Australia, VIC, Romsey
Joined Jul 2003
Could be silly questions but I'll ask them anyway
1. Will a 28mm diameter Outrunner BL fit inside the cowls? Looks like it from Saucisse's excellent pics. 2. Ditto, is the circumference of the firewall at the front of the nacelle large enough to accommodate an X mount? Great thread. Keep up the good work. I wish I'd got one of these for as a birthday present instead of the crappy EBay kit! ( http://www.rcgroups.com/forums/showthread.php?t=1357209 ) Cheers and thanks Mick |
In the video posted at the beginning of the thread the 370 motors used are 28mm. They seemed to fit very well and they use an X mount, unless Nitroplanes mounted them differently.
Side note: USPS left the "You have a package at the post office" in the mailbox today. Tracking number says it's my CL415. Yay! |
My GWS E-starter on Floats, my GWS Islander seaplane and my own design Catalina all used Artists Acrylic Paint from a craft store. None of these models has had any paint problems even though they are only flown fom off water.
I would think that for cheapnes and durability the CL-415 would use one of these acrylics. Being alcahol or water based the do not damage EPS models when applied. Ken |
![]() I am using the 370s and they fit with the x mount. I mounted the motors to the firewalls fed the wires through the nacelle. I then exopied ( I make many holes with a toothpick to ensure good bond) the firewall to the step inside the nacelle, the motor can then be used to eyeball the alignment. No downthrust or upthrust issues we noted during flight test. Bummer about you false alarm ( package pick up)
Mine is here tooo. Very nice...
![]() ![]() ![]() I have to make the decision about the motors - please help ?: http://www.hobbyking.com/UNITEDHOBBI...idProduct=2111 or http://www.hobbyking.com/UNITEDHOBBI...dProduct=14737 I have both pairs on the stock and I would like to use them with master Airscrew 8x6 3-blade propellers. Thanks huntingfield for the mounting tips. |
http://www.hobbyking.com/UNITEDHOBBI...dProduct=14737 |
The spray version isn't much different than undercoating in a can, which would also work. Or brush on electrical tape and a glob of silicon grease around the output shaft. |
Thanks for the info. The spray can is available in Australia and it can be otained in yellow colour. Ken |
| Thread Tools | |
| For Sale MR Aerodesign Canadair CL-415 Kit Complete | Rudderman98 | Aircraft - Fuel - Airplanes (FS/W) | 0 | May 09, 2009 07:05 PM |
| Found Canadair CL 415 kit,ARF, ARC,or plans | rcdude01 | Aircraft - Electric - Airplanes (FS/W) | 2 | Nov 13, 2008 05:41 PM |
| Wanted Looking for a Canadair CL-415 ARF or kit, maybe plans | rcdude01 | Aircraft - Electric - Airplanes (FS/W) | 1 | Oct 17, 2008 04:54 PM |
| For Sale Canadair CL-415 Kit NIB | EAMRC | Aircraft - Electric - Airplanes (FS/W) | 1 | Oct 29, 2006 11:36 AM |
| FS: Canadair CL-415 Kit | Rudderman98 | Aircraft - Electric - Airplanes (FS/W) | 3 | Oct 11, 2004 09:54 PM |
