| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Guest
Posts: n/a
Re: Flybar speculations... was Re: Large Scale turbine Jet Ranger at 3D masters
>> The system would simply try to maintain a position 90 degrees to
>> the axis of rotation, that being the rotor mast! > >The crux of the debate. > >Based upon your statement, I am going to speculate that what you are missing >is that the AXIS of >the flybar rotation is NOT the mast centerline. > If that's true, then you're right. I'm missing it completely because at this point, I totally disagree with that statement. To try to clarify this, I'm talking about mounting the rotor hub w/flybar to the rotor mast and spin the darn thing. The flybar will then be going around in circles with the spinning rotor mast. The flybars center, the teeter point, will be centered on the rotor mast, the axis of rotation in this case. That's the ONLY center of rotation that's relevant in this conversation. As I think we've already agreed, the rotation of the flybar itself, IE: the cyclic movements that would matter if the paddles were in place, are irrelevant in this conversation. >The MIDDLE of the bar is ON the mast CENTERLINE, but the AXIS of rotation of >the bar and the >AXIS of rotation of the mast are NOT the same (except when bar and mast are >perfectly >perpendicular) > Oops, I don't think so. The flybars "middle", the hinge point on which it teeters up and down, being mounted on the mast centerline, IS it's axis of rotation when it's spinning with the rotor mast. Just because the flybar is not in a plane, 90 degrees to the rotor mast at a given point in time, "does not" mean that the axis of rotation is different and that's why ti will try to reestablish a position, 90 degrees to the rotor mast. >The axis of rotation of the bar is defined by whatever plane the BAR is >spinning in . . . which >may or may not be perpendicular to the mast. > I don't see how you're coming up with that. <pause to think about light that just came on! ;-) > Oh, wait a minute. Let's see if I'm getting this right. You're contention is that the axis of rotation is "always" 90 degrees to the plane or rotation. "So", if the flybar isn't 90 degrees to the rotor mast, then it's axis of rotation will not be parallel to the rotor mast and I think, you're saying that it will want to stay that way. If the flybar were totally independant of the rotor mast and hub, I'd agree with that but it's not. The flybar's teeter hinge is solidly tied to the axis of rotation of the rotor mast, via the rotor hub. It is, therefore, influenced "by" the axis of rotation of the rotor mast. If the flybar isn't 90 degrees to the rotor mast, then it's axis of rotation (as I think you're defining it) is wobbling in space relative to the axis of rotation of the mast and it will not like that. It's natural preference will be to line back up with the rotor mast and that will put the flybar back into an orientation of 90 degrees to the rotor mast. >Centrifugal force is always perpendicular to the axis of rotation of any >mass . . at least so I >was taught. If you accept that as fact, I do! then you must concede that the >centrifugal force exerted >by the bar will attempt to pull the end of the bar exactly 90 degrees from >the AXIS of rotation >of the BAR itself . . not to be confused with the CENTER of rotation or >mass. > Well, because the two (flybar and rotor mast) are tied to each other, the center of rotation and the flybars axis of rotation will want to be the same, thus establishing (or at least trying to) that position, 90 degrees to the rotor mast. >Another way to state this is to imagine the mast vertical and the bar tracing >a perfectly >horizontal plane. Incline the mast 10 degrees from vertical. Centrifugal >force on the bar does >NOT change unless it's axis changes. The bar (gyroscope) axis is still >vertical where the mast >axis is not 10 degrees from vertical. > I totally agree with this IF the mast and flybar were completely independant of each other. Problem is, they're not! I refer back to what I stated above. >Your contention the centrifugal force will pull the bar 90 degrees from a >rotation axis is >absolutely correct . . . you're just looking at the wrong axis > >Just to confuse things a little further, centrifugal force and gyroscopic >force are different >animals . . . 