Old Nov 07, 2011, 08:07 AM
South Africa
Joined Feb 2010
Could also be because maybe i use a bigger prop than i should on the motor, however the aeronaut folding props i find is pretty light.
Axefly is offline Find More Posts by Axefly
Old Nov 08, 2011, 11:27 AM
Joined Feb 2006
30 kW BLDC motors available
Found out last week that JobyMotors.com is starting to produce a 30kW version of their motor for sale. It's not yet on their website, so contact them directly if you're interested. Right now he's deciding whether or not to produce in quantities based on demand. A 30kW motor is powerful enough to propel a single-seat ultralight or light 2-seater. Ask for JoeBen and tell him Mark Beierle sent you (Mark of the Thundergull ultralight fame who's built a few electric versions of his ultralight).
Jonathan
barracj is offline Find More Posts by barracj
Old Nov 08, 2011, 10:17 PM
Whats a search engine?
inventing_man's Avatar
Missouri
Joined Jun 2006
WOW ! I too have been reading this thread from cover to cover .
Dale, Cappy and Brian , thank you for this thread and your dedication to the sport .
As many have said they wish they could find a Lazair . I dont know if they are still being made , or if plans are avab. So if this might be infringing on someone , please let me know if this is the case and i will edit this post , But here is a possible alternative.
http://m-sandlin.info/ The drawing presented there are free and top notch. A very easy to build aircraft
inventing_man is offline Find More Posts by inventing_man
Old Nov 10, 2011, 06:42 PM
davincicode
Brian Steele's Avatar
Joined Jun 2006
Edit
Brian Steele is offline Find More Posts by Brian Steele
Old Nov 11, 2011, 10:14 PM
Joined May 2011
Hi Brian,
Thanks for the flattering comments on my re-drives. I designed them 30 years ago the old fashioned way - a pile of manufacturer's catalogs/specifications, a calculator and a pencil - and being naive enough to think I could with no mechanical engineering background. When I showed the tiny Pioneer engine and my design to a fellow that was then building re-drives for a few Ultralight aircraft producers, he told me I was crazy. I did finally get him to machine the large belt sheaves I needed. By then I had found a 9" South Bend lathe locally for sale, took a night school class and made the rest of the re-drive parts myself. So, way back then, I guess I was doing what Dale's trying to get people doing today. Dream it, then Do it. BTW, I've been dreaming for several years about converting one of my recumbent bikes to electric assist using RC stuff driven through the gears but haven't done it (yet). I have a pretty good collection of 18650 cells so I guess that's a start. I, however, have no intention of going wild like you have. Something approaching one HP will do me just fine!
Electrical interference is likely the cause of the Eagle Tree Logger's misbehaving in my mind too. One thing that most people don't realize is how powerful it can be under just the right circumstances. When you have lots of different frequencies, and they find lots of different length circuit board copper traces and component lead lengths, very efficient antennas can exist. When tuned so perfectly, amazingly large interference can be generated. Since I'm not intimately involved in the RC movement like most people here I had to go look over Eagle Tree's website. One thing I noticed was that in the listing of accessories for the eLogger the very last item offered is a ferrite choke. That makes me think they have in fact had somewhat wide-spread EMI problems...
I personally feel that Mike Sandlin is one of the heroes of the hang gliding/Ultralighting community. Who else is giving away complete plans for a variety of home buildable aircraft? Even if a person isn't interested in building one of them the plans can very educational. I've had a copy of his GOAT plans for a couple years. I hope I get to meet him someday!
As anyone that has read the early part of this blog would know, Dale has tried several times to power a Lazair using then-current RC equipment. Several years ago he planned to do it with 4 of the largest brushless motors then available. The batteries were similar to what he used this time. He built up one motor module to test. Unfortunately, he couldn't find a controller at the time that could survive. He eventually put it all aside to wait for the next generation of gear. At that time, IIRC, he computed that using $6000 in batteries would give him one climb to 1500 feet and maybe 10-12 minutes of cruise to try and chase down a thermal. Compare that to the flight duration he's getting now using approximately half the cost in batteries!
Chappy
Chappy123 is offline Find More Posts by Chappy123
Old Nov 12, 2011, 10:18 AM
Missouri
Joined Jun 2006
Grate ! Glad I'm not "crossing the line" here.
As Mike says , His highly detailed drawings are not "plans". Its detailed drawings of how he does stuff . So it is a good road map, thats open for changes to facilitate other ideas .
I would agree Non sheilded cables are useualy the problem. I have ran into this on many occasions in my line of work.
