I think you have that backwards.
Latest blog entry: Some stuff
No, not right. There are self-stabilizing helis that are designed with offset flybars or offset heads to provide stability. These designs are usually used on FP helis because they need it more, although there are a few CP helis with self-stabilizing heads. The Blade MSR, 120SR, Walkera CB100 and NE Solo Pro are examples of self-stabilizing FP helis.
But, if you look at conventional helis, CP helis have higher headspeed and head speed is constant while pitch changes, both of which promote higher stability. A conventional FP heli has low headspeed and you must change headspeed to change altitude, bad for stability. Most conventional FP helis use a head design that has no anti-roll geometry, most CP helis have anit-roll geometry. This is pretty academic these days as there are very few remaining conventional FP helis. Somebody new to the hobby who sees nothing but self-stabilizing FP helis could easily make the same assumption you did. |
Another point about FP versus CP helis, is for all intents and purposes, the rotating blades are seen as a solid disk. Air will not penetrate it. As far as wind is concerned the rotor disk is just like a kite. If wind gets under it, it will lift. With an FP heli your only choice is to cut throttle. Of course when you do that, you have no control. A CP heli has negative pitch. It can drive downward to counteract wind without reducing throttle; in fact you can often increase throttle. People who can fly FP helis in wind are essentially "wind surfing" while attempting to angle the head downward enough where the wind is pushing at an angle; kind of like tacking into the wind on a sail boat.
DFW airport
Joined Jan 2009
Lotta variation.
Hiller-only heads like HBFP don't stabilize at all. You REALLY have to stay ahead of them. Bell-Hiller + 45* heads like 120SR will reach a null with no control inputs, given enough time and space. But the price for that is staying ahead of the head's own corrections. IOW, when you tell it "stop" it kinda resents that and backlashes and you have to anticipate that too. Given a slight breeze, all 'stability' bets are off as "breeze" can come from ANY direction at any time. That's what makes it fun, eh? |
Pittsburgh PA
Joined Dec 2004
FP helis are no good in the wind and for that matter unless they have a 45 degree flybar they are no good for indoors. i would suggest the MCPX for a first CP heli. it is very similar to a 120sr IMO but you just have to fly it a little more. Sim time is a good thing as i think the sim is harder than actually flying, however crashing is a lot less expensive on a sim! if you plan on, staying in the hobby, get a good radio first, learn to program it and get comfortable with it on the sim.
CG I am beginning to think Balr is not human, i picture him as a super computer with reel to reel tapes ect... with everything about helicopters stored in the memory banks. |
I picked up Phoenix v3 today at the LHS. I already have a DX6i, so I got the cheaper one without the transmitter. To be honest, I am a little disapointed. It doesn't come with any instructions to speak of, and calibrating the transmiter to the software is a little confusing. For example, Phoenix says to do calibration in Heli mode, not fixed wing. Ok simple enough...but then it comes time to calibrate the "gear" and "flaps" switches. How in the heck do I do that in heli mode? Those aren't even options in heli mode. It just doesn't make sense. Anyways, rant over. I will carry this over to my other thread in the RC Sim forum
![]() Anyways, another question regarding CP helis...and a very noob one at that. Is collective controlled independently, or is it automatically mixed with throttle? I was thinking it was an automatic thing, but Phoenix asked me which channel I wanted to use for collective. |
United States, CA, Glendale
Joined Jan 2009
throttle and pitch are on the left vertical axis (mode 2) Its a mix in the radio....they have seperate channels but all work together when the stick is raised and lowered...Hope that is clear as mud...Look in your dx6i manual to be sure but I believe it like channel 2??? Cant member at the moment...I know throttle is 3...
-Jeff |
| Thread Tools | |
| Discussion fixed pitch vs collective pitch | itsgumby911 | Electric Heli Talk | 7 | Apr 18, 2012 09:54 PM |
| Question Fixed Pitch vs Collective Pitch | Woody_99 | Micro Helis | 9 | Mar 18, 2010 05:02 PM |
| Fixed Pitch vs Collective Pitch | newman | Electric Heli Talk | 8 | Sep 09, 2004 07:35 AM |
| Fixed pitch vs collective | flyboss | Electric Heli Talk | 2 | Jul 15, 2004 06:04 AM |