'G' forces are centrifugal, but there is no gyroscopic effect >to speak of. > I'd agree with that in a free flying mass. Example, a fixed wing aircraft in a turn. The aircraft will experience centrifugal force but no gyroscopic effect. >The solid armature of an actual gyroscope contains centrifugal force, but >that force has nothing >to do with the gyroscopic function. Oh boy! <BG> "That's" an entirely different discussion. Centrifugal force may be "different" from gyroscopic function but to say they have nothing to do with each other is incorrect. Here's how I look at it. We all know the law of nature that states; "Any object, set in motion, will tend to remain in motion and it will tend to "TRAVEL IN A STRAIGHT LINE." For the purposes of what I'm about to say, it's the "travel in a straight line" part that's important. If a mass is traveling through space at 100 mph, it will maintain that 100 mph and it will (absent any gravitational forces) continue to infinity in a STRAIGHT LINE at 100 mph. Now, let's tether that mass to a fixed point so that it's now traveling "around" that point in a circle at 100 mph. The point is now the axis of rotation. The mass is also now experiencing centrifugal force because it's trying to go in a straight line but it can't, it's being restrained to that central point. As a result, the "straight line" that it's experiencing is the "plane of rotation" that it is established in and it will not want to deviate from that plane of rotation. Gyroscopic function comes into play if a force is applied that tries to change the plane of rotation. Getting back to our free flying mass in space for a moment. If we introduce a gravitational force to the equation, the mass will start to turn in the direction of that gravity. The amount of turn will be dictated by a balance of the masses forward inertia and the strength of the gravitational pull. If the inertia is stronger, the mass will see a small turn and then break free. If they balance, the mass will enter orbit of the gravitational point, and if the gravity is stronger, the mass with spiral in to impact. On our gyroscope, because the mass has forward inertia along the plane of rotation, it tries to maintain that plane of rotation. A force applied to change that plane is reacted to somewhere up to 90 degrees along the plane, in the direction of rotation. That's why a helicopters cyclic commands are applied 90 degrees "ahead" of the point where we really want the rotor system to tilt. What I'm trying to say in this long winded explination is that, while I agree that centrufugal force and gyroscopic function are seperate things, they ARE related to each other. While you can have centrifugal force without gyroscopic function, you can't have gyroscopic function without centrifugal force. FWIW, Fly Safe, Steve R. |
#2 |
Guest
Posts: n/a
> will be centered on the rotor mast, the axis of rotation in this case. That's > the ONLY center of rotation that's relevant in this conversation. I'm convinced that you (and others) are mixing "center" and "axis". Center is a point, axis is a line. There is no such thing as perpedicular to a point. PLug that into your thinking and see if you don't get a different perspective. If you have a rubber ball floating in a swimming pool and you place your finger on top and pull towards you, it's axis of rotation goes from your left to right. If you were to place your finger on top and pull sideways, the axis of rotation would go from behind you to in front of you. IN each case, the center of rotation is the same, but the axis is very different. Both centrifugal and gyroscopic forces are relative to rotation AXIS . . . i.e. a line in space, not a point. If the flybar is tettered at all, then it is out of perpendicular to the mast AXIS (centerline in our example), then it's own AXIS (perpendicular to the plane of the bar) will be different. Incidentally, it would not be wobbling, just rotating about it's own AXIS. > Oh, wait a minute. Let's see if I'm getting this right. You're contention is > that the axis of rotation is "always" 90 degrees to the plane or rotation. Yes. > "So", if the flybar isn't 90 degrees to the rotor mast, then it's axis of > rotation will not be parallel to the rotor mast and I think, you're saying that > it will want to stay that way. Provided it is spinning, yes. > If