Old Jun 01, 2011, 07:51 AM
KiloOne is offline
Find More Posts by KiloOne
Dale
KiloOne's Avatar
Joined Jul 2004
Nelapaty,
No static wicks, I have a lot of hours in sailplanes with very sensitive computers and instruments on board and static buildup has never been a concern.
JBAZ4,
Nope, have never seen Airy-plane.
KiloOne is offline Find More Posts by KiloOne
Old Jun 01, 2011, 08:54 AM
KiloOne is offline
Dale
KiloOne's Avatar
Joined Jul 2004
Flight test report #1
On Sunday May 29th I flew the electric Lazair for a total of about 38 minutes of air time and about 7 minutes of pre flight taxi testing and test hops. There were 4 flights of circuit length or longer. After the testing I charged the batteries and determined that I had used 75% of their capacity during the testing.
Much of the time was spent at very high throttle settings.
Unfortunately, the display I have chosen for viewing of electric system parameters has proven unreliable so far in the field. Only one engine display seemed to be providing usable information most of the time (not all of the time). This contributed to the fact that I overheated both motors sometime in the flight testing. At the end of the last flight, the motors were still performing reasonably well but during most of the actual flying I was battling with what appeared to be an overheating problem at high power levels. In addition, both of the log files of the testing had little usable information in them.
Upon inspection after the last flight, I noticed what appeared to be solder spray that had landed on some stator windings of both motors. After disassembling both motors I found that the Y node of the WYE wound motor windings had overheated and the solder from the node had melted and migrated out, onto the windings. Although the node was still mechanically sound because I had wrapped the joint with fine stands of wire while I was soldering it, the overheated joint was a likely source of additional heating. I was lucky that the joint did not completely fail and destroy my motor controller again.
In hindsight I should not have buried this soldered Y node deep inside the motor windings, the hottest section of the motor. Currently I am beginning the rewinding process on both motors again but this significant delay in testing has forced me to cancel my cross country plans. I still hope to be able to fly the plane at Oshkosh.
Needless to say, I will terminate all 6 of the winding ends outside the stator area this time.
Here are some pictures:
Old Jun 01, 2011, 09:57 AM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
simply awesome!!!
keithy4129 is offline Find More Posts by keithy4129
Old Jun 01, 2011, 10:21 AM
JBAZ4 is offline
Find More Posts by JBAZ4
Joined Aug 2010
Congratulations Dale!!!
Very happy to hear that you had a safe Maiden! Keep up the good work!
JB
ps: I have one of these motors on the way from HK for a 35% Extra 260! I think it should handle my 30# plane!
JBAZ4 is offline Find More Posts by JBAZ4
Old Jun 01, 2011, 10:48 AM
Helno is offline
Find More Posts by Helno
Canada, ON, Kincardine
Joined Feb 2009
Congratulations on the test flights. To bad about the motors getting cooked.
Is that an eagletree sensor you are using for power data? I wonder if you are getting unusual results because the sensor is resting directly over another power lead.
Helno is offline Find More Posts by Helno
Old Jun 01, 2011, 11:29 AM
Malle is offline
Find More Posts by Malle
Malle
Joined Mar 2011
oh man how coool is that it fly :-):-)
Malle is offline Find More Posts by Malle
Old Jun 01, 2011, 04:27 PM
Nelapaty is online now
Find More Posts by Nelapaty
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
Nice...
Nelapaty is online now Find More Posts by Nelapaty
Old Jun 01, 2011, 06:05 PM
philthyy is offline
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
AWESOME! That is so cool that it is up and flying (even with setbacks). Keep us updated!
philthyy is offline Find More Posts by philthyy
Old Jun 01, 2011, 07:21 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
That, my friend, takes skill... Amazing! :d
Park_aviator is offline Find More Posts by Park_aviator
Old Jun 01, 2011, 07:22 PM
3D, 1D at a time!
Joined Aug 2010
Skill, and a lot more guts than I have
Old Jun 01, 2011, 07:42 PM
mauimart is offline
Find More Posts by mauimart
Joined Jul 2008
Congratulations on your first flight. The fact that you accomplished this milestone with relatively inexpensive RC components is amazing. BTW, did you upgrade the bearings in the motors when you did the rewind, or are they stock? Perhaps some of the excess heat is coming from poor quality bearings. The Turnigy C80100 motors have a reputation for sub-par bearings.
mauimart is offline Find More Posts by mauimart
Old Jun 01, 2011, 07:52 PM
KiloOne is offline
Dale
KiloOne's Avatar
Joined Jul 2004
Thanks everyone!
Helno,
Good observation, my first thoughts were similar to yours but I figured that this logger was made to be in proximity to power wires. Also, the power panel display was not registering even with no motor running. I will still investigate this further as a potential reason that the logged data was corrupt, but still with no motor running the logged data was bad.
mauimart,
All the bearings in this motor appear to be good quality, the large bearing is a Japanese NSK and the 4 small bearings are Thailand NMB. They are definitely precision bearings. I think HK does try to respond to quality issues over time.
Old Jun 01, 2011, 09:51 PM
JBAZ4 is offline
Joined Aug 2010
Dale, just read up on re-winding motors. Do you think it is necessary to rewind these motors. I understand what you are trying to do withe wye term.
Also, I known that the Lazair is your creation, but are there any other UL craft you would consider electrifying (looking for suggestions). I too would want a twin but the only other twins I have found were the Hummingbird and Kolb Flyer (pusher).
I also have been considering stacking the motors in a contra rotating fashion on a single engine UL, ever given that any thought?
JB
Old Jun 01, 2011, 11:41 PM
redgreen is offline
Find More Posts by redgreen
Joined Apr 2007
Joby Motors
They have a nice motor that would work well with this project.
www.jobyrobotics.com
redgreen is offline Find More Posts by redgreen
Old Jun 02, 2011, 07:12 AM
KiloOne is offline
Dale
KiloOne's Avatar
Joined Jul 2004
Redgreen,
I came across these motors about a month ago but didn't want to commit to another motor at that time. Now is the perfect time to switch over. I believe that the inrunner design of the Joby motor and larger diameter will help provide the solution to my stator cooling problems for long periods of high power use.
I have just ordered two JM1S 70 motors. There was 1 in stock so I hope to receive it soon and the next will take 2 to 6 weeks (I am hoping for 2 weeks).
I also have two sets of wood props (34x20s and 36x20s) from my Lazair development days that should be a good starting point for these motors.
Thanks for posting, I am very excited about these motors.
Dale
Discussion Large scale electric build (~1/6 scale) stona Large Scale Cars 1 Feb 01, 2011 08:06 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline 3D Flying 38 Oct 25, 2010 11:16 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline Giant Electric Planes 1 Sep 10, 2010 03:46 AM
For Sale Electric Monster Motor! Tunigy 80-100-B-130 Kv Outrunner!! Nogahyde Aircraft - Electric - Power Systems (FS/W) 1 Sep 02, 2010 11:45 AM
