Wichita, Kansas, USA
Joined Jul 2003
Foamaroo FPV Video
Marc Browing flew his Foamaroo ARF FPV today and was kind enough to let us record the flight. I took and excerpt of the video and have posted it on YouTube. Marc is still fine tuning his motor/prop combination to get the best endurance from the plane.
We're also adding a couple of extra carbon strips to the wing to stiffen it up a little since the plane tends to "bounce" at speeds above 60 MPH. I've already done the mod on mine and it really stiffens it up.
Jimmy |
Joined Jul 2003
I shot some pictures of the Foamaroo kit tonight that I wanted to share. The first pictures show all of the parts in the kit. All of the holes in the fuselage and wings have been opened including the spar tube holes in the wing, servo wire hole, servo pocket, and winglet mounting dowel holes. The only holes that you have to make are the holes in the motor mount plate, winglets, and a hole in the aft fairing for your propeller shaft. It's pretty easy to assemble, even for a first time builder.
I've also included pictures of an ARF version of the Foamaroo (less motor and servos.) The pictures show both the opaque and clear domes. The nose section can be changed in a matter of seconds to fly different payloads and additional nose sections are available if needed. We can also make them longer or shorter if desired. The final pictures shows all three domes that I'm currently flying (opaque, clear, and opaque modified for my GoPro.) Jimmy
Latest blog entry: Ultrabatic BD-5J
Joined Jul 2003
Here are some pictures of the different kits for comparison.
Joined Jul 2003
Thanks, Gary.
I have a new employee that will be helping me produce our products and am currently bringing him up to speed. Jimmy |
Joined Jul 2003
Hi Patrick,
Yes, we can ship the FPV Foamaroo to Europe. Shipping is approximately $44 (US) via air. Jimmy |
Joined Jul 2003
I put together a quick video on how easy it is to change the nose payload section as well as prep the plane for flight.
Jimmy |
Joined Jul 2003
I've had some people ask which 3M77 product to use before covering the plane. I've used both the black can and the purple can with good results. I don't put on a heavy coat, just a quick coat the let it dry before I cover the plane with Ultracote. BTW - we now offer Ultracote for sale with our kits.
Happy flying, Jimmy |
Joined Jul 2003
Speed Control: http://www.hobbyking.com/hobbyking/s...idProduct=2165 Battery: http://www.hobbyking.com/hobbyking/s...idProduct=9184 -OR - http://www.hobbyking.com/hobbyking/s...dProduct=10383 Quote:
I have finally sourced a 1/2" spar for the plane that won't significantly increase the cost and will be incorporating them in future kits. The current spar system works very well and will shear if you hit a solid object, protecting the airframe and cargo. I think I can eliminate some of the spars strips and cut down on parts count by going to the new rear spar. Quote:
(JK) I'll have to check and see if they have pink Ultracote as I've never looked into it. Quote:
Joined Jul 2003
I could make a smaller hole to run the wires from the wingtip (similar to the one for the current spars) but not the large on that I use for the servos. Typically, a router with a 1/8" bit (Dremel tool) works great for making the well for the wires from the wingtip to the servo bay and then you can run the internally from there. Everyone has their own requirements for equipment so I typically leave that to the builder.
Jimmy |
| Thread Tools | |
| Discussion Nayan-uav for india- a 15 kg uav devlopment for search survillance and resuce | pritam_ashutos | UAV - Unmanned Aerial Vehicles | 90 | Mar 09, 2011 08:51 AM |
| Discussion New version of Momentum 40A to 150A Brushless ESC coming back in stock! | hobbypartz | HobbyPartz.com | 10 | Aug 18, 2010 05:19 PM |
| Build Log New Project: Quadcopter - first hover, then OSD, FPV, UAV... the works... | MARTINELLI | Coaxial Helicopters | 5 | Aug 02, 2009 01:48 PM |
| Discussion Recommendations for a EZ*(or other) FPV/UAV design for Public Safety/LEO usage | gwenhastings | Video Piloting (FPV/RPV) | 11 | Feb 14, 2008 11:34 AM |
| Discussion New FPV Extra 300 coming... | zaguruinzasky | Video Piloting (FPV/RPV) | 46 | Dec 14, 2007 06:09 PM |
