Old Mar 23, 2011, 04:58 PM
carl1864 is offline
Find More Posts by carl1864
Joined Jan 2010
Do you guys get drastically different range in city vs country?
I've done a lot of reading about FPV, but one thing I never notice much is range in the city vs in the country. I live in a highly populated area near seattle. I have 2 different FPV systems, a 900mhz 500mw, and a 5.8ghz 200mw (My radio is 2.4 ghz), and even after many many hours of troubleshooting and tinkering, I have never got either one to work very good.
My 5.8ghz has about the range of a medium sized baseball field, the 900mhz even less. I'm starting to think perhaps its all the 900mhz and 5.8 mhz cordless phones, baby monitors, nanny cams, etc. that tons of the houses around here most likely have. I haven't been able to test it in a remote area yet because I simply don't know of any flyable rural area anywhere around here. Everyplace is either densly populated, or else thick forest. No remote open areas that I can think of anywhere.
So that's why I'm asking you guys, do you experience a noticeable difference in range in a city vs in the country, or remote areas?
carl1864 is offline Find More Posts by carl1864
Old Mar 23, 2011, 05:08 PM
outtacontrol is offline
Find More Posts by outtacontrol
VNE Mach 2
outtacontrol's Avatar
United States, FL, Delray Beach
Joined May 2009
I do. I'm on 900mhz 500mw and I watched my plane fly away from me for over a mile today. In the city I've lost video feed at a few hundred feet.
outtacontrol is offline Find More Posts by outtacontrol
Old Mar 23, 2011, 10:13 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes. I've flown 2.5 miles on 500mW 900Mhz out in the country and could
have gone further. When I'm on my home slope overlooking the city, maybe 200 yards
before video goes to crap. I don't think it's 900Mhz baby monitors and cordless
phones though. I think it's overlap from the GSM cellular bands.
For 5.8Ghz you need a higher gain patch antenna on the receiver to
get decent range. There's less interference on 5.8Ghz than most of the other
bands.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 24, 2011, 04:51 PM
twinturbostang is offline
Find More Posts by twinturbostang
Fly FPV, sleep; repeat
twinturbostang's Avatar
United States, MD, Hagerstown
Joined Mar 2006
bands.
ian
What about 1.3GHz? How crowded is it?
twinturbostang is offline Find More Posts by twinturbostang
Old Mar 24, 2011, 05:02 PM
Acorns is offline
Find More Posts by Acorns
United States, IA, Mason City
Joined Oct 2008
On 2.4Ghz 1W I can go 1.5-2.5 miles in the country, or less than 2000 ft in a "city". Your location is really critical.
I haven't noticed as much of a problem with 900Mhz (I've went 7.5 miles on 1W while in the city, though well past the edge of it). I've only flown 1280 a few times, but it did seem pretty clear.
Acorns is offline Find More Posts by Acorns
Old Mar 24, 2011, 05:09 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
1.3Ghz is generally pretty good in urban areas. The problem we're facing though, is that
if *everyone* uses 1.3Ghz even when some other frequency might work for them
in their area then we eventually start shooting each other down. If I could use 900Mhz
I would. If I could use 2.4Ghz I would.
ian
Old Mar 25, 2011, 07:51 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It's not just the RF traffic in the city, but the numer of objects the signal can reflect off of. The more objects there are around you, the worse you will get hit with multipath interference.
Here's an experiment for you:
Find a remote location where there is any type of non-wooden structure nearby (Ie barns do not work, but brick houses and metal sheds do work). Now stand far away from the structure and fly once. For your second flight stand right in front of the structure. What happened to your video? Turned to complete garbage didn't it? That's multipathing. Stand by a metal building and it gets much worse. Or try a metal fence. Same thing.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 25, 2011, 12:40 PM
carl1864 is offline
Joined Jan 2010
-Alex
So do you think multipathing can have a big effect even if you are not actually next to the objects like your expiriment? For example, one of the main places I fly is a baseball field. I stand in the very center of it, no obstructions, open sky. However it is completely surrounded by a chain link fence, and all sorts of houses and buildings outside there. Think that's causing multipathing, even though they are a few hundered feet away?
Thanks for all the responses guys. Wasted so much time troubleshooting equipment that I thought was faulty, but sounds like it all might work just fine if I get away from the interference. I can't wait to find some country area to try out my gear. Probably will be a long time though, I'll have to probably travel half way across the state or something to get away from the population.
Old Mar 25, 2011, 02:08 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
No, multi-pathing is not nearly that big of a problem, unless you're
standing with your back to a house or building or car, or flying your plane
low around the same. I would assume by your range comparison to a "baseball field"
in your first post that you're probably flying in the park and not near buildings.
Where I've experienced the worst video noise from an urban environment,
there was no multi-pathing at all.
ian
Discussion What does charger do different in Fast Charge vs. Balance Charge learn2turn Batteries and Chargers 21 Aug 24, 2013 03:03 AM
Have a question, How do you guys fly so high yet still be in range of control? alanhsu Aerial Photography 29 Sep 07, 2012 11:00 AM
Discussion What kind of Range do you FPV RC Car guys get? airbagit13 FPV Talk 41 Jun 12, 2012 10:21 PM
Question Are you guys ever gonna get some 2500mAh 65c 4s packs in? Z06 Tony Xtreme Power Systems 2 Mar 04, 2011 11:01 PM
Radio Control for UAV, What do you use and how much range do you get ???? JettPilot UAV - Unmanned Aerial Vehicles 17 Apr 14, 2009 12:47 PM
