Old Apr 03, 2011, 05:22 AM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
That is coming along great mate, are you going with pull/pull controls or push rods?
Craig
trumps is offline Find More Posts by trumps
Old Apr 03, 2011, 11:42 AM
PETERRAKE is online now
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Reuben,
Yes mate, just score and crack the longerons.
Pete
PETERRAKE is online now Find More Posts by PETERRAKE
Old Apr 03, 2011, 01:53 PM
ben199 is offline
Find More Posts by ben199
ben199's Avatar
New Zealand
Joined Jul 2008
Craig
Hey Craig,
I'm thinking push rods with a small scale cover where they exit the fuse like on the fullsize
-Reuben
ben199 is offline Find More Posts by ben199
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Originally Posted by PETERRAKE View Post
Reuben,
Pete
Cheers Pete
Old Apr 04, 2011, 12:12 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
A bit more progress made today.
I started to join the two fuse sides together, first the top side which is done with the fuse resting upside down over the plan and then the bottom but at a much slower rate as I forgot to pick up some more right angle squares...
I plan to have the last of the rear fuse framed up later tonight.
While that was drying I marked and drilled the front former for the motor mount.
-Reuben
Old Apr 04, 2011, 12:43 AM
Modelholic is offline
Find More Posts by Modelholic
Modelholic's Avatar
Perth WA
Joined Feb 2007
Excellent work - coming along nicely. I just hope the other half doesn't catch you mutilating her clothes pegs!
Modelholic is offline Find More Posts by Modelholic
Old Apr 04, 2011, 12:46 AM
Modelholic's Avatar
Perth WA
Joined Feb 2007
As an aside if you make two sets of each horizontal to fit the top side and use the second so produced for the bottom side you are pretty much assured parallel sides once complete.
Old Apr 04, 2011, 12:54 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
That sounds like a good tip, I got a bit enthusiastic and realised after I had finished the first set that I should have cut two of each....
Your pilot looks great!
-Reuben
Old Apr 07, 2011, 04:36 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
I have now glued the front and rear fuse sections together and work is progressing well.
I have epoxied the motor mount in and added 3 degree's of down and right thrust while I was at it.
The servo rails are also mounted and work has begun on adding the upper former's.
-Reuben
Old Apr 07, 2011, 04:49 AM
Modelholic's Avatar
Perth WA
Joined Feb 2007
You're going to have to start bending wire soon! There is no escape!
Old Apr 07, 2011, 05:16 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Simon,
I've bent the wire for the upper wing but..... I'm not looking forward to aligning it?
I might be best to wait untill I have the wings done?
-Reuben
Old Apr 07, 2011, 08:52 AM
Norfolk, England
Joined Sep 2001
Reuben,
If you kake up a simple jig - a strip for each fuselage side, another to sit on the fuselage sides (like an H) and a further strip across the top (for the strut ends to align with) - you shouldn't have too many problems. You can use the fuselage section drawing as a guide for making the jig and, as long as your wire bending is accurate, that should set up the front strut quite nicely. The rear strut, again given accurate wire bending, simply aligns with the top of the fuselage sides - although another jig wouldn't hurt things.
Before fitting the u/c wires, I'd suggest covering that area of fuselage bottom. Then you won't have to cover around the sewn in place wires. Unless, of course, you were intending to use P clips. Also remember, if you do bind the u/c wires, you need the top of the fuselage open, so you can still work from the inside.
Yes, I have done this before, and yes, that is how I found out.
Pete
Old Apr 07, 2011, 02:04 PM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Reuben,
Pete
Thanks Pete,
I will definitly be building a jig to align the top wing.
I was thinking of using p-clips to mount the u/c.
The build is going good so far and I havn't struck any problems
Winter has arrived here in the deep south so I should make good progress this weekend.
-Reuben
Old Apr 10, 2011, 07:31 AM
Modelholic's Avatar
Perth WA
Joined Feb 2007
Reuben,
I hope your weekend has been productive and I look forward to seeing the pics. I guess if you haven't been posting here you must have been building!!
The graphics you have obtained from Caille are superb and I hope to obtain a set for the DVIII. I was wondering what sort of information you sent so that I might get mine together and send off for mine!
Old Apr 10, 2011, 08:45 AM
Norfolk, England
Joined Sep 2001
Or, like us in the UK, he's having a glorious day and has gone flying. As for me, I'm up to my ears in plotting DVII wing ribs and making sure the wing will actually fit the fuselage. Such fun!!!
Pete
Build Log Peter Rake's Morane Saulnier AI - Upsized Pat Lynch Scale Kit/Scratch Built 354 Nov 18, 2015 06:06 AM
Discussion Peter Rake's Besson MB411 lake flyer Scale Kit/Scratch Built 107 Jul 09, 2012 09:16 AM
Build Log Peter Rake's Yak Air-1 Pat Lynch Scale Kit/Scratch Built 216 Jan 29, 2012 01:35 PM
Build Log Peter Rake's WACO 9 | Prototype Build hoffboy Scale Kit/Scratch Built 88 Jan 13, 2012 08:18 PM
Build Log Peter Rake's Udet Flamingo Prototype Build uranus456 Scale Kit/Scratch Built 55 Dec 01, 2009 08:20 AM
