Old Aug 11, 2012, 07:07 AM
Axefly is offline
Find More Posts by Axefly
South Africa
Joined Feb 2010
Originally Posted by GCrafte View Post
I have a vision of being able to fly all over Europe (and also other continents) in an electric airplane. It will not save you any money if you have to pay landing fees every 100th kilometer, but might do so if you can land on rivers and lakes. There just have to be decent possibilities to recharge the batteries and also some decent solutions for sleep, food and water.
It might work right now if you´re not in a hurry and it might work even better in ten years time if the infrastructure for charging of batteries etc has improved.
Like mentioned above. Trick your wings out with solar panels. Yes solar is not ideal, but it is an option. I heard that solar technology improves by the week, someday, they should be very efficient.
Axefly is offline Find More Posts by Axefly
Old Aug 11, 2012, 07:39 PM
Gedexas is offline
Find More Posts by Gedexas
CP heli ≠ 3D heli
Gedexas's Avatar
United States, NJ, Point Pleasant Beach
Joined Mar 2009
I imagine that the weight of a solar panel requires more energy to move itself though the air than it generates, especially when the platform like Lazair is not optimal in the glide ratio department. What does Lazair glide? 20:1 on a good day?
There is one aircraft that can propell itself indefinitely by it's own on-board solar panels. I believe NASA debuted this aircraft a few years ago. It's far from being able to carry any significant load, though. To be fair, it's far from looking sturdy enough to withstand a serious gust of wind.
Gedexas is offline Find More Posts by Gedexas
Old Aug 11, 2012, 11:57 PM
Axefly is offline
South Africa
Joined Feb 2010
I think the solar panels is meant more in the sense for charging the batteries on the ground while stationary, not powering the plane in the air.
Maybe instead of the wing covering material the solar panels can be implemented, advancements in this technology aims to make solar more flexible, not sure where they're at yet, but it's coming.
All sorts of efficiency breakthroughs have been achieved the past year with solar tech, i'ts a matter of now just waiting for it to be commercially available.
Old Aug 12, 2012, 06:47 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Solar foil is in development:
tech.groups.yahoo.com/group/ETList
www.electrifyingtimes.com
Vriendelijke groeten ;-) Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Aug 12, 2012, 01:41 PM
Axefly is offline
South Africa
Joined Feb 2010
Aaah... There we go.... !
Old Aug 15, 2012, 12:34 AM
GCrafte is offline
Find More Posts by GCrafte
Joined Nov 2011
Solar foil
Solar foil? Here is another link: http://blog.cafefoundation.org/?p=6485
GCrafte is offline Find More Posts by GCrafte
Old Aug 15, 2012, 08:48 AM
Joined Feb 2001
You could put the foil on every plane surface: tail, wings, the open tail-boom surfaces, floats, between float struts. All top AND bottom, for reflected light, both surfaces.
Vriendelijke groeten Ron
Old Aug 18, 2012, 09:15 AM
Gianni Martini is offline
Find More Posts by Gianni Martini
Italy, Lombardy, Castellucchio
Joined Aug 2012
UL glider retrofitting to electric
Hello everyone Gianni from Mantova ( Italy )
I'm a newcomer to the forum
I am a glider pilot , and I have always believed in the electric propulsion , I am the service director of the biggest 5-axis machine tools for the aerospace industry and I am in contact with all the country and company of the sector .
I am also owner of Alisport Silent Club OP ( fixed Konig engine on the Pylon ).
In winter time I want start retrofit to electric my Silent OP, and I need ( if possible some support from the blog )
Silent data are:
130Kg empty weight W/o engine
80Kg pilot weight ( me )
Max LD 34/96KmH ( with winglets )
Actual power is 28HP Konig SD570
According to the information from the Italian manufactor of theSilent and based on the SIlent electro AE1 ( retractable Pylon type ) the characteristics of the very old version are:
Motor type : Not specified
Motor power: 13Kw
Motor rpm: 3.400rpm
Motor weight. 8.5Kg
Battery Weight: 40Kg
Ramp up: 2m/s
take off. <200mt on grass field
Propeller: two blade folding type , 1,92mt diameter , 1300rpm
Electric retractable Pylon
Now , I spend last two night to read all the information posted , because I have to choice the BLDC direct drive and right propeller , now I'm confused because i've to make the decision to use Jobj motor or the 200cc equivalent CA120-80-12 take a look at : http://www.gsmodels.com/en/products0...&fid=100080417
Powered glider don't need power to cruise and after take off reach 600 / 800mt ( 5 to 8 minutes ) the motor must be retract in the fusellage and soaring can start , restarting motor in flight is not safe and depend of height , finally what I want is have power capacity for 20 to 30 minutes ??!!
