Old Mar 23, 2011, 10:40 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Mini-HowTo
Build a performance antenna for your LRS radio
This is my complete tutorial on how to build a turnstile antenna for your LRS system. Everything is explained. Even the theory and impedance plots are given.
You can find it all here: http://fpvlab.com/forums/showthread....tenna-tutorial
This video is the short and dirty:
Build IBCrazys Turnstile LRS antenna for FPV (4 min 33 sec)
Build, Discuss, Enjoy
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 23, 2011, 11:37 PM
hdphil is offline
Find More Posts by hdphil
United States, CA, Galt
Joined Mar 2009
Alex
i was looking at your turnstile antenna, I thought a 75 ohm phasing harness was required between the 2 dipoles.
like this:
http://www.west.net/~jay/turnstile.html
your antenna seems to be more of a modified biquad
Phil
i used to use them for wx satellite work years ago
hdphil is offline Find More Posts by hdphil
Old Mar 25, 2011, 11:23 AM
hdphil is offline
Joined Mar 2009
i guess no comment...
Old Mar 25, 2011, 12:43 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That antenna is a different type of turnstile. The author used a 1/4 wavelength section of coaxial cable to obtain the phase shift where I used the reactive components of the wires. I tried using his method and it failed. The antenna performed very poorly until I tried using the reactances instead.
Does his work? Probably for 2 meters, but it doesn't work for UHF. At least not without a 1/4 wave section of 75 ohm coaxial cable to get the impedances to match up properly.
-Alex
Old Mar 26, 2011, 04:37 AM
hdphil is offline
Joined Mar 2009
thanks Alex,
i wasn't aware of the different way to acheive the same result, i'll have to build one and try it out.
Old Apr 09, 2011, 11:10 AM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Thanks for offering this video, i built myself one for my new plane.
Cheers, Kev.
Kev.au is offline Find More Posts by Kev.au
Old Apr 10, 2011, 08:50 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
Will servo wire work? Is there a certain gauge I need?
Kmart is offline Find More Posts by Kmart
Old Apr 10, 2011, 08:51 PM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
There IS such thing as a stupid question...
"Take 2 pieces of 18-22 AWG wire 15” (40 cm)"
Old Apr 10, 2011, 10:28 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Wire thickness is critical. Wire has two properties R and X. together they create an impedance Z. As wire thickness changes, so does X and R, but X changes much more significantly where R is nearly constant. The X vectors of the two segments need to be opposed as closely to 90 degrees as possible at a point where their parallel equivalent is 50 ohms. This happens with an 18-22 AWG wire. Outside that range the X value changes too much and it loses it's phase shifting properties.
Simulating this is as easy as doing a frequency sweep of a simple Dipole in 4NEC2. Selects X/R plot and you will see what happens as you select different wire thicknesses.
-Alex
Old Apr 10, 2011, 10:46 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
It would be interesting to do a ground range test with this antenna
like in this video
If it passes the test for the plane when it is in a dive or heavy climb it would be cool
or a tight turn
testing for diversity (1 min 6 sec)
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Apr 10, 2011, 11:57 PM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
So is 20awg the most ideal thickness? Or will anything from 18 to 22 work just fine?
Old Apr 11, 2011, 12:13 AM
Mykro is offline
Find More Posts by Mykro
RC Model Plane FPV Pilot..
Joined Feb 2009
Whats the math behind this antenna?
Is it designed only for LRS?
How about the other frequencies??
Mykro is offline Find More Posts by Mykro
Old Apr 11, 2011, 07:20 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The math is a complex impedance matching scheme. I designed it for 22 AWG wire. The reactance of that wire is fine for wire between 24 and 18AWG. 22 is optimal.
It works by phasing the reactive vectors 90 degrees apart. It is actually circularly polarized, but should not be used as such as the rotation shifts between the top and bottom of the antenna.
One element of the antenna is 52 +j54 and the other is 53-j52 if cut perfectly.
-Alex
Old Apr 11, 2011, 07:28 AM
barok is offline
Find More Posts by barok
barok's Avatar
Joined Apr 2006
this will work on any LRS..Dragonlink??...
using the welding wire (same wire used to make the cloverleaf ant.) should be ok..
thanks..
barok is offline Find More Posts by barok
Old Apr 11, 2011, 08:32 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It will work with any LRS. I have some cables coming with MCX connectors for use with the Scherrer LRS.
Welding wire will work ok so long as it is .050 wire. Wire thickness is critical here.
-Alex
Mini-HowTo Build your own TX antenna for FPV IBCrazy FPV Equipment 3058 Today 08:13 AM
Discussion Why Did You Choose Your LRS..... SENTRY 62 FPV Talk 237 Dec 31, 2013 02:06 AM
Question Best 2.4ghz radio for high performance carbon stuff? outngo High Performance 38 Feb 14, 2011 12:12 PM
Discussion How to build heavy Duty Antenna Tracking pod for Eagle Tree FPV? ganapati08 FPV Talk 6 Oct 19, 2010 12:24 PM
Question UHF LRS Pro Antenna Question CageHound FPV Talk 4 Apr 04, 2010 09:47 AM