the flybar were totally independant of the > rotor mast and hub, I'd agree with that but it's not. The flybar's teeter > hinge is solidly tied to the axis of rotation of the rotor mast, via the rotor > hub. Here again, I thing you are considering a point as if it were an axis. The bar ans mast are only 'solidly' connected at a single point. They are NOT solidly connected by AXIS. The hinge alows the rotation axis of the bar abnd the mast to deviate from each other. The condition is similar to what happens in an automotive U-joint or CV joint. Both of these mechanisms transfer rotational power through a point while allowing the axis of rotation to be different on each side of that point. In fact, it may be useful to understanding the concepts if one were to mentally cut away the mast above the flybar and consider the hinge to be an actual U-joint, which is in fact what is. > rotation of the mast and it will not like that. It's natural preference will > be to line back up with the rotor mast and that will put the flybar back into > an orientation of 90 degrees to the rotor mast. > Well here we come full circle. If you can let go of the natural fixation on 'point' you may see that there is no 'natural preference' for the bar to spin on the same axis as the mast so long as there is no connection between those axis. The bearing friction provides a very small connection . . at 30 to 50 seconds response time, obviously not quite enough . . . .and the physical dampers (mechanical on a real heli, aerodynamic on our models) are needed to force the bar to follow the mast. |
#3 |
Guest
Posts: n/a
> What you guys are saying it totally over my head, but it seems pretty > obvious to me that if you spin the rotor head with the flybar paddles > removed, the flybar will move to, and hold itself at 90 degrees to the main > shaft. Were that true, then it begs two questions: 1) If the bar naturally wants to follow the mast, how does it provide any stabilization at all? 2) What are those paddles for? |
#4 |
Guest
Posts: n/a
Steve Simpson wrote:
>> What you guys are saying it totally over my head, but it seems pretty >> obvious to me that if you spin the rotor head with the flybar paddles >> removed, the flybar will move to, and hold itself at 90 degrees to >> the main >> shaft. > > Were that true, then it begs two questions: > > 1) If the bar naturally wants to follow the mast, how does it provide > any stabilization at all? > > 2) What are those paddles for? shall I remove blades & flybar paddles from my Sceadu and film it to stick on the web? Perhaps you're right but my instinct tells me not. My helis not good for anything else so I might as well.. |
#5 |
Guest
Posts: n/a
"Carl Farrington" <carl@000compsup000.net> wrote in message news:bh9d53$ri$1$8302bc10@news.demon.co.uk... > Steve Simpson wrote: > >> What you guys are saying it totally over my head, but it seems pretty > >> obvious to me that if you spin the rotor head with the flybar paddles > >> removed, the flybar will move to, and hold itself at 90 degrees to > >> the main > >> shaft. > > > > Were that true, then it begs two questions: > > > > 1) If the bar naturally wants to follow the mast, how does it provide > > any stabilization at all? > > > > 2) What are those paddles for? > > shall I remove blades & flybar paddles from my Sceadu and film it to stick > on the web? Perhaps you're right but my instinct tells me not. My helis not > good for anything else so I might as well.. Give me a ring first Carl. I'll hold the camera or I'll fly the heli, I don't mind which. -- Beav Please note my E-mail address is "beavis dot original at ntlworld dot com" (with the obvious changes) Beavisland now lives at www.beavisoriginal.co.uk |
#6 |
Guest
Posts: n/a
NNTP-Posting-Host: compsup.demon.co.uk