I've been order to Alisport the electric pylon used in the engine Silent IN because I don't want made experiments so I will use standard retraction system.
Can some ones help me to suggest the right motor BMS , battery and so on ?
Thanks in advance ( and sorry for my English )
Gianni Martini is offline Find More Posts by Gianni Martini
Old Aug 20, 2012, 03:49 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hello Gianni
Concerning a direct drive BLDC outrunner, here is a candidate
Parawatt motor
weight 7.4 kg
Power max 20 kW
Kv 35 rpm/V (star connecting)
contact : www.parawatt.com
Very robust motor (hollow shaft 30mm + excellent ball bearings)
Could be used with MGM Compro HBC series controler
Probably with 13S-14S Lipo you could obtain 1300 rpm on your 1.92m prop
Louis
Fourdan is offline Find More Posts by Fourdan
Old Aug 20, 2012, 09:08 AM
Joined Aug 2012
Hello Louis ,
thanks but this motor is too heavy,
I am in contact with the motor manufactor ot this 200 CC 30Hp
BLDC motor CA 120-80 , for Kv modification if it will no possible
I am thinking ( i not like ) a belt reduction or rewire the motor
For the ESC I am thinking a high quality Kelly OPTO KHB72701 700/350 A
Do you know a good BMS system
Gianni
Old Aug 20, 2012, 09:35 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Originally Posted by Gianni Martini View Post
Hello Louis ,
Gianni
Your selected motor is same as the hobbyking
Turnigy CA120-70 Brushless Outrunner (100cc eq)
Dave did try it on his Lazair, but eventually decided for a different one
He did also all the rewind stuff
Maybe is better to use a gear that rewind....
Anyhow, if you look in old post you may get some info about the motor and the rewinding actions
Tchuss
E_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Aug 20, 2012, 11:10 AM
Joined Feb 2001
Several big'uns compiled in this thread
www.rcgroups.com/forums/showthread.php?t=1464696
Maybe start a new thread Gianni? We're hijacking this one.
Old Aug 20, 2012, 11:57 AM
Fourdan is offline
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Hello Louis ,
Gianni
Hello Gianni
My opinion
No BMS when running the motor
Only balance at every charge
It could be very hard to run a 2.7 kg low Kv motor at 12 kW @ 1300 rpm direct drive (1.92 m diam prop)
Good luck
Louis
Old Aug 20, 2012, 01:04 PM
Joined Aug 2012
Hello Tchuss
E_lm_70
My motors is CA 120-80 ( = 200CC )
Dave in Lazair use CA 120-70 ( = 100CC )
Take a look at the Chinese ( not HK ) manufactor :
Gianni
Old Aug 20, 2012, 01:13 PM
sunworksco is offline
Find More Posts by sunworksco
BabyBootLegger
sunworksco's Avatar
United States, CA, Alameda
Joined Nov 2010
Ask Astrolight.com to give you information for their custom-built BL inrunner.
sunworksco is offline Find More Posts by sunworksco
Discussion Large scale electric build (~1/6 scale) stona Large Scale Cars 1 Feb 01, 2011 08:06 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline 3D Flying 38 Oct 25, 2010 11:16 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline Giant Electric Planes 1 Sep 10, 2010 03:46 AM
For Sale Electric Monster Motor! Tunigy 80-100-B-130 Kv Outrunner!! Nogahyde Aircraft - Electric - Power Systems (FS/W) 1 Sep 02, 2010 11:45 AM
