Old Mar 24, 2011, 11:21 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
My XP9303/DragonLink and Skywalker Set Up
I have had several questions on how I set up my XP9303/DragonLink in my Skywalker using a ET OSD PRO and an FY-20A stabilizer. I use AUX2 3 position switch to control Dual Rates, FY-20A stabilizer on/off, and RTH. Here is a list of what channel goes where and its function:
1- Throttle - goes to the Throttle in port of the OSD
2- Aileron - goes to the Aileron in port of the FY-20A
3- Elevator - goes to the Elevator in port of the OSD
4- Rudder - goes to the Aileron/Rudder in port of the OSD
5- Gear Switch - goes to the AUX1 in port of the OSD
6- Flap 3 position Switch - goes to the PAN servo for 3 positions
7- AUX2 3 position Switch - goes to the "switch" port of the FY-20A. Position "0" is low rates, FY-20A off, no RTH. Position "1" is high rates, FY-20A in full stabilization mode, no RTH. Position "2" is high rates, FY-20A in full stabilization mode, RTH engaged.
8- LT Lever - goes to the tilt servo (optional). Also serves as the input from the 5V UBEC output.
9- Mix Switch - goes to the AUX2 port of the OSD
This is how I fly my Skywalker. There may be other ways to program the radio, but this is how I do it. Feel free to do it your own way. You'll notice that I used a small piece of masking tape to remind me what mixes 5 and 6 need to be to obtain LT or DN.
Below is screen shots of how I've programmed the radio in order of how they appear on the transmitter screen. I've included a block diagram of how I have my system hooked up.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Last edited by Crist Rigotti; Mar 25, 2011 at 04:22 PM. Reason: added block diagram
Old Mar 24, 2011, 11:28 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
I have been experimenting wit throttle to elevator mix and stopped useing it due to the volts/amps/watts change as i fly, but mix stays the same.
so end result the mix does not realy work effectively from beginning to end of flight.
I found manually trimming the elevator a more effective means to the end with elevator throttle mix.
your throttle can be 1/4 or 3/4 and same watts output durring the flight but mix remains the same and does not work very effectively
Originally Posted by Crist Rigotti View Post
I have had several questions on how I set up my XP9303 in my Skywalker using a ET OSD PRO and an FY-20A stabilizer. I use AUX2 3 position switch to control Dual Rates, FY-20A stabilizer on/off, and RTH. Here is a list of what channel goes where and its function:
7- AUX2 3 position Switch - position "0" is low rates, FY-20A off, no RTH. Position "1" is high rates, FY-20A in full stabilization mode, no RTH. Position "2" is high rates, FY-20A in full stabilization mode, RTH engaged.
8- LT Lever - Tilt servo
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Mar 24, 2011, 11:34 PM
Joined Mar 2008
David22,
I find it easier to use manual trim for the elevator too. Hence I'm not using any mix. I showed it just in case anybody else wants to try it.
Old Mar 24, 2011, 11:56 PM
Taiping is offline
Find More Posts by Taiping
Canada, BC, Vancouver
Joined Sep 2009
Did you ever try RTH without a stabilizer? Thanks
Taiping is offline Find More Posts by Taiping
Old Mar 25, 2011, 12:18 AM
Joined Mar 2008
No. Never thought of doing that.
Old Apr 03, 2011, 12:44 AM
mentony32 is offline
Find More Posts by mentony32
mentony32's Avatar
Australia
Joined Jun 2010
Hi Crist,
Are you displaying the Dragon Link RSSI on the OSD Pro ? I have been with just a simple single wire connection to the eLogger, but someone made me nervous saying this was a cause of a crash. I havent seen a problem, have you ?
mentony32 is offline Find More Posts by mentony32
Old Apr 03, 2011, 12:50 AM
Joined Mar 2008
Originally Posted by mentony32 View Post
Hi Crist,
No I'm not. I'm the one that had some problems with it. Frankly, I think that displaying RSSI using a DL isn't all the necessary. The solid link even at very great distances makes RSSI something that I don't worry about. Personal preference.
Discussion how do i set up my arf jet THESANDMAN Beginner Training Area (Aircraft-Electric) 9 Jan 27, 2011 11:48 PM
Discussion Sharing my progress! Belt CP V2 - perfect set-up danda00 Mini Helis 4 Jan 27, 2011 01:35 PM
Discussion Advice on my f22 set up before I order XLSPilot85 Electric Ducted Fan Jet Talk 0 Oct 25, 2010 11:53 PM
Discussion Please review my proposed FPV set-up!! carbonbmw FPV Talk 15 Sep 16, 2010 07:41 AM
Wanted looking for electric heli set up for my computer set up. nick84 Aircraft - Electric - Helis (FS/W) 3 Sep 04, 2008 10:19 PM
