus
Old Jul 18, 2011, 04:00 PM
CSG_EU is offline
Find More Posts by CSG_EU
Joined Apr 2011
Wires correct
CSG_EU is offline Find More Posts by CSG_EU
Old Jul 19, 2011, 08:23 AM
tigar is offline
Find More Posts by tigar
tigar's Avatar
Athens, Greece
Joined Sep 2001
Shouldn't the pads on the imu be soldered? They don't look like they are on the picture...
tigar is offline Find More Posts by tigar
Old Jul 19, 2011, 08:51 AM
weazel is offline
Find More Posts by weazel
Deutschland, BY, Schweinfurt
Joined Feb 2011
edited...
correct connection:
http://www.rcgroups.com/forums/showp...&postcount=587
weazel is offline Find More Posts by weazel
Old Jul 19, 2011, 10:56 AM
Gaza07 is offline
Find More Posts by Gaza07
Gaza07's Avatar
United Kingdom, England, Nottingham
Joined Nov 2002
Yes the pads have to be soldered and they are now, that is a picture of my flyduino and allinone, although im sure its the middle and bottom pad near the baro and not middle and top, you can see this in the diagram below, I have flown this setup with several versions of multiwii dev with no problems, but I have problems with the mega pirate code the x and y of the gyro and accel seem to be mixed up im getting y accel with x gyro and visa versa in the raw sensor view and no one seems to be able to tell me why
Gaza07 is offline Find More Posts by Gaza07
Old Jul 19, 2011, 03:10 PM
CSG_EU is offline
Joined Apr 2011
Originally Posted by weazel View Post
Is this correct? Or have the 3 solder pads at the bottom to be connected together?
3 pin jumper I2C address for ITG3200
Old Jul 20, 2011, 03:49 AM
tigar is offline
tigar's Avatar
Athens, Greece
Joined Sep 2001
What exactly do you mean? I have to solder all 3 pads? Does it make a difference in the code? (different pads+ different address?)
Old Jul 20, 2011, 02:27 PM
AlexnderH is offline
Find More Posts by AlexnderH
AlexnderH's Avatar
Joined Dec 2006
Am i being stupid....or is it possible to connect all of this together without mounting to a circuit board?
AlexnderH is offline Find More Posts by AlexnderH
Old Jul 20, 2011, 02:30 PM
Gaza07 is offline
Gaza07's Avatar
Joined Nov 2002
No your not being stupid you can go direct to the flyduino from the llc version of the allinone I just put it on the flydusense because I needed some where to stick it
As can be seen in the picture the flydusense board is the version with no llc
Old Jul 20, 2011, 03:35 PM
AlexnderH's Avatar
Joined Dec 2006
I meant without using flyduino, just using the 5V all in one and the arduino mini pro. Is that possible?
Old Jul 20, 2011, 03:58 PM
Gaza07 is offline
Gaza07's Avatar
Joined Nov 2002
Sorry I miss understood what you meant, Ive had my allinone connected to a pro mini on a paris v3 sheild and it worked fine running the multiwii dev code
Old Jul 20, 2011, 04:16 PM
AlexnderH's Avatar
Joined Dec 2006
Is a shield such as the paris v3 required? Or is it there just to make things neater?
I have an 5V all in one on its way and already have an arduino pro mini. I have everything to program the arduino, but do i need a shield? I was under the impression from the multiwii site that wires can be jumped from the arduino straight to the all in one (wmp is used on their site though)
Old Jul 20, 2011, 04:17 PM
AlexnderH's Avatar
Joined Dec 2006
by the way, sorry for the hijacking
Old Jul 20, 2011, 04:29 PM
CSG_EU is offline
Joined Apr 2011
5V All in ONE have LLC and you can connect directly to flyduino.
About jumper;
2 wire jumper solder together
3 wire jumper solder central pad to GND pad
Sold Two NIB CMOS Board Cameras 420 TVL 3.6mm lens (Only one left!) bah7566 FPV Equipment (FS/W) 0 Feb 10, 2011 04:49 AM
For Sale: PHA 01 All in one board skeppley Aircraft - Electric - Helis (FS/W) 3 Sep 10, 2004 09:33 AM
I need an all in one board for a feda dragonfly zoom boy Micro Helis 11 Aug 13, 2004 11:56 AM
Feda All-in-one board problem Chris07 Micro Helis 2 Nov 23, 2003 09:35 AM
Feda all in one board repairs Yukonho Micro Helis 7 Oct 08, 2003 05:22 PM
