Old Mar 23, 2011, 04:51 PM
DKNguyen is offline
Find More Posts by DKNguyen
Edmonton, Alberta, Canada
Joined Oct 2008
Heat Sealing Vacuum bag?
I was curious if anyone tried heat sealing their vacuum bagging tubes. Can you just use a regular trim sealing iron?
DKNguyen is offline Find More Posts by DKNguyen
Old Mar 23, 2011, 06:03 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
I use a lot of plastic tubing to do bagging. I have an impulse sealer that will do up to 16". I start the bag out long, cut right at the weld when opening, and reseal again for the next bagging.
Otherwise you can use the bladder welding technique if your plastic is compatible.
wyowindworks is offline Find More Posts by wyowindworks
Old Mar 24, 2011, 03:19 AM
DudleyLeRoux is offline
Find More Posts by DudleyLeRoux
scratch build everything
DudleyLeRoux's Avatar
South Africa, KwaZulu-Natal, Botha's Hill
Joined Aug 2009
I also prefer the plastic tubing route. I seal one end with tacky tape and use a removable clamp seal for the other side.
DudleyLeRoux is offline Find More Posts by DudleyLeRoux
Wanted sealing iron, heat gun, and other finishing supplies no1isnormal Aircraft - General - Miscellaneous (FS/W) 1 Feb 21, 2011 11:31 AM
Discussion Need opinions on my vacuum bag lay-up DKNguyen Composites Fabrication 6 Nov 22, 2010 01:12 AM
Discussion Vac bag sealing discostu956 Slope 30 Oct 04, 2010 07:19 PM
Sold Hobbico Deluxe Heat Gun & Custom Sealing Iron Like New mode101 Aircraft - General - Miscellaneous (FS/W) 8 Sep 27, 2010 04:16 PM
sealing a large vacuum bag? Mr DIY Composites Fabrication 12 Jun 24, 2004 01:31 PM
