Old Mar 23, 2011, 03:07 PM
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
Cool
Another Wicked powered unique jet.
This one should fly this weekend.Its called a Wing Jet EP.Its not sold anymore and for a good reason.It had a problem with wings folding up.The fuse is very nice fiberglass,but wing is balsa and not very strong.I cut underside of monocoat off and added some sheer webbing and CF tow,and a CF spar.It still may fold but hopefully not.This thing was made for a 70mm fan....hmmmm The biggest battery you can fit is a 3s 2100,and thats what it called for,dunno what 70mm fan could use that,maybee in the brushed days.
I installed one of Dons new 5100KV in a used 64mm shroud with a cutdown Wemo rotor.I have not got any numbers yet,I did run it up and its gonna make the jet scoot,but battery was not nearly charged up,charging it up now.Stay tuned....Joe
fh64_lucky is offline Find More Posts by fh64_lucky
Old Mar 23, 2011, 05:46 PM
fh64_lucky's Avatar
Joined May 2005
I got a flight on it this afternoon,the wing did not fold.....It is not as fast as I hoped for but it flew well.A touch tail heavy,I went with a nano2100,going to use a regular 2200 as that is just a bit heavier.Try n get some video this weekend.Joe
Old Mar 23, 2011, 11:45 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Joe,
That is a unique looking plane! Remember when mounted like that your outlet is 100% FSA, and it really needs a thrust tube and possibly an inlet lip. I bet it would go well with the W3000 or W2700 as a pusher prop model.
The Don is offline Find More Posts by The Don
Old Oct 06, 2012, 08:45 AM
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
FWIW, the WingJet is still being sold.
I ordered one last night from Airborne Models in CA (US distributor). $124.99
The redesigned kit addressed the wing issue. It also changed the servo mounting from vertical to horizontal, so it is easier to identify the two.
ltc is offline Find More Posts by ltc
Build Log Wicked powered Windrider BD-5J EDF Jet The Don Don's RC 118 Oct 31, 2014 10:01 AM
Build Log Wicked Powered Jpower 50mm T-45 EDF The Don Don's RC 32 Aug 07, 2011 04:31 PM
Build Log Wicked Powered J-Power 50mm L-39 The Don Don's RC 27 Jun 22, 2011 02:52 PM
Build Log Wicked Powered Max-Jet F-117 Stealth EDF from Nitroplanes The Don Don's RC 62 Jun 01, 2011 09:45 PM
Build Log Wicked Powered J-power 50mm F-35 The Don Don's RC 26 Oct 14, 2010 01:27 AM
