Old Jun 21, 2012, 07:18 AM
Joined May 2011
Originally Posted by Paiste2002 View Post
hi there FDR .
here is the picture of the Sub trim ,
Notice the letters .
Skin 1 & 3 Are great
Yes, that's what I was afraid of...
It means, that my modifications make the skin 2 unusable. (Try to edit a value: then the background will be white, so you won't see the white text at all!)
Sorry, but if you want to use the skin 2, than you have to revert to the original library!
It would be possible to make the backgrounds mid-gray, but then it wouldn't be optimal for either skin. For example when it writes on it with red (while editing or selected) then color blinds won't see the text...
I will make a notice on this issue in the announcement post.
Thank you for testing, I really appreciate it!
FDR
FDR_ is offline Find More Posts by FDR_
Old Jun 21, 2012, 07:30 AM
Australia, VIC, Cranbourne West
Joined Jun 2012
I Just bought a DEVO 12s ,,, Does it actually have different setting for every Heli ?
Because I set one up and by the time i got to setup my 4th heli , the first one changed a fear bit ?? am i doing something wrong ?
For some reason all 4 heli's are acting the same
Dahm nice Radio though .
Paiste2002 is offline Find More Posts by Paiste2002
Old Jun 21, 2012, 07:34 AM
Joined Jun 2012
Anytime
Glad i could help
Old Jun 21, 2012, 07:35 AM
Joined May 2011
Well, it has 60 model memories, but not all the settings are in the model data, for example the settings of the system menu (the rightmost button with a wrench) are general for the transmitter.
Old Jun 24, 2012, 07:43 AM
Joined Jun 2012
Yah Thanks Guys ,, It was a bit of a stupid Question as I figured it all out in a day or two
Thanks anyway , i am really enjoyinh the DEVO 12S it has alot it can do and alot to learn , but it still is a easy enough TX to use
Old Jul 04, 2012, 04:48 AM
Joined Aug 2007
Originally Posted by brianos007 View Post
Whats the use of the telemetry in the devo12 if you can not use it.
You have to disable the sensor not to have the lock outs.
I have a devo12 with the telemetry module and a devo12S and both have the same problem when the sensor is active lock outs on both the transmitters.
With the sensor inhibit the devos work super fine without any lock outs.
Its daylight robbery they now sommething is wrong with the telemetry and still selling the devo12S and promoting the telemerty function
Is walkera telling costumors there is sommething wrong with the devo12 NOW they dont and they now the problem exist
Its a very nice TX if you dont need the telemetry.
Lets hope they soon come with a solution for this problem.
Grtz Ed
I have just ordered a 12S so I can not try out this idea I had about telemetry problem. But I have studied former Walkera radio protocols and something came to my mind:
- Did you try the following sequence? 1) Tx Off 2)Rx + Telemetry On 3) Tx On
- Are Rx and telemetry antennas close by or parallel to each other?
As telemetry is sent in the same radio band the TX uses to transmit, it might be jamming the signal. If you switch the Tx when telemetry is already transmitting, the 12S would be able to sense the busy channel and avoid it.
It would be also a good idea to have all 3 antennas perpendicular to each other (2 from Rx ad one from telemetry).
Just a theory but worth trying out...
renatopub is offline Find More Posts by renatopub
Old Jul 04, 2012, 01:48 PM
Live to learn. . .
Rafa's CB100's Avatar
Austin, TX
Joined Dec 2009
You know they fixed telemetry with the latest firmware update, right?
http://www.rcgroups.com/forums/showthread.php?t=1644811
Rafa
Rafa's CB100 is offline Find More Posts by Rafa's CB100
Old Jul 05, 2012, 09:19 AM
USA, SC, Easley
Joined Sep 2009
Been flying with the Devo for a few months now and really like it. One thing that drives me nuts is not having servo speed control. I hate to see the flaps bang down and even in the air you can see the plane jump with you throw them. I have looked into setting one of the slides as the control so I can deploy them slowly but the flap menu does not allow that, at least as far as I can tell maybe I am missing something. Can set up a custom mix but have not gotten around to it. Anyone have any ideas?
yellowbird2800 is offline Find More Posts by yellowbird2800
Old Jul 10, 2012, 04:17 PM
Joined Oct 2011
Heli8, did you ever figure out how to get trim in delta wing mode? I've got a Devo 10 on order (with a mini CP), and I'm thinking of getting a tuffwing (which would need elevons).
