Old Jun 10, 2011, 10:56 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
Yellowbird, do you have pictures of how you use a duct for cooling? I try all sorts of methods and combinations thereof to cool my motors and am always willing to try different methods.
rebell is offline Find More Posts by rebell
Old Jun 10, 2011, 12:39 PM
yellowbird2800 is offline
Find More Posts by yellowbird2800
USA, SC, Easley
Joined Sep 2009
Here is a pic I have on hand of an out runner and one of a baffle I added to my Neu motor. The motor face is set back behind the cowl face. The dummy radial which is mounted on thin ply fits tight around the motor. The only air that can go through the cowl has to travel through the stator. This made a huge difference on motor temp. This also works well on my P47 and P39. If the the motor is 90% efficient and peak watts are around 6000 then 600 watts of heat is produced. Sure it is not that simple of an equation but you get the idea. ESC cooling has to be monitored but Castle only requires 5 mph airflow so it has never been an issue for me.
I did something similar to my Neu motor set up because it was getting hot and it worked great. Motor now comes down almost ambient. Helped that the built in fan blades departed from the shaft at some point.
yellowbird2800 is offline Find More Posts by yellowbird2800
Old Jun 10, 2011, 10:47 PM
KrisMcLean is offline
Find More Posts by KrisMcLean
Joined Jun 2011
Battery Choice?
G'day Dale. I'm hoping to make the pilgrimage to Oshkosh this year (I'm from Sydney Australia) & see your creation.
In the meantime I'm intrigued by your battery choice. I've been loitering-with-intent at the fringes of electric cars. Conventional wisdom in the home brew end of this genre uses big 3.7v 40-100Ah submarine batteries (Thundershy etc) that work out to about $350/kwh & about 11kg/kwh
I like the Tesla approach better. Ordinary 2Ah 18650 format commodity cells (laptop batteries) come in at $250/kwh & 5.6kg/kwh around 2/3 the price & half the weight. They don't have the peak discharge of the traction batteries but run OK at the 0.5C rate for a 2 hour drive.
If I read your post correct your 14.8v 5Ah 430g zippys @ $32.89 ea work out to $440/kwh & 5.8kg/kwh? Given the energy density is about the same as the regular 18650s I'm thinking you paid extra for the higher discharge capability, for take offs?
KrisMcLean is offline Find More Posts by KrisMcLean
Old Jun 12, 2011, 07:28 AM
KiloOne is offline
Find More Posts by KiloOne
Dale
KiloOne's Avatar
Joined Jul 2004
JPXman,
You would be surprised at how much prop noise there is still. It is quiet but still makes me consider wearing a helmet with ear cover.
yellowbird,
I agree completely that cooling systems are lacking in these motors. The CA120-70 motors that I have been using has very little room for airflow through the stators and the aluminum bearing hub that the stator is bonded to does not have many cooling passages either. The cowl-less installation I have helps out a bit but makes it difficult to add ducting to force air through the center of the motor where it is needed. I still believe that these HK motors could be made to fly the Lazair with some more attention given to cooling but I just do not want to rewind them again and the Joby inrunner design appears to me to address the cooling issues directly. I am glad to see that ducting has worked so well for you and if I have to add some on the Joby motors, the inrunner design will make this easier.
Kris,
Hope to see you at Oshkosh assuming I get there.
Isn't the 18650 designation a cylindrical size specification (18 mm dia x 65 mm long)?
Can you tell us where to buy the 18650's at $250/kwh & 5.6kg/kwh and point us to charge/discharge curves?
In my installation I am not pushing the discharge rate of my cells since even at full power I am only discharging at 3-4c.
Dale
KiloOne is offline Find More Posts by KiloOne
Old Jun 12, 2011, 09:26 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Right, 18650 is 18mm x 65mm and the A123 18650 cells are nominally 1100mAh but really closer to 900mAh. My understanding is that the Tesla uses the A123 26650 2.3Ah cells which retail at around $8 but can be sourced from China for less.
Considering each cell to be: $8, 2.3Ah, 2.8V under load and 70g that gives around 6Wh/cell => $1300/kWh and 12kg/kwh.
kgfly is offline Find More Posts by kgfly
Old Jun 13, 2011, 12:27 AM
typeRA is offline
Find More Posts by typeRA
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
Originally Posted by kgfly View Post
...2.8V under load...
That sounds awfully low for a 1C discharge rate.
typeRA is offline Find More Posts by typeRA
Old Jun 13, 2011, 02:08 AM
kgfly is offline
Joined May 2006
You are right, I use them at more like 15C to 20C. So call it 3.2V at 1C discharge, that doesn't change the figures that much:
$8, 2.3Ah, 3.2V @ 1C load and 70g gives around 7.3Wh/cell => $1100/kWh and 10kg/kWh
Old Jun 14, 2011, 06:03 PM
hybridplane is offline
Find More Posts by hybridplane
Joined Jun 2011
Motor Cooling
KiloOne (Dale)
Good luck with your electric developments & congrats. on your maiden flight. We had some trouble with motors overheating too (our's is the UK electric Lazair) - we found that model motors just can't take the sustained power required for larger aircraft (we let smoke out of a couple !) until fitting a centrifugal fan on the back - made from FR4 PCB material. See detail of fan on back of Predator 30 motor. We can run these at about 5kW continuous with 32x12 3-blade props. - oversized for the motor but work well at ~4,000rpm. We also have auto power control to maintain the motor windings below 150 deg.C. We have done the same thing on a Hacker 200, which is on a hybrid gas/electric Alatus motorglider - this burnt out and had to be rewound with more copper and thermally conductive epoxy potting to get the heat out. Seems good now for about 8kW continuous at 7000rpm. We went for large LiPo cells - I'd be interested to hear how you get on with lots of small ones; I'm thinking of going that route for higher power/weight ratio. Jobys motors look promising too - good that we're getting more choice as time progresses; may still need forced-air cooling though for high continuous power.
