Old Apr 18, 2011, 08:07 AM
Modelholic is offline
Find More Posts by Modelholic
Modelholic's Avatar
Perth WA
Joined Feb 2007
On call? Just wondering what you are on call for. Being a vet myself I know all about being on call -- and I hate it!
The wing is looking great too!
Modelholic is offline Find More Posts by Modelholic
Old Apr 18, 2011, 02:09 PM
ben199 is offline
Find More Posts by ben199
ben199's Avatar
New Zealand
Joined Jul 2008
Originally Posted by PETERRAKE View Post
3 degrees mate - 3/4" under the extreme tip of the top wing. The struts will set the dihedral on the lower panels.
Pete
Thanks Pete
ben199 is offline Find More Posts by ben199
Old Apr 18, 2011, 02:13 PM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Hey Simon,
I work for an electrical company so it shouldn't be too bad, being a vet will be exciting for you!
-Reuben
Old Apr 19, 2011, 05:09 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Originally Posted by portablevcb View Post
Yes, it will follow.
charlie
Hey Charlie,
The motor arrived today, thank you for sending it
It looks good and will set the model off nicely.
Both lower wings are now built and tomorrow night I will start the upper center section.
-Reuben
Old Apr 26, 2011, 04:28 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Starting to look like a plane now
I managed to follow my plan of building a wing section a night and everything went together well, the main wing components were assembled in a straight forward manner after studying the plan's for a few moments to ensure that the right wing ribs were being used.
The only difference that I have found so far between parts and plan's is that the trailing edge stock has been slightly shorter than the plan's, but only by an 1/16th this has been common with all four wing sections.
Other than that its been a simple and enjoyable build so far
I brought some doculam today, I hope its the right stuff..... its 75 micron's???
-Reuben
Old Apr 26, 2011, 05:42 AM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Reuben
Coming on nicely mate, and all that lovely sanding still to do.
I think you might find 75 micron a bit heavy, but others will have a better idea.
I've no idea why the trailing edge pieces should be short, they are exactly the same size on the cut file as those on the plan.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Apr 26, 2011, 08:14 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
It's a combination of two things Pete. The laser cut width is a finite amount that varies from .005" to .010". The other is that pesky acute angle at the outboard ends of the TE. When you have an acute angle the apparent loss of length is much more than the laser cut width. I am actually surprised that it is only 1/16", I'd expect closer to 1/8".
charlie
portablevcb is offline Find More Posts by portablevcb
Old May 01, 2011, 02:09 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
The fuse is now sheeted and some of that lovely sanding has begun
I copied a tip that I saw on Simon's (modelholic's) DVIII build thread and painted the inside of the cockpit area before sheeting it.
All the sheeting was done after the sheet had first been soaked with hot water and left to dry for a couple of days wrapped around a spraycan to hold its shape.
I then made a template to cut the cockpit openings which allowed both holes to be exactly the same.
-Reuben
Old May 01, 2011, 03:01 AM
Buzzkill2 is offline
Find More Posts by Buzzkill2
Buzzkill2's Avatar
United States, MI, Grand Blanc
Joined Mar 2007
Good work. Subscribed
Buzzkill2 is offline Find More Posts by Buzzkill2
Old May 01, 2011, 03:53 AM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
Very nice work.
Len
LenBFP is offline Find More Posts by LenBFP
Old May 02, 2011, 06:40 AM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
That is coming along very nicely mate, she will be a beauty when finished!
Cheers
Craig
trumps is offline Find More Posts by trumps
Old May 06, 2011, 02:48 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
The fuse is coming along I have added the ply sheeting on the bottom and I have bent and soldered the landing gear.
I have attatched the landing gear using aluminium sheet that started its life as a redbull can..... guess it really has wings now
I got this tip off uranus456's flamingo build thread, which has been very helpfull!
-Reuben
Old May 06, 2011, 04:59 AM
Modelholic's Avatar
Perth WA
Joined Feb 2007
That's looking great - the wheels are fantastic. The ply sheeting, is that glued in place?
Thanks for passing on the mounting tip as well.
Old May 06, 2011, 05:09 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Hey Simon,
The rear hatch is held on by the landing gear screws and is the main access panel to the servos and Rx.
The front one will be held on at the front by a simple tab and slot with the rear being latched closed with a couple of small magnets, to allow acess to change the battery.
Its slowly coming together and hopefully I will start the covering on Monday
-Reuben
Old May 06, 2011, 06:16 AM
Norfolk, England
Joined Sep 2001
Reuben,
Looking good mate, should make a very pretty finished model.
Pete
Build Log Peter Rake's Morane Saulnier AI - Upsized Pat Lynch Scale Kit/Scratch Built 354 Nov 18, 2015 06:06 AM
Discussion Peter Rake's Besson MB411 lake flyer Scale Kit/Scratch Built 107 Jul 09, 2012 09:16 AM
Build Log Peter Rake's Yak Air-1 Pat Lynch Scale Kit/Scratch Built 216 Jan 29, 2012 01:35 PM
Build Log Peter Rake's WACO 9 | Prototype Build hoffboy Scale Kit/Scratch Built 88 Jan 13, 2012 08:18 PM
Build Log Peter Rake's Udet Flamingo Prototype Build uranus456 Scale Kit/Scratch Built 55 Dec 01, 2009 08:20 AM