Thanks!
Originally Posted by Heli8ight View Post
BRIANOS,
My two issues with this radio are:
1 sloppy switch
No trim adjustments in Delta wing mode (This could be opperator error though)
A futaba 10CHP is a great radio for the price. RX's can be a little pricey though.
Bill Mercer is offline Find More Posts by Bill Mercer
Old Jul 12, 2012, 12:29 PM
100mph club member
turbodriven's Avatar
NW O-town
Joined Jun 2005
Where is the best place to buy this? Best price with shipping that is?
turbodriven is offline Find More Posts by turbodriven
Old Jul 24, 2012, 09:26 AM
Joined Jul 2012
Hi,
Can someone please open the 12s and tell what's written on four big chips on the board? It cannot be seen on the photo.
The most important thing is the square chip in the center next to the LCD panel connector.
agalakhov is offline Find More Posts by agalakhov
Old Jul 28, 2012, 02:34 AM
Suomi, JKL
Joined Apr 2011
Does anyone know where to find a ppm signal DEVO12S transmitter?
I would like to combine Jeti transmitter module.
justiina is offline Find More Posts by justiina
Old Aug 08, 2012, 04:47 AM
eriskio's Avatar
Joined Mar 2010
Hi All,
I would thank FDR_ for it great library!
I've installed it on my Devo12 about 1 month ago and I'm really happy with it!
Small idea/suggestion: while there are some projects on the way like new "deviation" firmware and FDR_' libraries, it would be a nice to have a PC based model editor, doesn't it?
Model data saved on .bin files are really simple to decode, I think.
Someone interested?
Bye
eriskio is offline Find More Posts by eriskio
Old Aug 08, 2012, 05:01 AM
Joined May 2011
Originally Posted by eriskio View Post
Hi All,
Someone interested?
Bye
You are welcome!
I've made a model editor for the DEVO 8/8S, and there wasn't too much interest about it...
Since the model data file of each DEVO model is a different binary, it's not that easy to port them to other transmitters (not to mention that the DEVO 12 has much more options). The most tiring part of the development was to discover the model data file: change one thing, turn off (beep), turn on in dfu mode, name the file, download the file, compare it with a default file, leave dfu mode (beep-beep), change it back, change something else, and so on x1000 times!
Old Aug 08, 2012, 08:22 AM
eriskio's Avatar
Joined Mar 2010
Originally Posted by FDR_ View Post
You are welcome!
OPS... my fault sorry. :-) I haven't found it on your site before.
Anyway I agree with you: mapping the model file can be a really boring and long job. But your web editor is amazing and really nice!
Maybe it would be more interesting to users if the USB driver developed for Deviation firmware project could be used also with original firmware, so that the editor software can also be used as a database of one's own models without the mess of uploading/downloading each model as bin file.
Discussion Walkera Devo 12 (11X clone) Nuremberg 2011 Mikarro Radios 7 May 13, 2011 10:28 AM
Discussion Walkera 4#6 first impression ehirobo Micro Helis 39 Apr 28, 2011 07:48 PM
Discussion Walkera 1#A, First Impression icwebby 3D Electric Heli Flying 6 Feb 13, 2011 08:44 PM
Discussion What is your First Impression? rimshotcopter Life, The Universe, and Politics 48 Nov 27, 2010 06:19 PM
Discussion Walkera 4G6 first impression. ehirobo Micro Helis 138 Mar 21, 2010 09:53 PM
