Old Mar 23, 2011, 10:57 AM
reptileman is offline
Find More Posts by reptileman
nj
Joined Jan 2004
these are safe to keep in your radio?
I just got one of these life batteries to replace my lipo pack for my radio because i was sick of taking it in and out.... the life packs are safe to keep in your radios right?
reptileman is offline Find More Posts by reptileman
Old Mar 23, 2011, 11:20 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Every pack is safe to keep in your radio, unless it malfunctions, or is charged in the wrong way.
Julez is offline Find More Posts by Julez
Old Mar 23, 2011, 11:29 AM
nj
Joined Jan 2004
Just don't trust lipos in the radio all the time!
Old Mar 23, 2011, 12:01 PM
Himalaya is offline
Find More Posts by Himalaya
Himalaya's Avatar
Joined May 2009
Any TX lipo accident reports?
Himalaya is offline Find More Posts by Himalaya
Old Mar 23, 2011, 08:28 PM
slide ruler is offline
Find More Posts by slide ruler
misguided user
slide ruler's Avatar
United States, ND, Fargo
Joined Mar 2011
i think leaving the tx on all night would be a accident. i did that a few times already. i use eneloops tho.
slide ruler is offline Find More Posts by slide ruler
Old Mar 23, 2011, 10:58 PM
Himalaya is offline
Himalaya's Avatar
Joined May 2009
Most if not all decent radios beep if no operation for a few minutes. Even if some don't, the most one can lose is just an overdischarged pack, it may puff, but no hazard.
Old Mar 24, 2011, 05:39 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I left mine on overnight twice with no problems.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Mar 24, 2011, 09:11 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Beaware that the DX7 and likely other transmitter can become scrambled if left on until battery become very low. If this happens they must go back to repaire center for fixing. I have not experienced this myself but I never leave my on by accident either but I have read of many such reports.
Guess I should add that I have used NiMH cells for years and years in my RC Transmitters and that for the past 4 years or so the LSD type mostly Sanyo Eneloops.
Charles
Old Mar 24, 2011, 08:03 PM
akschu is offline
Find More Posts by akschu
akschu's Avatar
USA, AK, Houston
Joined Aug 2005
Or you could just sanyo eneloops then you don't have to worry about over working the regulator, removing the battery to charge, over discharge, etc, but still maintaining the very long sitting battery life.
akschu is offline Find More Posts by akschu
Old Mar 24, 2011, 09:39 PM
misguided user
Joined Mar 2011
Def agree there.
Old Mar 25, 2011, 01:06 AM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
Eneloops
If you are going to use a square cell technology I think this is a way better option than a LiPo.The voltage range doesnt hammer the regulator either.The low voltage alarm is still in the correct range as well.LiFe packs tend to stay balanced better than LiPo but its still a good idea to balance charge.
aerocal is offline Find More Posts by aerocal
Old Mar 25, 2011, 06:58 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Don't trust NiMH as well. This happend to a friend's plane when the charger failed to stop charging the RX battery.
Could as well happen to your TX.
Old Mar 25, 2011, 07:13 AM
Southern Pride
NiMH s AKA Eneloops in a Transdmitter charge just fine with the OEM Wal Wart chargers which do not depend on peak detections. Any charger can fail but in 49 years of flying RC I have never had the first problem with these low tech supplied with the radio systems chargers.
There is no need in using a peak detection charger with a RC Transmitter Ni battery unless you need a fast charge at the field due to poor planing on your part. A 1 Amp. rate charge at the field for 15 min. will give you between 1 and 2-1/2 hours of addational transmitter on time depending on your radio.
Charles
Old Mar 25, 2011, 08:24 AM
nitrodude71 is offline
Find More Posts by nitrodude71
r/c addict
USA, LA, DeRidder
Joined Jul 2004
Charles
i left my dx7 with lipo on overnight by accident once about a year ago and have had no problems as of yet knock on wood (besides an over discharged lipo)
nitrodude71 is offline Find More Posts by nitrodude71
Old Mar 25, 2011, 09:34 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I had an old Cannon wall wart TX/RX charger suddenly burn up while I was in the room. Seemed to be a short where the wires exited the plastic case although hard to tell after the fact. I wonder if a bad pack or leaving connected too long can cause a wall wart charger's output wires to overheat melt and short.
E-Challenged is offline Find More Posts by E-Challenged
Discussion How are you "Safe" starting your electric death machine?? hidaven Electric Plane Talk 61 Dec 15, 2010 11:03 AM
Discussion are these lipo's safe? Niek-1 Batteries and Chargers 4 May 26, 2008 09:14 PM
Discussion 1 or 2 receivers/batteries **1:2,3 SCALE** ? What would y do to keep your $$ safe ? mnluz Scale Sailplanes 44 Feb 13, 2008 04:01 AM
My dad just bought some lipos...are these things really that safe? RJ Fighter Beginner Training Area (Aircraft-Electric) 11 Oct 17, 2005 04:14 PM
