Old Mar 24, 2011, 03:22 AM
ben199 is offline
Find More Posts by ben199
ben199's Avatar
New Zealand
Joined Jul 2008
Peter Rake's Udet Flamingo
After searching for my next build and a couple of messages to Mr Rake I have decided to have a go at building one of his models the 38" Udet Flamingo.
After a short search on the net I became interested in this plane, hopefully I can do it justice
I have settled on an actual plane that I wish to reproduce and while I wait for the kit to arrive from manzano laser I have decided to have a go at making some spoked rims.
I have used 70mm pvc drain pipe for the rim's and copper rivets soldered together to make the hub's, fishing line is used for the spokes.
This is my first attempt at spoked rims so there is a bit of trial and error
I also ordered a graphics kit from Callie Graphics and after a short wait it arrived and is exactly what I wanted
-Reuben
ben199 is offline Find More Posts by ben199
Old Mar 24, 2011, 03:35 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Some photo's of the great graphic's kit that Callie has done, it turned out to be more complete and accurate than I had expected and I think it will really set the model off.
-Reuben
Old Mar 25, 2011, 04:35 AM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Reuben,
Glad to see you're keen mate. I think you'll find that more spokes around the rim would result in stronger, better looking wheels.
If you were to double the number at the rim, but keep the same number at the hub you could get a much more realistic looking wheel.
I like your drilled rivet hubs, but you might want to consider joining the two parts with about 10-12 degrees off-set - so the holes aren't in the same position on both sides. Then do the lacing all in one run, starting by doing all the bottom 'spokes'.
It would go a bit like this. Start at the rim (hole 1) and lace through a hub hole, then back out through rim hole 3. go onto rime hole 5 and repeat, coming back out through hole 7, etc., etc.
Once all the bottom spokes are laced, go to the nearest missed rim hole and start the process again for the top spokes. Hopefully, since it's the spokes that provide the strength in these wheels, the greater number of spokes will make for stronger wheels.
Although this shows a different style of wheel, it does give an idea of the lacing pattern.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Mar 25, 2011, 04:53 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Cheers Pete,
The wheel in the photo is a test to see if I could get my head around the lacing, I will add another 12 holes to the rim and have another go.
Thanks for the spoke pattern pdf that makes it a lot easier
-Reuben
Old Mar 25, 2011, 08:58 AM
Norfolk, England
Joined Sep 2001
You're welcome mate. You can ignore those strange looking loops at the top left, they were just for a wheel laced front to back, rather than from the outside of the rim. You can go straight from finishing the back, at 12, to starting the front, at 13.
IIRC, when Pat does his wheels he uses pipe joints, rather than the pipe itself. They're thicker material and allow you to put grooves around the outside for the lacing and tyre to seat into.
Pete
Old Mar 26, 2011, 03:40 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
I put Pete's lacing pdf to the test tonight and I'm happy to say it worked great! One down and one to go.
Pete,
I have a cunning plan to add sides to the rims once they are laced and running true or as close to true as I can get. The sides will be 2x 5mm rings of 1mm plastic sheet.
-Reuben
Old Mar 26, 2011, 08:29 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Since you have nylon fishing line running through metal hub I's recommend you 'fill' the holes in the hub with epoxy. It will minimize the rubbing of the nylon as the wheel flexes.
Nice work. Reminds me I have to build another set for my Pietenpol.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Mar 26, 2011, 09:07 AM
Norfolk, England
Joined Sep 2001
Reuben,
Glad it helped out. Wheel looks good.
Pete
Old Mar 28, 2011, 03:21 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Some more progress...
I took Charlie's advice and epoxied the hubs where the fishing line/spokes are threaded to prevent any fretting due to movement.
I have added the sides to the rims and given them a coat of silver paint, I just have to add the tyres.
I'm happy with the result and already have some idea's on how to improve things next time I need to make some
-Reuben
Old Mar 28, 2011, 04:21 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Just checked the UPS website and.....
Label/Receipt Number: CJ18 2100 *****
Class: Priority Mail International Parcels
Service(s): International Parcels
Status: Arrived Abroad
Your item arrived in NEW ZEALAND at 11:52 am on March 28, 2011. Information, if available, is updated periodically throughout the day.
Old Mar 28, 2011, 08:31 AM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
Now we get to see if NZ customs takes as long as Canadian customs.
Old Mar 28, 2011, 07:26 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Having lived in both fine lands, I vote "No".
Great set of wheels!
Wolpertinger is offline Find More Posts by Wolpertinger
Old Mar 30, 2011, 12:12 AM
ben199 is offline
ben199's Avatar
New Zealand
Joined Jul 2008
Guess what was waiting for me when I finished work today
Charlie,
Was there ment to be a vacume moulded motor in the kit?
Cheers Reuben
Old Mar 30, 2011, 08:54 PM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
Yes, it will follow.
charlie
Build Log Peter Rake's Morane Saulnier AI - Upsized Pat Lynch Scale Kit/Scratch Built 354 Nov 18, 2015 06:06 AM
Discussion Peter Rake's Besson MB411 lake flyer Scale Kit/Scratch Built 107 Jul 09, 2012 09:16 AM
Build Log Peter Rake's Yak Air-1 Pat Lynch Scale Kit/Scratch Built 216 Jan 29, 2012 01:35 PM
Build Log Peter Rake's WACO 9 | Prototype Build hoffboy Scale Kit/Scratch Built 88 Jan 13, 2012 08:18 PM
Build Log Peter Rake's Udet Flamingo Prototype Build uranus456 Scale Kit/Scratch Built 55 Dec 01, 2009 08:20 AM
