This thread is privately moderated by flywmoi, who may elect to delete unwanted replies.
Old Mar 25, 2011, 01:51 AM
flywmoi is offline
Find More Posts by flywmoi
Trader Rating: 17
United States, CA, Palm Springs
Joined Aug 2010
Trader Rating: 17
For Sale
NIB Futaba 10CG 2.4GHz, FASST Radio Brand New
I have a brand new Futaba 10CG 2.4GHz FASST Radio System. It is the aircraft mode 2 version with the ratchet Throttle. It will come with the full factory warranty, NIB, all the manuals and chargers, the complete setup. This radio cost me over $520 plus shipping, and I am only asking $475 plus $15 shipping.
10CG System Overview:
* Dial 'n Key™ programming w/joystick
* Airplane, heli and glider software
* 2048 resolution
* Real-Time Response™
* Smart Switch Technology™
* Basic & advanced menus
* 15-model memory, expandable to 48 models*
* 10-character model & user naming
* Assignable switches & dials/functions
* Model select, copy, re-set
* Data transfer
* 2 proportional slider switches
* Fail-safe, sub-trims, servo reversing & EPA
* Digital trims & trim step, expo & dual/triple rates
* 160 x 72 back lit LCD w/adjustable contrast
* Servo monitor display
* Auxiliary channel screen for 1-step function/switch assignment
* Model & system timers
* Full functionality trainer system (cord required)
* Throttle cut, hold & idle down
* Mode 1-4 selectable
* Sticks w/length and tension adjustments
* Requires optional 128K CAMPac Module (FUTM9408)
Airplane Features
* 8 programmable mixes
* Elevator/Flap
* Throttle needle
* Aileron differential
* Flaperons
* V-tail
* Elevon
* Air brake w/elevator delay
* Ailevator
* 4-position snap roll switch
* 2 independent gyro settings
* 7-point throttle curve
* Flap trim
Heli Features
* 6 programmable mixes
* Hover/pitch
* Hover throttle
* 8 swash plate types w/graphics
* Swash AFR
* 5-point revo mixing
* Gyro menu
* 7-point throttle & pitch curves w/delay
* High/low pitch setting
* Swash ring
* Throttle hold & 3 idle-ups w/delay
Glider Features
* Butterfly/elevator (2)
* Elevator/flap
* Chamber mix
* Aileron/flap
* Aileron/rudder
* Flaperons
* V-tail
* 4-point offset
* Spoiler mix
* Single/dual flap servos
* 5 flight conditions
* 3 wing types
* Adjustable motor cut
Includes:
Futaba 10CG Transmitter
9.6V 700mAh NiCd Transmitter Battery
Wall Charger (xmtr & rcvr)
Instruction Manual
If interested please email me at realfast2000@gmail.com
Thank you
flywmoi is offline Find More Posts by flywmoi
Old Mar 25, 2011, 12:26 PM
rvsixer is offline
Find More Posts by rvsixer
Trader Rating: 17
rvsixer's Avatar
United States, CA, Orange County
Joined Sep 2005
Trader Rating: 17
Regarding the full factory warranty, are you an authorized Futaba reseller? Factory warranty only applies to original purchaser, not subsequent owners.
rvsixer is offline Find More Posts by rvsixer
Old Mar 25, 2011, 06:46 PM
flywmoi is offline
Trader Rating: 17
Joined Aug 2010
Trader Rating: 17
I was under the assumption that if it has never been used, then the warranty would follow the unit? Am I mistaken?
Sold Futaba 10CG 2.4GHz FASST System - NIB HotRod34a Aircraft - General - Radio Equipment (FS/W) 0 Jan 27, 2011 06:12 PM
Sold New Futaba 10CG 10-Channel FASST 2.4GHz Radio Buzz_Man Aircraft - General - Radio Equipment (FS/W) 7 Dec 21, 2010 11:52 PM
Sold NIB Futaba 10CG 10Ch FASST 2.4GHz Heli- R6014HS Rx FUTK9256 $385 FREE SHIPPING compudation Aircraft - General - Radio Equipment (FS/W) 0 Sep 05, 2010 04:44 AM
Sold NIB Futaba 10CG 10Ch FASST 2.4GHz Heli- R6014HS Rx FUTK9256 $385 FREE SHIPPING compudation Aircraft - Fuel - Helis (FS/W) 0 Sep 05, 2010 04:43 AM
Sold NIB Futaba 10CG 10Ch FASST 2.4GHz Heli- R6014HS Rx FUTK9256 $399 compudation Aircraft - General - Radio Equipment (FS/W) 0 Aug 31, 2010 06:17 PM