X-Trace: news.demon.co.uk 1060723331 9090 62.49.18.87 (12 Aug 2003 21:22:11 GMT) X-Complaints-To: abuse@demon.net NNTP-Posting-Date: Tue, 12 Aug 2003 21:22:11 +0000 (UTC) X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1165 X-Priority: 3 X-Newsreader: Microsoft Outlook Express 6.00.2800.1158 X-MSMail-Priority: Normal Xref: news.newshosting.com rec.models.rc.helicopter:54615 Beav wrote: > "Carl Farrington" <carl@000compsup000.net> wrote in message > news:bh9d53$ri$1$8302bc10@news.demon.co.uk... >> Steve Simpson wrote: >>>> What you guys are saying it totally over my head, but it seems >>>> pretty obvious to me that if you spin the rotor head with the >>>> flybar paddles removed, the flybar will move to, and hold itself >>>> at 90 degrees to >>>> the main >>>> shaft. >>> >>> Were that true, then it begs two questions: >>> >>> 1) If the bar naturally wants to follow the mast, how does it >>> provide any stabilization at all? >>> >>> 2) What are those paddles for? >> >> shall I remove blades & flybar paddles from my Sceadu and film it to >> stick on the web? Perhaps you're right but my instinct tells me not. >> My helis not good for anything else so I might as well.. > > Give me a ring first Carl. I'll hold the camera or I'll fly the heli, > I don't mind which. How can you fly it without blades? I was thinking just getting the rotor spinning to see if the flybar aligns on a plane 90 degrees to the main shaft (which is what I reckon will happen), or if it maintains it's position where it's put. Am I totally missing the point? |
#7 |
Guest
Posts: n/a
> Give me a ring first Carl. I'll hold the camera or I'll fly the heli, > I don't mind which. How can you fly it without blades? I was thinking just getting the rotor spinning to see if the flybar aligns on a plane 90 degrees to the main shaft (which is what I reckon will happen), or if it maintains it's position where it's put. Am I totally missing the point? >>>>>>>>>> Beavis don't need no stinkin blades to fly a helicopter......................... |
#8 |
Guest
Posts: n/a
"Carl Farrington" <carl@000compsup000.net> wrote in message news:bhblq3$8s2$1$8302bc10@news.demon.co.uk... > Beav wrote: > > "Carl Farrington" <carl@000compsup000.net> wrote in message > > news:bh9d53$ri$1$8302bc10@news.demon.co.uk... > >> Steve Simpson wrote: > >>>> What you guys are saying it totally over my head, but it seems > >>>> pretty obvious to me that if you spin the rotor head with the > >>>> flybar paddles removed, the flybar will move to, and hold itself > >>>> at 90 degrees to > >>>> the main > >>>> shaft. > >>> > >>> Were that true, then it begs two questions: > >>> > >>> 1) If the bar naturally wants to follow the mast, how does it > >>> provide any stabilization at all? > >>> > >>> 2) What are those paddles for? > >> > >> shall I remove blades & flybar paddles from my Sceadu and film it to > >> stick on the web? Perhaps you're right but my instinct tells me not. > >> My helis not good for anything else so I might as well.. > > > > Give me a ring first Carl. I'll hold the camera or I'll fly the heli, > > I don't mind which. > > How can you fly it without blades? Oh we'll leave THEM on so that the experiment has some real value. If the heli flies Ok, WE'LL know it does and if not, YOU'LL know it doesn't :-)) I was thinking just getting the rotor > spinning to see if the flybar aligns on a plane 90 degrees to the main shaft > (which is what I reckon will happen), or if it maintains it's position where > it's put. And how are you going to subsequently move the heli to a new position? Don't tell me you're going to rock it around wi' t'boom:-)) Get it up in t'air without them paddles and then it's discussion over:-)) > > Am I totally missing the point? Probably, just like me. -- Beav Please note my E-mail address is "beavis dot original at ntlworld dot com" (with the obvious changes) Beavisland now lives at www.beavisoriginal.co.uk > > |
#9 |
Guest
Posts: n/a
> > I don't mind which. > > How can you fly it without blades? I was thinking just getting the rotor > spinning to see if the flybar aligns on a plane 90 degrees to the main shaft > (which is what I reckon will happen), or if it maintains it's position where > it's put. No cheating, Carl! The original question was about the handling of the heli in flight. To answer the question, you need to see if the bar will FOLLOW the mast with no paddles or links, so you must hover and then tilt the mast with cyclic input. If I am wrong, the bar will follow the mast via some physics unknown to me and you will be able to fly around fine, albeit a bit sluggish. If I am right, . . . . well, you didn't like that heli so much anyway . . . . it will all boil down to how well the bar resists bending once it runs out of hinge travel. It is does bend, the resulting out of balance condition may make for an interesting landing . . . . . particularly with no stabilization. For the record, I was only kidding about trying this out with an actual model heli. I think the result could be very bad and do not recommend you try it, . . . . but if you insist, I will provide the web space to post the video. |
