Old Nov 21, 2012, 11:18 PM
sunworksco is offline
Find More Posts by sunworksco
BabyBootLegger
sunworksco's Avatar
United States, CA, Alameda
Joined Nov 2010
Looks like an Astroflight motor. I'm planning to use one on a submarine piston ballast tank. Great motor.
Giovanni
sunworksco is offline Find More Posts by sunworksco
Old Dec 03, 2012, 10:40 AM
KiloOne is offline
Find More Posts by KiloOne
Dale Kramer
KiloOne's Avatar
United States, NY, Hammondsport
Joined Jul 2004
Originally Posted by Mike Freas View Post
Did you sell all the PL8's?
I have one gang of 3 PL8's left with their power supplies (see pic in this thread)
Anyone interested, make an offer.
Dale
KiloOne is offline Find More Posts by KiloOne
Old Dec 03, 2012, 10:47 AM
KiloOne is offline
Dale Kramer
KiloOne's Avatar
Joined Jul 2004
Originally Posted by Ron van Sommeren View Post
Kontronik Kosmik controllers
  • 5-14 Lipo, 20-59 V
  • 200 A continuous current
  • BEC 7 A cont. current
  • 200 g without cable
Programmable reverse, very handy for taxiing
More info
www.kontronik.com
I like this, especially the bolted connectors (and reverse!).
Wish I still had the resources to try four.
Dale
Old Dec 03, 2012, 10:57 AM
KiloOne is offline
Dale Kramer
KiloOne's Avatar
Joined Jul 2004
December 2012 Udate
Not much going on now, in fact I have not been able to do anything since Oshkosh.
I have had to concentrate on other business ventures that actually bring in money.
Since I am still the only one working on this and no investors have surfaced, it looks like things will still progress slowly.
If I was to go back working on this full time again I estimate another 6 months till I have the electronics where I would be happy with them.
The biggest problem I need to solve is to have a reliable mosfet power switch that I can control with a 5v signal and which switches up to 300 amps at 50v. I am lacking experience on this and I welcome input from anyone with a solid solution for this.
I hope to take the Oshkosh plane down to Texas this winter yet for further flight testing.
Dale
Old Dec 03, 2012, 05:20 PM
Tail Spin1 is offline
Find More Posts by Tail Spin1
Zach
Illinois
Joined Feb 2004
Dale
If the mosfets are part of your BMS you may check with a solar racing team. Some of them such as the University of Michigan build their own BMS and may be able to help. We are all in the same boat when it comes to the BMS.
I've been looking into the PL-8 for use in charging the batteries in our solar powered car. Unfortunately we can't afford to buy one.
The current plan for charging our lipos is to connect them directly to a variable power supply. My gut feeling is that this is going to end badly.
Zach
Tail Spin1 is offline Find More Posts by Tail Spin1
Old Dec 08, 2012, 02:43 AM
bobc0 is offline
Find More Posts by bobc0
Joined Dec 2011
You may struggle to find a big enough single MOSFET to meet your needs. However for an on/off switch application there's no problem paralleling (they share current nicely when paralleled & there are no 2nd breakdown or early effect worries). If you used say 10 parallel IRFP4568PBF from IR, that's 0.6mohm RDSon. 300A through that lot is just over 5W each dissipation & would take up about 2 square inches of board space.
Dealing with 300A in a PCB trace is another problem, but not insurmountable I don't think; I've seen professional equipment with >100A in a 1inch wide PCB trace, that would be on 4oz. copper; & you have 2 or maybe 4 layers to play with.
bobc0 is offline Find More Posts by bobc0
Old Dec 23, 2012, 06:49 PM
isachan is offline
Find More Posts by isachan
Joined Nov 2006
There is a electronic device called "opto-isolators" to drive huge electric power from microcontrollers.
Have a look at his site:
http://jondontdoit.blogspot.ca/2012/...h-your-tv.html
Or this site:
hackaday.com
and search for "opto-isolator"
I think that would be an answer to the question !
Isao
isachan is offline Find More Posts by isachan
Old Jan 02, 2013, 09:25 PM
davidjbacon is offline
Find More Posts by davidjbacon
Electric Aircraft Enthusiast
Joined Aug 2011
Dale, I'm a bit unclear as to whether you're looking for a good motor controller or just something to act as a big electronic safety switch or the like.
In any case, I think you'll find a wealth of relevant information and DIY expertise on the Motor Technology forum of Endless Sphere. You have even attracted some attention on those forums, viz.: http://endless-sphere.com/forums/sea...ds=dale+kramer
davidjbacon is offline Find More Posts by davidjbacon
Old Feb 02, 2013, 08:12 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Testreport by Gerd Giese (a.k.a. www.elektromodellflug.de):
Translated version:
translate...www.rc-network.de/forum/content.php/233-Die-Brushless-Antriebe-von-Kontronik-erstürmen-die-Oberklasse
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Feb 02, 2013, 10:04 AM
Neil Stainton is online now
Find More Posts by Neil Stainton
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
Thanks Ron. That looks much better and safer than using a CC controller.
Neil.
Neil Stainton is online now Find More Posts by Neil Stainton
Old Feb 16, 2013, 08:53 AM
Axefly is offline
Find More Posts by Axefly
South Africa
Joined Feb 2010
December 2012 Udate
Dale
Dale, you should try kickstarter.com
You have a wealth of R&D to convince them on how successful this will be, i have heard many successful stories and of course naturally this is an exciting an interesting endeavor no matter who you are !
Axefly is offline Find More Posts by Axefly
Old May 29, 2013, 05:10 AM
Joined Feb 2001
Slightly OT
Video and more pictures of manned flight with an electric multicopter
www.e-volo.com ...
Originally Posted by e_lm_70 View Post
I think they will make more money with YouTube revenue sharing, then not trying to sell the concept ... As said, it is dangerous, and highly inefficient way to fly. They have been the first on doing it ... but ... everybody could have done it, with enough money to "waste" ... it is nothing else then a RC multi copter, but bigger ... nothing special. ...
Version 2 in the works, the VC200
www.e-volo.com
Controllers
translate...www.sinusleistungssteller.de
VC200
Old Jun 13, 2013, 07:06 AM
Joined Feb 2001
Plettenberg Nova series: 15, 30 and 150kW
www.plettenberg-motoren.net/index.php/en/motor-serias-nova
Old Jun 13, 2013, 07:16 AM
Joined Feb 2001
Controllers
www.plettenberg-motoren.net/index.php/en/motor-control
MST 140-400: 30/40kW
MST 400-400: 120/160kW
Old Jun 13, 2013, 07:31 AM
Joined Feb 2001
www.makanipower.com ( also www.jobymotors.com & www.jobyaviation.com ???) aquired by Google.
See
www.makanipower.com/google
Discussion Large scale electric build (~1/6 scale) stona Large Scale Cars 1 Feb 01, 2011 08:06 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline 3D Flying 38 Oct 25, 2010 11:16 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline Giant Electric Planes 1 Sep 10, 2010 03:46 AM
For Sale Electric Monster Motor! Tunigy 80-100-B-130 Kv Outrunner!! Nogahyde Aircraft - Electric - Power Systems (FS/W) 1 Sep 02, 2010 11:45 AM
