Old Mar 25, 2011, 10:52 AM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
9503 Setup questions
Hey Guys,
Just want to make sure I'm doing it the best way.
I'm using the jr 9 channel rx and a 9503 radio.
I have a 4 servo wing and 2 elevator servos (split).
Aux3 is mated to aileron.
Aux2 is mated to elevator
Aux4 is mixed with Aux1 in mix 5(Flaps)
Gear port is used for gear
Rudder is used for rudder
Everything seems to be working fine however I don't like the fact you can't mate aux4. What's the deal with that?
Thanks for the help
Ben
tulz43 is offline Find More Posts by tulz43
Old Mar 26, 2011, 09:46 AM
Zeeb is offline
Find More Posts by Zeeb
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
Four servo wing, is it dual servos per aileron or something like a stick with flaps and ailerons?
There is a mix for the stick type programming to get the "crow" working, but there is no native mix/support for a dual servo per aileron mix. It can be done, but there is no trim on one side. Most guys are using either matchboxes or PE's if that's what you want to set up?
Zeeb is offline Find More Posts by Zeeb
Old Mar 26, 2011, 01:32 PM
tulz43 is offline
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Sorry about that. Each wing has a flap and an aileron.
Old Mar 26, 2011, 04:27 PM
AWorrest is offline
Find More Posts by AWorrest
Lincoln, NE
Joined May 2005
Ben,
Take a look at the article"Programming Guide for the JR XP9303 for the Hangar 9 Ultra Stick" found at: http://www.horizonhobby.com/ProdInfo...rogramming.pdf
You could have more versatility if you had mated the flaps together rather than mixing them. By mating them, you would have a common trim which mixing will not afford and you could have used them as ailerons. AUX4 is not mate-able and has not been since the 9303 was introduced. Use that channel for the retracts and use the GEAR channel for mating. One other thing, when a primary channel is mated with AUX3, you have an extra trim option. (This is also true for the FLAP channel when it is inhibited and mated to another channel.)
Allan
AWorrest is offline Find More Posts by AWorrest
Old Mar 27, 2011, 02:57 AM
tulz43 is offline
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Awesome! Thanks Allan. Don't know why I didn't think of that.
Discussion 9503 setup help Mtspawn Radios 1 Feb 24, 2011 10:12 AM
Help! MPLX FUNJET Setup Questions! Justin Mosher Foamies (Kits) 4 Nov 29, 2010 01:09 PM
For Sale JR 9503 Transmitter beach1 Aircraft - Sailplanes (FS/W) 3 Sep 02, 2010 06:24 PM
Discussion JR 9503 questions! Svensson Radios 1 Aug 28, 2010 02:50 PM
Discussion Throttle hold setup for 9303 0r 9503? bhoges17 Radios 12 Mar 26, 2010 05:41 PM
