Sri Lanka
Joined Mar 2010
What radio gear from Hobby King for a 20 inch (40 cm) Cessna 180 type model?
I have been looking for radio gear for a first model,
For example this model: http://www.rcgroups.com/forums/showthread.php?t=841748 http://www.hobbyking.com/hobbyking/s...idProduct=9042 So far I have located the following on the Hobby King web site: TX and RX HobbyKing 2.4Ghz 6Ch Tx & Rx V2 (Mode 2)(THROTTLE ON THE LEFT) Servos: Hobby King 3.7g / .4kg / .10sec Micro Servo What battery ESC and motor should I use?
GWS 5030 or 6030 prop Plush 6A ESC 350/360 2S battery |
Sri Lanka
Joined Mar 2010
Thanks but I need more specifics. Is this ok?
C1818 Micro brushless Outrunner 3500kv (9g) $9.99 9g http://www.hobbyking.com/hobbyking/s...idProduct=5377 TURNIGY Plush 10amp 9gram Speed Controller http://www.hobbyking.com/hobbyking/s...idProduct=4204 GWS prop GWS EP Propeller (DD-5030 127x76mm) (6pcs/set) http://www.hobbyking.com/hobbyking/s...dProduct=10033 Rhino 360mAh 2S 7.4v 20C Lipoly Pack http://www.hobbyking.com/hobbyking/s...idProduct=7301 |
Sri Lanka
Joined Mar 2010
20 inch, 50 cm careless again, sorry
UNGN, thanks for the updated links, nice motor and esc, nice price Just to confirm the charger: http://www.hobbyking.com/hobbyking/s...idProduct=7637 I can use my own dc adapter? Any concerns about the quality of the DC output - noise, voltage fluctuations etc? |
I use a DC power supply from an external hard drive. As long as you don't try to charge batteries at an Amp-hr rate greater than the power supply, you'll be fine.
This is only a concern with really large batteries. |
Latest blog entry: AR6400 guillows Space Shuttle
Sri Lanka
Joined Mar 2010
Thanks. The Hobby King receiver weighs 13g according to this:
http://www.rc-radiocontrol.com/hobby...eceiver-6ch-v2 Whatever I get, weight has to be within the ranges specified below for trainers. Or I could calculate wing cubic loading of a model that flies slowly enough. The Cessna 170 at the bottom of the page weighs in at 86g and has a span of 24 inches. Assuming a wing area of 24 x 4 = 96 inches and the weight of 3 ounces, plugging it into the calculator below gives a cubic loading of 5.5 and wing loading of 4.5 oz per sq in / 13.5 oz per sq dm and it flies slowly. Keeping this cubic loading for my model should give the same sort of slow flight. Cubic wing loading calculator http://www.ef-uk.net/data/wcl.htm |
| Thread Tools | |
| Build Log Cessna 180 from Paul Bradleys Model Airplane Plans Page | knlever | Free Flight | 29 | Jun 19, 2012 03:55 PM |
| For Sale orange rx from hobby king and orange satilite from hobby king | ZEROSKIN76 | Aircraft - General - Radio Equipment (FS/W) | 8 | Mar 15, 2011 01:41 PM |
| Sold orange rx from hobby king and orange satilite from hobby king | ZEROSKIN76 | Aircraft - General - Radio Equipment (FS/W) | 4 | Feb 21, 2011 12:06 PM |
| Sold Skyartec Cessna 182 RTF w/ JR SX600 Computer 10-Model Radio & Lipos | Sammy70 | Aircraft - Electric - Airplanes (FS/W) | 3 | Oct 25, 2010 11:19 AM |
| Help! what motors for the executive jet from hobby lobby? | ED3 | Electric Ducted Fan Jet Talk | 5 | Sep 13, 2010 02:50 PM |
