Old May 11, 2011, 03:03 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
The FMA PowerLab8 is an 8S charger rated up to 1344W/40A output.
When you connect packs in parallel the charger simply sees it as a single pack with larger capacity cells. Hence an 8S1P 2000mAh connected in parallel to another identical pack forms an 8S2P 4000mAh pack. The charger has no trouble charging and balancing that pack.
This is a good place to go to learn about parallel charging lithium packs: http://www.rcgroups.com/forums/showthread.php?t=932319
As I understand it, in this project the battery is formed from 4S 5000mAh packs. These are connected in series to form 8S 5Ah packs. Those are connected in parallel to form 8S4P 20Ah packs. Those are connected in series to form a 16S4P 20Ah pack for flight or in parallel to form an 8S8P 40Ah pack for charging.
The PL8 can charge an 8S pack at 40A, so yes, it can charge an 8S8P 40Ah pack at 1C and as a result, each of the individual 4S 5Ah packs will indeed be charged at 1C.
kgfly is offline Find More Posts by kgfly
Old May 11, 2011, 07:51 AM
KiloOne is offline
Find More Posts by KiloOne
Dale
KiloOne's Avatar
Joined Jul 2004
Thanks kgfly and well said.
Re: Balancing leads
All balance wire schemes have wires that connect to series connected cells (ie - +- +- +- + where - + is a cell) as follows: The lowest potential wire will connect to the - on the far left, the highest potential wire to to + on the far right and there will be wires of increasing potential connected to each of the +- cell nodes from the left to the right. The large power output leads will also be connected to the far left - and the far right +.
The difference between various brands and their balance schemes will be the physical type of balance connector used and in which pins these balance wires are connected to. However, no matter which brand and connector, all it takes to figure out the scheme is a simple probing with a DVM looking for the lowest potential wire and then the wires of increasing potential.
Re: Charger connection
Each charger is totally independent of the others. The final fully charged voltage of each 64 cell battery pack will be the same for each charger as long as the same charging parameters (presets) are used on each charger. For each motor, this allows me to combine each of the three 64 cell 16s4p battery packs in parallel (without much connection current cross feed) to end up with one large 16s12p 60ah pack that connects to the motors' speed controller. As the number of cycles on a pack goes up and the likelihood of a cell failure rises, I will be able to isolate the bad cell to a particular group of 8 cells that get parallel charged together based on the fact that I am controlling each charger from its USB cable and logging each charge that I do. Thus a I will be able to look at the graphs and see the voltage degradation of a group of 8 cells. Once a problem is seen I can quickly unplug those 8 cells from the PCB and quickly isolate and replace the weak cell/4s pack. I do not expect this to happen very often, if ever, in the 300 or so cycles I expect to get out of my packs before they are down to 75% or so of their original capacity.
Re: Capacitors
Yes I have 6 pcs of 75v 470uf low ESR caps on each PCB. These hopefully take care of the inductance of all the wire/traces in the battery pack and the length of wire I will have between the batteries and the controller. Have a look at this thread for some more info: http://www.rcgroups.com/forums/showt...ending+battery . I have had to add some connectors and pushbuttons to each PCB to take care of spark suppression when connecting the final output connector, series jumper and charging harness due to these capacitors. These pushbuttons and resistor jumpers will force the voltage of the caps to either 0v, 30v or 60v just prior to the connection I am about to make, thereby reducing the connection spark to a minimum.
Good questions.
Dale
KiloOne is offline Find More Posts by KiloOne
Old May 11, 2011, 12:26 PM
andypag is offline
Find More Posts by andypag
Joined May 2011
Thanks guys, that's given me plenty more homework and research areas to get familiar with. I expect I'll be back later in my development and learning process with more questions if you don't mind. I'll be following your progress in the meantime. Is there a website?
Andy
andypag is offline Find More Posts by andypag
Old May 11, 2011, 07:00 PM
kgfly is offline
Joined May 2006
This website provides an excellent tool to visualise how cells and packs are connected in various series/parallel configurations: http://scriptasylum.com/rc_speed/lipo.html
Old May 25, 2011, 06:26 AM
KiloOne is offline
Dale
KiloOne's Avatar
Joined Jul 2004
Quick Update
Been working hard on the project.
Expect to have first flight this weekend if all goes well.
Here are a few pics.
Dale
Old May 25, 2011, 07:35 AM
jointer is offline
Find More Posts by jointer
Czech Republic, Hlavní město Praha, Prague
Joined Oct 2010
Great project.
Just a note - the PL8 chargers can be "networked" as far as i know, so you can connect them together and charge directly as 16S.