#10 |
Guest
Posts: n/a
> How can you fly it without blades? I was thinking just getting the rotor > spinning to see if the flybar aligns on a plane 90 degrees to the main shaft > (which is what I reckon will happen), or if it maintains it's position where > it's put. Without bladers there will be no downwash from the blades while hovering,this might have some effect on the flybar. |
#11 |
Guest
Posts: n/a
"Courseyauto" <courseyauto@aol.com> wrote in message news:20030813123457.21906.00000739@mb-m07.aol.com... > > > How can you fly it without blades? I was thinking just getting the rotor > > spinning to see if the flybar aligns on a plane 90 degrees to the main shaft > > (which is what I reckon will happen), or if it maintains it's position where > > it's put. > > > Without bladers there will be no downwash from the > blades while hovering,this might have some effect on the flybar. What about all those little heli's where the flybar is ABOVE the blades Doug? Or don't they count? :-) -- Beav Please note my E-mail address is "beavis dot original at ntlworld dot com" (with the obvious changes) Beavisland now lives at www.beavisoriginal.co.uk |
#12 |
Guest
Posts: n/a
> Without bladers there will be no downwash from the > blades while hovering,this might have some effect on the flybar. What about all those little heli's where the flybar is ABOVE the blades Doug? Or don't they count? :-) >>>>> Only in an inverted hover............. |
#13 |
Guest
Posts: n/a
"Courseyauto" <courseyauto@aol.com> wrote in message news:20030813154645.21906.00000744@mb-m07.aol.com... > > > Without bladers there will be no downwash from the > > blades while hovering,this might have some effect on the flybar. > > What about all those little heli's where the flybar is ABOVE the blades > Doug? Or don't they count? :-) > > >>>>> > > Only in an inverted hover............. Well we'll have to wait and see if someone can get a paddle-less heli inverted to see if that's true:-) -- Beav Please note my E-mail address is "beavis dot original at ntlworld dot com" (with the obvious changes) Beavisland now lives at www.beavisoriginal.co.uk |
#14 |
Guest
Posts: n/a
Well we'll have to wait and see if someone can get a paddle-less heli inverted to see if that's true:-) -- Beav >>> I have flown my xcells numerous times with the flybar lock still on,to be honest i couldn't tell a lot of difference. I know what your going to say but these were some 20gm sab paddles so they were fairly quick when they were enabled without the lock in place. DOUG |
#15 |
Guest
Posts: n/a
"Courseyauto" <courseyauto@aol.com> wrote in message news:20030813195125.28318.00000395@mb-m10.aol.com... > > Well we'll have to wait and see if someone can get a paddle-less heli > inverted to see if that's true:-) > > > -- > Beav > >>> > > I have flown my xcells numerous times with the flybar lock still on,to be > honest i couldn't tell a lot of difference. Yeah, but that's not the same as simply removing the paddles, and the times I've flown with a lock on, I've been VERY aware that the heli isn't behaving as normal. Usually because the heli won't manoeuvre nearly half as well as it does with the lock in the box where it belongs. I know what your going to say but > these were some 20gm sab paddles so they were fairly quick when they were > enabled without the lock in place If you couldn't tell much difference, SOMETHING about your heli is't working properly. -- Beav Please note my E-mail address is "beavis dot original at ntlworld dot com" (with the obvious changes) Beavisland now lives at www.beavisoriginal.co.uk |
| Thread Tools | |
| Data Scale MX400 Jet Ranger | darthdrk | Mini Helis | 7 | Oct 29, 2006 09:16 AM |
| Discussion 240 or 401 for full scale .30 jet ranger | rmasu | Electric Heli Talk | 13 | Sep 11, 2006 04:22 PM |
| Re: Solder Wick (was Re: DURACELL AA 2300 NiMH) | Jim K | EFLIGHT Mailing List | 1 | Jan 04, 2006 09:11 PM |
| Large Scale turbine Jet Ranger at 3D masters | Carl Farrington | rec.models.rc.helicopter | 40 | Aug 12, 2003 04:02 AM |
| Re: Large scale airplane | Robert Ussery | RCSE | 0 | Jun 26, 2003 04:02 AM |
