Old Apr 18, 2011, 07:20 AM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
UHF TX module voltage?
Was reading the manual for this while I wait for it to get here and saw something a bit puzzling.
Transmitter power suply range is 8.4-16V
When the voltage is less than 8.4V may result in decreased output power
Recommended to use three large-capacity lithium battery
I am having to modify the TX I am using for this module, (T9X) to provide power on pin #4 and most modules are using voltages in the 6v range. I may have to e-mail the maker for an answer but if 8.4-16v is accurate then I will need to put more than 6v on that pin?
I am also wondering if there is anyone that has any idea why this systems' receiver is labeled "18 CH UHF Receiver"? I hope it means daisy chaining them like the Sombra Labs receivers to get full 18 channel output.
Anyone got any more in depth info?
Rob
camship is offline Find More Posts by camship
Old Apr 18, 2011, 09:54 AM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
Rob
I did not notice that info
So it`s NOT plug`n play into my Futaba radio after all??
liteglow is offline Find More Posts by liteglow
Old Apr 18, 2011, 10:05 AM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
I have a futaba 10cap that I power with a 3 cell lipo. Rmilec lrs is plug and play with it. No problems running at high power.
bracky72 is offline Find More Posts by bracky72
Old Apr 18, 2011, 11:45 AM
camship is offline
camship's Avatar
Joined Oct 2001
Power for module
Just looked at the latest documentation I can find and the first few pages deal with the power supply voltage output from your TX to the module.
The first one in the list is the 10C and it shows 12v output on the power pin and the same for several others. Further down it shows illustrations of modifications to power supply of the TX to handle the increase in current properly. All basicly show a direct connection to the radio battery.
4047 UHF System Concise Manual 2
Well OK then, 12 volts it is.
Rob
Old Apr 18, 2011, 12:00 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
If using a standard NiMH battery pack then it's never really 12V, but 11.x dropping down
to about 8.8 at the low voltage alarm. As long as the RmileC module has it's own regulator that
can maintain full output power down to input voltage of 8.4V it should be fine in the likes of the 10C, 9C etc.
You have to be careful using a 3S LiPo in a TX. Some of them have linear regulators
that can burn out when you're supplying a full 12.6V hot off the charger.
ian
Daemon is online now Find More Posts by Daemon
Old Apr 18, 2011, 12:21 PM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
9x Pin OUT:
1 = Modulation Signal - PPM
2 = +4.13V
3 = +Vcc
4 = Gnd
5 = RF output
rmilec should be using 1, 3, and 4
so it gets 11v with a 3s lipo from pin 3.
its plug and play as far as i know.
wallaguest1 is offline Find More Posts by wallaguest1
Old Apr 18, 2011, 12:36 PM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
What is the purpose of pin 2?
In a JR radio it is 6V
renatoa is offline Find More Posts by renatoa
Old Apr 18, 2011, 01:41 PM
Joined Nov 2006
RENATOA i don't know, but that's the main problem if the turnigy 9x if you want use a JR module on it, you must provide 6v on the pin 2 so it work properly.
I wonder in what the hell FlySky engineers were thinking about when they made the design...
Old Apr 18, 2011, 03:49 PM
liteglow is offline
Joined May 2005
ahh.. it`s plug`n play after all
great!!
Old Apr 18, 2011, 04:02 PM
renatoa is offline
Joined Sep 2007
JR was designed this way, it needs 6V on that pin to operate, but... wth will ever use a genuine FM module in this radio ?!!!
Because the 2.4GHz modules no more use that pin !!!
Old Apr 20, 2011, 03:39 PM
camship is offline
camship's Avatar
Joined Oct 2001
Figures
Wonderful. Got my Module and receiver. Popped the module in and, nothing.
Absolutely nothing.
Hmm, wait, I have NO VOLTAGE on any pin but the signal pin. Open the case up and what do we find? Broken bits, pc board ripped from moorings and a screw, loose inside the case and a burned component smell.
Oh, nice, it looks as if someone stomped on the box with it inside. The module housing is pushed in and there are cracks all around the module socket that are only visible with the cover removed and looking at the inside.
Well, so I got a smashed radio and nothing to be done. I have had it in my possession for a few weeks already. I'll dig around and see what's burned up.
Guess it will be someone else that gets to tell you guys how well they work and if they are really compatible with the T9X. I got to get a new transmitter.
Later,
Rob
Old Apr 21, 2011, 12:10 AM
redsonic is offline
Find More Posts by redsonic
Expert
Joined Mar 2007
Hello Cam!
Please post photos of module inside!
Much thx!
redsonic is offline Find More Posts by redsonic
Old Apr 21, 2011, 04:06 AM
spitfire_Doug is offline
Find More Posts by spitfire_Doug
spitfire_Doug's Avatar
Australia, WA, Carlisle North
Joined Jul 2008
Absolutely nothing.
Later,
Rob
Hi Rob,
That sucks man, I thought It was bad when hobbyking didn't put everything in my order . I have the Eurgle 9x from r2hobbies,
http://www.r2hobbies.com/eng/proddet...ps2805003_mode
Which I liked because it doesn't have native 2.4Ghz. Also works with the JR synth modules so there shouldn't be any problem with the Rmilec 433 LRS.
Regards
Doug
spitfire_Doug is offline Find More Posts by spitfire_Doug
Old Apr 21, 2011, 06:46 AM
camship is offline
camship's Avatar
Joined Oct 2001
Oh What Fun!
Thanks Doug!
I was looking for a good replacement. I am using the ER9X firmware. I really like it so far from what I have seen of it's operation. Way better than the original supplied by Turnigy.
Strangely the TX still thinks everything is fine and is for all observation working correctly, just no output on the power pins, weird. I suppose I could "Hotwire" it and make it work. I have some lm78xx's I could use but I really would be uncomfortable using it for anything other than junker work.
Hope everyone else is having better fortunes with their systems.
I saw an update on the RMILEC website that mentioned that only Futaba modules are a true "drop-in" and that any other TX will need to be rewired to supply proper power. Kick me! I have Futaba radios everywhere! and a JR style module I bought for the T9X, AAAAAHH!
Isn't that nice? Guess they had some feedback from a few other folks that are having issues.
Have a great day all and keep 'em AGL!
Rob
Old Apr 21, 2011, 04:51 PM
liteglow is offline
Joined May 2005
I have mine in about 6 days
Wanted WTB - BevRC/RmileC 2.4Ghz LRS control system Daemon FPV Equipment (FS/W) 5 Nov 18, 2011 10:21 AM
Sold [VDS]LRS thomas scherrer UHF + 2 receivers long range LTS49 FPV Equipment (FS/W) 8 Jul 22, 2011 03:55 PM
Question UHF LRS Pro Antenna Question CageHound FPV Talk 4 Apr 04, 2010 09:47 AM
Discussion For Sale: Spektrum DX7 for use with UHF/LRS jeff1068 FPV Talk 0 Mar 31, 2010 07:24 PM
Discussion Scherrer UHF LRS x Futaba 12FG/R6014FS Cr_Conrado FPV Talk 2 Dec 20, 2009 07:35 AM
