Old Mar 25, 2011, 12:10 AM
philthyy is online now
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
VERY good news indeed! This makes my day! I've been planning on getting an Attopilot system for a while now...so having this plane teamed up with an Atto is going to be perfect for my first true UAV.
philthyy is online now Find More Posts by philthyy
Old Mar 25, 2011, 12:14 AM
chancesAU is offline
Find More Posts by chancesAU
chancesAU's Avatar
Australia
Joined Apr 2008
Originally Posted by Mikey636 View Post
Looks very very similar to a Scan Eagle..
Not a chance
THIS is very similar to a scan eagle
chancesAU is offline Find More Posts by chancesAU
Old Mar 25, 2011, 12:19 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Notice the Scan Eagle avoids landing on its nose with a really tricky
vertical wire catch mechanism. That's going to be the weak point of
the Jackaroo if you opt for the clear dome on the nose, unless you
add landing gear and fly it off a runway, which sort of defeats of
the purpose having all the gear inside to lower drag. With the gear
you have extra drag. Without the gear, you'll get chips and scratches
in the dome in no time.
I'd opt for a non-clear nose, that can take some abuse, and put
the camera on top. The biggest advantage to a fuse design like this
is that it'll be *much* easier to balance than the typical flying wing,
because the battery can be shifted around over the CG. Can change
battery sizes much easier.
I've actually been contemplating something like this for a while
as I found the EPO fuse on my "Scoutjet" to be too fragile. Was thinking
of using a thin walled PVC or ABS pipe as the fuse with an EPP nose.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 25, 2011, 03:01 AM
c4v3man is offline
Find More Posts by c4v3man
It's pronounced Caveman...
Reno, NV
Joined Nov 2009
ian
It'd be neat if you could simply hinge a self-contained dome by the top of the fuse with a servo that would allow you to simply hinge the entire dome up when landing. Obviously would create drag/shift COG when engaged but it would be a lightweight solution that if done at the right moment while landing would prevent scratching. The weight penalty for the hinge/servo would be minimal I'd think.
c4v3man is offline Find More Posts by c4v3man
Old Mar 25, 2011, 08:50 AM
airmcn_3 is offline
Find More Posts by airmcn_3
Moore, Oklahoma
ian
Were keeping it simple.
There are over 200 landings with the dome in front. Not one cracked yet. Scratches are the largest concern.
Tried all you suggested. ABS, PVC, a special blue tube for rockets, molded fuselages and all foam fuselages. If you want it low cost and at a decent weight it will have to be all foam.
It has a very large CG range so you can put your gear in multiple locations. IF you do not want a clear dome just let us know and we will work on making it an option.
Chris
airmcn_3 is offline Find More Posts by airmcn_3
Old Mar 25, 2011, 08:58 AM
techspy is online now
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Very cool! I have been a fan of the Scan Eagle and have considered taking my 60" Ritewing and making a tube fuselage for it with a dome in the front. This looks exactly like I was thinking it would turn out. Is there ANY ballpark price yet?
As for the dome getting scratched, how about a servo activated shield or skid that moves into place when needed? Probably easier that having the whole thing rotate/retract. Or, if the domes are cheap enough where you could by a dozen or so at a good price, just replace as needed. But I know good optically clear ones are not cheap, http://www.cleardomes.com/smalldomes.htm
techspy is online now Find More Posts by techspy
Old Mar 25, 2011, 11:24 AM
airmcn_3 is offline
Moore, Oklahoma
a cover is an interesting idea. Probably something we would not provide on the aircraft to save cost but we could most defiantly distribute drawing details on a working mechanism.
Yes good clear domes are not cheap.....
Old Apr 04, 2011, 09:08 PM
airmcn_3 is offline
Moore, Oklahoma
Should not be long. Would you guys like a closed dome option? It will bring the price down a good amount.
Chris
Old Apr 05, 2011, 08:14 AM
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Yes. Any idea on price????
Old Apr 05, 2011, 09:04 AM
jtprouty is offline
Find More Posts by jtprouty
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
We're still working out the details and should know more shortly. Will have a couple of prototypes flying in the next week or two.
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old Apr 05, 2011, 09:49 AM
Blue Collar is online now
Find More Posts by Blue Collar
United States, NE, Omaha
Joined Oct 2005
Chris
Chris I would sell the plane with a foam dome and a clear dome as a seperate upgrade. I would like to start out with a foam dome until I know the plane is flying well (hate to nose it in on the maiden with an expensive clear dome)that way I am not risking the dome until I comfortable with the plane.
Could you share any details about how the motor mount and winglets attach or will that be left to the builder to decide? Will Vtx and gps slots and cavities be molded or routed into the wings?
Excited to see the final product, its looking like it might just be my next project.
Mark
Blue Collar is online now Find More Posts by Blue Collar
Old Apr 05, 2011, 12:27 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
It will come with either a clear or a fiberglass dome depending on what the customer chooses. The winglets will screw into blind nuts to make them easy to remove. Still working on the motormount.
The GPS can actually be mounted inside the fuselage since there's no material in the plane that will interfere with it. I mount it inside the Osprey fuselage and have never had a problem with GPS reception.
Shouldn't be a problem to rout a cavity for the video TX into the wing - just have to decide how far out of the fuselage to rout the pocket.
Jimmy
Old Apr 06, 2011, 08:44 PM
rclab1 is online now
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
Jimmy/Chris,
hows' the Jackeroo-FPV foam version coming along?
Have you guys set a price yet?
and videos sell :-)
rclab1 is online now Find More Posts by rclab1
Old Apr 06, 2011, 11:32 PM
airmcn_3 is offline
Moore, Oklahoma
Originally Posted by rclab1 View Post
Jimmy/Chris,
and videos sell :-)
Give us a couple weeks. There is a lot to get together for production.
Old Apr 06, 2011, 11:38 PM
USA
Joined May 2010
ok,
perfect!
Discussion Nayan-uav for india- a 15 kg uav devlopment for search survillance and resuce pritam_ashutos UAV - Unmanned Aerial Vehicles 90 Mar 09, 2011 09:51 AM
Discussion New version of Momentum 40A to 150A Brushless ESC coming back in stock! hobbypartz HobbyPartz.com 10 Aug 18, 2010 06:19 PM
Build Log New Project: Quadcopter - first hover, then OSD, FPV, UAV... the works... MARTINELLI Coaxial Helicopters 5 Aug 02, 2009 02:48 PM
Discussion Recommendations for a EZ*(or other) FPV/UAV design for Public Safety/LEO usage gwenhastings FPV Talk 11 Feb 14, 2008 12:34 PM
Discussion New FPV Extra 300 coming... zaguruinzasky FPV Talk 46 Dec 14, 2007 07:09 PM
