Joined Mar 2011
is this one a basket case then? |
Check the crystals in both the tank and transmitter, reinsert them. The power LED on the transmitter is lit right?
Latest blog entry: Making a Super Sized Frankenquad
Basically remove and reinsert.......without ordering a second set, which is actually cheap, or putting yours in a known-good setup, there's no other way to check them.
Sudbury ON Canada
Joined Nov 2009
Did you check if your crystals are matching ???
For example ; if you have a " 03 TX " on your transmitter ; you need a " 03 RX " in the tank ( you access the crystal by removing the battery cover ) .. I would check that before opening the tank ![]()
Good point, kind of take it for granted they should match and that the tanks would be bench-tested before leaving the factory.
| Thread Tools | |
| Question Pershing/Snow Leopard | Devildog | RC Tanks | 37 | Feb 24, 2011 11:15 PM |
| Help! Heng Long Leopard 2 A5 1:24 | loosebruce | RC Tanks | 3 | Nov 29, 2010 10:12 PM |
| Discussion Heng Long Tanks | MacGuy | RC Tanks | 3 | Nov 09, 2010 10:53 AM |
| Discussion Heng Long Snow Leopard 1/16th | mikesndbs | RC Tanks | 25 | Jul 16, 2010 07:02 PM |
| Discussion Heng Long tank more realistic start-up | strmnd54 | RC Tanks | 4 | Mar 13, 2010 05:59 PM |