Paul (R)
hybridplane is offline Find More Posts by hybridplane
Old Jun 15, 2011, 12:39 AM
rebell is offline
JustFlying
rebell's Avatar
Joined Dec 2005
The difference with using the same motor in a model is that you stand on one place and fly only short distances within line of comfortable vision with short power bursts with lots of low power in turns. With man carrying planes you fly long distance at sustained power setting which makes a big difference. How good the model motor might be, it is not designed for that.
I like your cooling system. It looks like you have a double aluminium plate at the back for transferring the heat to for cooling. If it is that, I did that on some of my high stressed motors in models as well.
Old Jun 19, 2011, 08:12 AM
Foxbuilder is offline
Find More Posts by Foxbuilder
United States, NY, Frankfort
Joined Jun 2011
Motor cooling
I agree with Hybridplane. The thermal conductive epoxy is a big plus for heat proplems. I've used it in industry with large motors. They where under alot of high torgue stress and heat would do them in. I went with the epoxy and had it vacumm inpregnated. Our heat problems with the windings subsided. liquid cooling would solve even more.
KiloOne (Dale)
I have a virgin Lazair III . It has never been flown. Always thought a electric powerd Lazair would be possible.This has my creative jucies flowing. Good luck . Looking forward to see it at Oshkosh!
Foxbuilder is offline Find More Posts by Foxbuilder
Old Jun 19, 2011, 08:57 AM
KiloOne is offline
Dale
KiloOne's Avatar
Joined Jul 2004
Hi Paul,
Great to hear you are still developing your electric Lazair. Wish I had a temp input to my Jeti controllers that would limit power based on temp. They do have an internal temp limit that is software adjustable, tried to figure out a way to parallel that sensor with another that would effectively limit both controller and motor but could not get access to the components.
Rebell,
I've spent a good part of my life taking things that are not supposed to do something and then making them do it. A lot of motors would work fine on a J3 Cub model and not on a screaming 3D. No one knows the limits of these HK motors. I am probing those limits without being hindered by the warning 'but they are not designed for that'. I still believe I could plod on and make the HK motors work fine for the Lazair (and may rewind them someday, I just bought the wire).
Foxbuilder,
I do hope that the Joby motors will work well enough to bring the Lazair to Oshkosh. Still on track for starting their courier journey to me late this week from CA.
Dale
Old Jun 19, 2011, 09:08 AM
KiloOne is offline
Dale
KiloOne's Avatar
Joined Jul 2004
Thermally conductive potting
As this is being mentioned lately, I did consider it when I rewound my motors.
I ended up just spraying a green McMaster Carr supplied 'Sprayon' varnish for two reasons, the first was expediency and the second was that I could not come up with a simple solution to heat dissipation from the potting compound to the airflow.
Sure the potting compound would draw heat from the windings but where would it go? The more potting compound applied, the less airflow there would be around it. I agree that the potting compound would help greatly as long as the compound ends up transferring the heat to some sort of heat sink in the airflow.
The Joby motors appear to have that heatsink and if the supplied heat flow path to the heatsink from the windings is not adequate then I think a good thermally conductive potting compound will be in order.
Is this thinking flawed?
Dale
Old Jun 20, 2011, 10:00 AM
Fltofancy is offline
Find More Posts by Fltofancy
Gene
Fltofancy's Avatar
Joined Mar 2011
Weight and Balance
Dale,
What does your weight and balance look like in this flying configuration?
Fltofancy.
Fltofancy is offline Find More Posts by Fltofancy
Old Jun 20, 2011, 08:25 PM
dalbert02 is offline
Find More Posts by dalbert02
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
I have not been this excited about a build project since the "Pink Floyd" foamie several years ago. Way to go Dale! Awesome!
-dave
dalbert02 is offline Find More Posts by dalbert02
Old Jun 20, 2011, 09:26 PM
Joined Jun 2011
I can only get 8wh out of the 18650 Li polymer generics if I keep the discharge rate to 0.5C Dale. Anyway hope you can get to Oshkosh on your zippys, sounds like you need a bit circular heatsink for those motors like the ones we used to clip onto 2N3055s transistors only bigger.
Discussion Large scale electric build (~1/6 scale) stona Large Scale Cars 1 Feb 01, 2011 08:06 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline 3D Flying 38 Oct 25, 2010 11:16 PM
Discussion OMP EG Aircraft 85-100 CC Extra 300 - Electric Conversion Alkaline Giant Electric Planes 1 Sep 10, 2010 03:46 AM
For Sale Electric Monster Motor! Tunigy 80-100-B-130 Kv Outrunner!! Nogahyde Aircraft - Electric - Power Systems (FS/W) 1 Sep 02, 2010 11:45 AM
