Espritmodel.com Heli Air
Old Mar 26, 2011, 06:15 AM
Italia, Emilia Romagna, Modena
Joined Mar 2009
ALLINONE THREAD------allinone--allinone MCU--allinone II
ALLINONE II
HMC5883L Triple Axis Magnetometer
BMA180 Triple Axis Accelerometer
BMP085 Barometric Pressure Sensor
ITG3200 Triple-Axis Digital-Output Gyro
NEO-6Q Ublox GPS receiver
Dimensions 55x16mm
ALLINONE + MCU
http://stores.ebay.it/Special-RF-des...=p4634.c0.m322
"All In One +MCU I add arduino to All In One board and connectors for ESC, RX, LCD, FTDI usb board and servo control. Great for MultiWii copter or other Arduino code. Board size 25x30mm" csg_eu
ALLINONE BOARD.
(NEW WITH LLC)
this PCB includes the best sensor for our multicopter:
-HMC5883 Triple Axis Magnetometer
-BMA180 Triple Axis Accelerometer
-BMP085 Barometric Pressure Sensor
-ITG3200 Triple-Axis Digital-Output Gyro
Build in ultra low noise linear LDO voltage regulator.
I2C all sensors connected to I2C bus 5V with LLC
LLC PINOUT
http://www.rcgroups.com/forums/showa...6&d=1302773848
...at a special price of 99$ for now...
the board will work with multiwii code if (thanks pipersw):
- change the BMA180 address to 0x82 in the code
- solder to GND the AD0 pin of the ITG3200
- solder CLK to GND
-NEW change this code(in serial.pde):
#define MAG_ORIENTATION(X, Y, Z) {magADC[ROLL] = X; magADC[PITCH] = Y; magADC[YAW] = Z;}
to
#define MAG_ORIENTATION(X, Y, Z) {magADC[ROLL] = -Y; magADC[PITCH] = X; magADC[YAW] = Z;}
you can purchase it at:
http://stores.ebay.com/Special-RF-de...=p4634.c0.m322
or contact CSG_EU
MULTIWII + ALLINONE. COMPASS WORK PERFECTLY
MULTIWII + ALLINONE. COMPASS WORKS PERFECTLY (0 min 48 sec)
VIDEO TEST OF ALLINONE BOARD(ACRO+STABLE+BARO+COMPASS):
MULTIWII + ALLINONE (4 min 2 sec)
FIRST VIDEO OF ALLINONE BOARD ON MULTIWII GUI
Sensor board test (0 min 28 sec)
FIRST FLIGHT OF ALLIONE BOARD ON MULTIWII (ONLY GYRO AND ACC)
http://www.youtube.com/watch?v=U50au58KV2o
arnaldo26 is offline Find More Posts by arnaldo26
Old Mar 26, 2011, 06:28 AM
I'm new here
timecop's Avatar
Joined Dec 2010
Sweet, while FreeIMU guys are sitting with their fingers up their butt, an enterprising Chinaman steals the spotlight.
timecop is online now Find More Posts by timecop
Old Mar 26, 2011, 06:30 AM
Joined Mar 2009
NOt chinaman.....germanman!!!!!!
Old Mar 26, 2011, 06:46 AM
Wingfan
South Germany
Joined Jul 2006
da ist ja wirklich alles drauf, aber:
Missing a 328P!
Or what else are all waiting for
@arnaldo
Kumpel hat eine arduino microplatine nur mit dem itg3200 und einem ACC gemacht.
Wo kann man sowas bestücken lassen, also Serie kleiner 50 Platinen?
gruss
roland
suarez is offline Find More Posts by suarez
Old Mar 26, 2011, 06:51 AM
Joined Mar 2009
Missing a 328P!
@arnaldo
gruss
roland
i'm not german...and i'm not the seller...I'm just making public the availability of this board
Old Mar 26, 2011, 09:03 AM
rimshotcopter's Avatar
Joined Aug 2009
Wow, Nice.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Mar 26, 2011, 09:21 AM
Registerer Used
milouze's Avatar
Paris
Joined May 2010
Which code is used to drive it?
Seems interesting...
milouze is offline Find More Posts by milouze
Old Mar 26, 2011, 09:22 AM
I'm new here
timecop's Avatar
Joined Dec 2010
Same design problems as Jussy's stuff though, no I2C level shifter, so not-so-5v-friendly.
Hopefully 5883 on THAT board actually works, too.
Old Mar 26, 2011, 09:57 AM
Joined Mar 2009
you can use it with all projects that work with these sensors...like multiwii...
Old Mar 26, 2011, 10:08 AM
AutoQuad Team
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Missing a 328P!
@arnaldo
gruss
roland
This is an I2C sensor board. You need a flight controller to attach it.
Try Seeedstudio for a prototype fabrication.
kinderkram is offline Find More Posts by kinderkram
Old Mar 26, 2011, 10:10 AM
AutoQuad Team
kinderkram's Avatar
Joined Jun 2010
Did you already try & fly it?
I wouldn't buy an item that I didn't see airborne.
Old Mar 26, 2011, 10:17 AM
I'm new here
timecop's Avatar
Joined Dec 2010
As opposed to buying an item that's been in beta for exactly 3 months and still haven't managed to start full/proper production??
Old Mar 26, 2011, 10:21 AM
Joined Mar 2009
i hope i will receive one of these as soon as possible and i will inform you!
Old Mar 26, 2011, 11:37 AM
AutoQuad Team
kinderkram's Avatar
Joined Jun 2010
Ok, thx!
Old Mar 26, 2011, 12:53 PM
France, Ile-de-France, Fresnes
Joined Jan 2011
I have order one on Ebay, need only a voltage level converter.
pipersw is offline Find More Posts by pipersw
Last edited by pipersw; Mar 27, 2011 at 09:57 AM. Reason: post corrected after have seen the author is not the seller
Sold Two NIB CMOS Board Cameras 420 TVL 3.6mm lens (Only one left!) bah7566 FPV/RPV - Equipment and Vehicles (FS/W) 0 Feb 10, 2011 04:49 AM
For Sale: PHA 01 All in one board skeppley Aircraft - Electric - Helis (FS/W) 3 Sep 10, 2004 09:33 AM
I need an all in one board for a feda dragonfly zoom boy Micro Helis 11 Aug 13, 2004 11:56 AM
Feda All-in-one board problem Chris07 Micro Helis 2 Nov 23, 2003 09:35 AM
Feda all in one board repairs Yukonho Micro Helis 7 Oct 08, 2003 05:22 PM