Old Nov 12, 2011, 02:05 PM
More Motors, More Fun... :-)
nioa's Avatar
Phoenix, AZ
Originally Posted by Chappy123 View Post
.....Electrical interference is likely the cause of the Eagle Tree Logger's misbehaving in my mind too. One thing that most people don't realize is how powerful it can be under just the right circumstances. When you have lots of different frequencies, and they find lots of different length circuit board copper traces and component lead lengths, very efficient antennas can exist. When tuned so perfectly, amazingly large interference can be generated. Since I'm not intimately involved in the RC movement like most people here I had to go look over Eagle Tree's website. One thing I noticed was that in the listing of accessories for the eLogger the very last item offered is a ferrite choke. That makes me think they have in fact had somewhat wide-spread EMI problems......
Originally Posted by inventing_man View Post
......I would agree Non sheilded cables are useualy the problem. I have ran into this on many occasions in my line of work.
I too have had Eagle Tree erratic readouts with two sets of different Dashboard/Flight Data Recorder units purchased at different times. Shielding does NOT help. I have been very careful with grounding and the prevention of ground loops, etc.. Eagle Tree's support offered canned (and some electronically ridiculous) responses that did little to improve the problem. Even at my workbench the units read erratically! I have given up on Eagle Tree.
Just had to get that off my chest! I rarely criticize anything without offering a solution, but this time, I can't offer one.
Thanks again for this informative, excellent thread.
Nick
nioa is offline Find More Posts by nioa
Old Nov 15, 2011, 07:08 PM
davincicode
Joined Jun 2006
Edit
Old Nov 16, 2011, 05:13 PM
Dale
KiloOne's Avatar
Joined Jul 2004
Update
Hi everyone,
Wow, a lot of posts since I last posted.
I am back from my cross country trip. I gave a talk at Scaled Composites in Mojave on Oct 27 about the Electric Lazair and I got to fly the full size Spaceship 2 simulator. That was the highlight for me. I managed to get to space and back without crashing the ship, although I was a little out of control a couple times.
We put 42 hrs on the RV8 and about 6000 xcountry miles.
Not much to report about the Lazair flying yet but I see I need to address a lot of posts to this thread. Unfortunately I am leaving for Uvalde again tomorrow. This time I am flying a Taifun motorglider to get down there. I'll try to catch up with my thread responses while I am down there if I have time.
Dale
KiloOne is offline Find More Posts by KiloOne
Old Nov 17, 2011, 02:59 AM
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Originally Posted by KiloOne View Post
Hi everyone,
Neat! I guess the advice to fly at least 2 mistakes high certainly applied here!
I don't suppose anybody thought to record the talk and post it somewhere?
marhar is offline Find More Posts by marhar
Old Nov 18, 2011, 11:12 PM
Missouri
Joined Jun 2006
Sad note here, Mark Stull , of Texas a Avid UL home builder and expermenter Crashed and parished in his latest experment. I believe Mark did post here at RC groups a few times, and some here may know him .
A very sharp and pointed wake up call for us all . Sence this thread is dedicated to 1 to 1 UL Home built scale , please keep in mind what is at stake guys and gals and be careful up there.
Phil .
Old Nov 20, 2011, 08:16 PM
homo ludens modellisticus
Ron van Sommeren's Avatar
near Nijmegen, Netherlands
Joined Feb 2001
... BTW, I've been dreaming for several years about converting one of my recumbent bikes to electric assist using RC stuff driven through the gears ....
See/search this subforum
http://endless-sphere.com/forums/viewforum.php?f=21
Vriendelijke groeten Ron
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Nov 20, 2011, 08:22 PM
Joined Feb 2001
Discussion/sources for larger batteries in the elelectric PPG group
http://groups.yahoo.com/group/electr...o=1&m=p&tidx=1
Old Nov 30, 2011, 03:27 AM
Australia, NSW, Greta
Joined Aug 2011
This period the thread is now going through is a bit like the period between season one ending and season two starting on a great tv show.
Hanging out for the next report.
Ozziedownunder is offline Find More Posts by Ozziedownunder
Old Dec 01, 2011, 03:55 AM
Joined Nov 2011
I want one!
I am very interested in a plane like this. Are Dale or anyone else going to produce and sell an amphibian electric Lazair soon?
GCrafte is offline Find More Posts by GCrafte
Discussion Large scale electric build (~1/6 scale) stona Large Scale Cars 1 Feb 01, 2011 08:06 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline 3D Flying 38 Oct 25, 2010 11:16 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline Giant Electric Planes 1 Sep 10, 2010 03:46 AM
For Sale Electric Monster Motor! Tunigy 80-100-B-130 Kv Outrunner!! Nogahyde Aircraft - Electric - Power Systems (FS/W) 1 Sep 02, 2010 11:45 AM
