Old Mar 25, 2011, 08:49 AM
billbolz is offline
Find More Posts by billbolz
Brazil Indiana
Joined Sep 2010
Chargers and parallel charging
What connectors do I need to charge two 4000 mah 4 cell lipos on a cellpro 10 charger? How do you use channel one and two, and what kind of adapter do I need? How does the parallel connectors work and can I ge tone to charge the two batteries mentioned above?
billbolz is offline Find More Posts by billbolz
Old Mar 25, 2011, 09:28 AM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
That charger is designed to charge 2 batteries as-is without any special setup for parallel charging. Is the goal to charge multiple on each port? I think you will run low on watts pretty quickly especially if you are doing 2C or greater charge rates.
Do you have the manual for the charger? If not, you can find it here:
http://www.fmadirect.com/downloads.htm
Dave H. is offline Find More Posts by Dave H.
Old Mar 25, 2011, 09:41 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Just a friendly little note that Cell Pro 10 works well charging two LiPolys (one on each output) as long as they are the same capacity and discharged the same amount as when used in parallel or series however if they are used seperately and not discharged evenly charging can take a very long time. When the first one reaches the CV stage and the rate is reduced the rate is also reduced for the other battery.
A couple of perhaps helpful post. I got tired of looking for my mis matched packs charge that took forever and a day.
http://www.rcgroups.com/forums/showp...&postcount=381
http://www.rcgroups.com/forums/showp...&postcount=372
Charles
Old Mar 25, 2011, 09:48 AM
Dave H. is offline
Joined Feb 2008
Yeah, when I do my morning charge I check all the batteries and group them by similar charge levels. For the ones going on the Cellpros it's for speed and for the ones going on the iChargers with parallel cables, it's to be gentle on the batteries.
Old Apr 06, 2011, 05:05 PM
billbolz is offline
Brazil Indiana
Joined Sep 2010
charging two lipos cellpro 10
No I don't want to charge more than two batteries at the same time but I have another dumb question: The adapters I have for the cellpro 10 are the same. I also picked one up for Thunderpower lipos. The two adapters have different ports, channel one and channel two, for the data clips. How do I set this up to charge two skylipos 4000 mah 4 cell batteries on channel one and channel two at the same time when they have the same connectors?
Old Apr 07, 2011, 08:11 AM
Hughes500Bob is offline
Find More Posts by Hughes500Bob
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
http://www.tjinguytech.com/charging-how-tos
^^^^ This should help you.
Bob
Hughes500Bob is offline Find More Posts by Hughes500Bob
Discussion Can I use this adapter for parallel charging in 206B? avt Batteries and Chargers 5 Oct 29, 2010 03:14 PM
Discussion Parallel Charging is GREAT! jygwkuo Batteries and Chargers 4 Oct 21, 2010 09:46 PM
New Product parallel charging board‏ warbirdguyn951 Batteries and Chargers 43 Oct 13, 2010 03:03 AM
Data Parallel battery charging current test 4Dim Batteries and Chargers 25 Oct 02, 2010 02:07 PM
Sold parallel charge and balance cables for charging up to 6 lipos at once ff954 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 27, 2010 11:09 AM
