Old May 07, 2011, 07:20 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
When we going to see a real FPV piloted vid with it? Unless you do fly with
the camera inside the nose, the endurance will suffer with FPV gear outside the fuse.
My old Funjet could do 25 minutes clean on a 2100mAh batter, and only
15 minutes or less with a camera and Tx outside the fuse.
ian
Daemon is offline Find More Posts by Daemon
Old May 07, 2011, 07:27 PM
jtprouty is offline
Find More Posts by jtprouty
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
The times I posted are with a clean fuselage. I haven't had time to install my video TX yet but it will only add s couple of ounces to the plane. Going out to try some bungee launches with it right now.
jtprouty is offline Find More Posts by jtprouty
Old May 07, 2011, 08:24 PM
scrtsqrl is online now
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Unsolicited Suggestions...
Jimmy,
IMHO, the shoulder wing format is preferable because will reduce wear and tear on the wing's underside.
Could you buiild it a "center section" and optional length forward and tail end fuse sections? This would give the operator the option of choosing the aircraft's volume without you having to re-tool for a completely new diameter fuse.
A tapered end section could significantly reduce noise and increase prop efficiency...
Just some thoughts...Thanks for all your work.
scrtsqrl is online now Find More Posts by scrtsqrl
Old May 07, 2011, 11:34 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
We did some bungee launch testing of the Foamaroo today and it went really well. The winds were very light and variable so I didn't have the benefit of launching into the wind. The bungee is one that we offer, complete with the case to roll it up when finished. Overall launch area is about 30 feet with the bungee stretched out.
No control input is required during the launch until after the bungee has released. In one of the videos I left the motor off and came around to land to demonstrate the ability to land if you have a problem during the launch.
I also asked Dan St. Louis to hand launch the plane to get his opinion of how easily it launches. Unfortunately (for Dan) I forgot to tell him how I have the elevator set up with more throw than it needs and he stalled it during landing, hitting pretty hard on the nose. On the video Dan picks it right back up and re-launches. No damage at all.
I also wanted to demonstrate how easy it launches and performed an underhand launch with very little forward momentum. Worked really well.
Foamaroo Bungee Launch Tests (4 min 41 sec)
Bungee Launch Tests
Launch and Hard Landing of Foamaroo FPV/UAV (2 min 29 sec)
Hand Launch with Hard Landing
Underhand Launch of Foamaroo FPV/UAV (0 min 55 sec)
Underhand Launch
Foamaroo Sport Flying (2 min 10 sec)
Demonstrating how well the Foamaroo flies
Jimmy
Old May 07, 2011, 11:43 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
Thanks for the suggestions. I've got about 10 hours on the prototype thus far and haven't had any wear and tear on the wings yet. I've done a lot of sliding landings and had a couple of bumpy landings but don't see any sign of damage yet. The ground here is really hard due to lack or rain and is perfect for testing the durability of the airframe.
It's actually really easy to customize the length of the fuselage by adding sections in front or behind the fuselage tube. I've come up with a new system that will not only open up the entire fuselage (other than where spars go between the wings, but will also add a large hatch and make the wings break down into three pieces.
tapering the fuselage would add a lot of complexity and cost and our goal is to keep this kit as affordable as possible.
Really appreciate your comments, keep 'em coming!
Jimmy
Originally Posted by scrtsqrl View Post
Jimmy,
Old May 07, 2011, 11:45 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
Ian,
The Foamaroo is designed to keep the camera gear inside the fuselage *(that's why we offer a clear dome.)
Jimmy
ian
Old May 07, 2011, 11:49 PM
scrtsqrl's Avatar
Joined Oct 2006
Jimmy,
You're way ahead of me. Thanks.
Old May 09, 2011, 10:42 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
All the parts for make the wing removable have been ordered and I'll have a second prototype flying as soon as the parts come in. I'll post some pix when it's ready.
Jimmy
Old May 11, 2011, 08:33 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Ian,
Ok, so let's see an FPV piloted video through the clear dome.
ian
Old May 11, 2011, 08:47 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
We'll have to do that after I get the two piece wings complete as I don't fly FPV so don't have goggles to do it with. I have a video TX/RX and should be able to record from that. Even if it was FPV the video would look just like the one I already shot, just from inside the fuse. Really no difference other than 2" in height on the camera.
Jimmy
Old May 11, 2011, 08:57 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
That assumes that the curved clear dome will have zero optical effect on
the picture, be it distortion, or sun flares, etc.. I doubt that, which is why I'd like
to see it. Personally, I'd likely just put the camera above the fuse on a pan servo.
Either way, I'd like to see it demonstrated for its intended purpose since this is
the FPV forum after all. Visually piloted video really does look different than FPV piloted video.
ian
Old May 11, 2011, 09:48 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
The dome that we're using are acrylic and are supposed to be mote optically clear than the other domes but we'll see. Better domes are available but the cost goes up very quickly. We'll be testing the acrylic domes very soon.
Old May 15, 2011, 05:24 AM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
Is there clearance to fit a folding prop. to quieten it a bit?
NDw is offline Find More Posts by NDw
Old May 15, 2011, 07:32 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
You can adjust the position of the tailcone when you install it. The length of the tailcone is dependent on the distance from the firewall to the back plate of the prop hub. If you cut the tailcone short enough you can adjust for a folding prop. I haven't used a prop on my pushers and very rarely break one.
I've also made some good progress on the removable wings and have a solution that I should be flying later this week. I'll be using two carbon spars - a rear one for strength and a forward one to align the wing with the fuselage. I have all the parts, just need to make the jig to cut the holes in the cores.
On another note, I also have a pan system worked out that will install inside the current fiberglass nose cone. It can be rotated 90 degrees when you install the nose to make it a tilt system as well. I'll post more on it in the weeks to come.
Jimmy
Old May 15, 2011, 11:10 PM
scrtsqrl's Avatar
Joined Oct 2006
Jimmy,
Is a shoulder wing option still an option?
Thanks.
Discussion Nayan-uav for india- a 15 kg uav devlopment for search survillance and resuce pritam_ashutos UAV - Unmanned Aerial Vehicles 90 Mar 09, 2011 08:51 AM
Discussion New version of Momentum 40A to 150A Brushless ESC coming back in stock! hobbypartz HobbyPartz.com 10 Aug 18, 2010 05:19 PM
Build Log New Project: Quadcopter - first hover, then OSD, FPV, UAV... the works... MARTINELLI Coaxial Helicopters 5 Aug 02, 2009 01:48 PM
Discussion Recommendations for a EZ*(or other) FPV/UAV design for Public Safety/LEO usage gwenhastings FPV Talk 11 Feb 14, 2008 11:34 AM
Discussion New FPV Extra 300 coming... zaguruinzasky FPV Talk 46 Dec 14, 2007 06:09 PM