It should be in the manual (i do not own PL8, but i know that).
jointer is offline Find More Posts by jointer
Old May 25, 2011, 06:08 PM
Helno is online now
Find More Posts by Helno
Canada, ON, Kincardine
Joined Feb 2009
That looks great Dale. How much has this motor change affected the CG? the rotax 185 must weight alot more than this electric motor.
Helno is online now Find More Posts by Helno
Old May 25, 2011, 11:01 PM
KiloOne is offline
Dale
KiloOne's Avatar
Joined Jul 2004
Jointer,
If I charged at 16s with 2 PL8's I think I would have to buy 6 more chargers to charge the 6 packs I have, but then again they would charge twice as fast and I would need four 6800 watt generators to charge them instead of two.
Helno,
The CG will change very little. Remember the 35 lbs of fuel and tank etc is no longer behind the pilot. This makes up for the reduction in motor weight and I have placed the batteries very close to the CG.
I just finished the first engine nacelle and the second is ready to assemble, here are some pics:
Old May 26, 2011, 02:28 AM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
I may be out of line here but the only inherent problem I have run across with charging with parallel balance connectors is that there is no way for the charger to recognize a broken or disconnected balance lead on any one or more of the packs.I puffed a cell on a pack that had a broken lead at the cell.
This happened to me with relatively small(3S 2200mah) packs while I was charging 4 of them in parallel.Seems to me that it could be a much larger potential liability if this happened using much larger collections of packs.
I considered it may be possible to build a parallel balance conector that could recognize one or more cells missed from the equation due to a broken lead or bad connection and terminate the charge process.All of the chargers I know of dont care if a cell is missing as long as the value for the specific cell set is within the correct value range.It has no way of knowing if all of the cells are actually connected in the set.
Just a thought.
aerocal is offline Find More Posts by aerocal
Old May 26, 2011, 09:52 AM
kgfly is offline
Joined May 2006
Since the packs are semi-permanently mounted and the balance leads are not being constantly handled and plugged in/out, I think the risk of a broken balance wire is vastly reduced compared to normal RC usage. If the connections all check out before and after assembly then they should be reliable IMO.
Old May 26, 2011, 11:58 AM
Helno is online now
Joined Feb 2009
Those motors look great. You should see if Hobbyking will sponsor you to cover some of the costs.
Old May 26, 2011, 08:13 PM
KiloOne is offline
Dale
KiloOne's Avatar
Joined Jul 2004
Aerocal,
Having 96 4s packs on board I can not think of a way to charge them economically without parallel charging. In addition to kgfly's comments, the individual 4s packs balance connector will never be touched during a normal charge cycle. I think I am doing pretty good using 6 PL8's to their maximum and have only 8 cells in parallel. I will be logging all my charge and discharges and should be able to isolate cell problems down to 8 cell resolution and when I suspect a problem I can simple unplug all those 8 cells to quickly identify the culprit.
Helno,
Sponsors come with their own set of drawbacks and I just want to be free to do this without worrying about sponsor commitments. It would be nice though if HK would sell the motor with my winding configuration. I am not sure I want to rewind any more of these.
Today's pic:
Old May 26, 2011, 08:31 PM
Nelapaty is online now
Find More Posts by Nelapaty
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
Dale,
Just out of curiosity Have you given any thought about static electricity with everything being electric power?
How are you protecting the packs and electronics from static
Are you using static wicks on your aircraft..
Nelapaty is online now Find More Posts by Nelapaty
Old May 31, 2011, 10:16 AM
JBAZ4 is offline
Find More Posts by JBAZ4
Joined Aug 2010
Awesome project Dale! Did you get a chance to Maiden?
Have you ever seen Staib's "Airy-Plane"? I could not find much info on it. I think it was circa 1967.
JB
Humble admirer
JBAZ4 is offline Find More Posts by JBAZ4
Old May 31, 2011, 10:23 AM
realtimerecon is online now
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
WOW Dale, am I glad i found this thread.Best of luck to you.Will be keeping an eye on this
realtimerecon is online now Find More Posts by realtimerecon
Discussion Large scale electric build (~1/6 scale) stona Large Scale Cars 1 Feb 01, 2011 08:06 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline 3D Flying 38 Oct 25, 2010 11:16 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline Giant Electric Planes 1 Sep 10, 2010 03:46 AM
For Sale Electric Monster Motor! Tunigy 80-100-B-130 Kv Outrunner!! Nogahyde Aircraft - Electric - Power Systems (FS/W) 1 Sep 02, 2010 11:45 AM
